| 0001638 | FreeCAD | Bug | public | 2014-07-25 11:51 | 2019-07-29 15:16 |
| Reporter | worstsalad | Assigned To | wmayer | ||
| OS | Windows | OS Version | 7x64 | ||
| Summary | 0001638: Not possible to draw anything. | ||||
| Description | When changing to any workbench, I receive the error "DLL load failed: Procedure not found." and thats it, not possible to draw anything. | ||||
| Steps To Reproduce | Just change to any workbench. | ||||
... 00:01:13.368: Loaded "c:\program files\freecad 0.14\bin\TKERNEL.DLL" at address 0x000007FEE5750000 by thread 1. Successfully hooked module. 00:01:13.368: Loaded "c:\windows\system32\TBBMALLOC.DLL" at address 0x000000000E590000 by thread 1. Successfully hooked module. 00:01:13.368: Loaded "c:\program files\freecad 0.14\bin\TKG2D.DLL" at address 0x000007FEE69E0000 by thread 1. Successfully hooked module. ... 00:01:13.415: Loaded "c:\program files\freecad 0.14\bin\TKMESH.DLL" at address 0x000007FEE45B0000 by thread 1. Successfully hooked module. 00:01:13.415: Loaded "c:\windows\system32\TBB.DLL" at address 0x000000000FF90000 by thread 1. Successfully hooked module. 00:01:13.430: First chance exception 0xC0000139 (DLL Not Found) occurred in "c:\windows\system32\NTDLL.DLL" at address 0x000000007769D7E8 by thread 1. The problem might be that tbb.dll and tbbmalloc.dll is already installed under c:\windows\system32\. This directory is reserved for system libraries and all other dlls have nothing lost there. The problem is that the OpenCascade dlls try to load these dlls there instead of the local copy. Since tbb is a C++ library and apparently the version in system32 isn't binary compatible none of the OCC dlls load. Solution: Remove or at least rename tbb.dll and tbbmalloc.dll inside c:\windows\system32\ |
Report back if the given solution works. |
That solved the issue. Thank's a lot! Some other folks I work with also share(d) my DLL-Hell-Problem. One could prevent such things with using fully qualified paths to load the needed DLL's. (Also interesting: https://support.microsoft.com/kb/2389418/en-us and https://en.wikipedia.org/wiki/DLL_Hell) |
Apparently does National Instruments Software cause this Problem. To be precise, the IMAQ Image Processing Framework. It seems as if the NI-Framework needs to have these DLL's in the system32 Directory. An option would be to copy the DLL's NI copied to the system32 Directory to the NI-Directory, but then one would have a non-standard NI-Directory-Tree which could lead to further Problems. A workaround for me was to copy the tbb*.dll's from the FreeCAD\bin to the FreeCAD\lib directory. Which solved the Problem, but that's just a workaround. Another option for you would be, to load the Python modules with FreeCAD\bin as search path for DLL-Libraries (if that is possible). (At least do i think that a Python-Module loads the tbb.dll and tbbmalloc.dll from system32.) |
Thanks for the link to the secure loading of DLLs. Very interesting reading. However, I'm not sure what problems it can cause to implement the secure loading because ATM it's possible that users can also use 3rd party Python extension modules like numpy or the like. Now when setting fully qualified paths this won't be possible any more, for sure. > It seems as if the NI-Framework needs to have these DLL's in the system32 Directory.... That's totally insane design IMO. The system directory is reserved for system DLLs and it's taboo for any kind of application DLLs. > At least do i think that a Python-Module loads the tbb.dll and tbbmalloc.dll from system32. It's not a Python module it's one of the Opencascade libraries those starting with "TK". |
Note to myself: In FreeCADInit.py commenting out this block makes the load of PartDesignGui.pyd failing because Part.pyd can't be found. #try: # os.environ["PATH"] = PathExtension + os.environ["PATH"] #except KeyError: # os.environ["PATH"] = PathExtension #path = os.environ["PATH"].split(os.pathsep) #Log("System path after init:\n") #for i in path: # Log(" " + i + "\n") However, when changing the CMake macro SET_BIN_DIR to make all .pyd files to go to ${CMAKE_BINARY_DIR}/lib everything works fine again. |
Note to myself: When putting a faked tbb.dll into system32 then FreeCAD fails to load all OCC-dependent modules. When adding these three lines std::string binPath = TempHomePath; binPath += "bin"; BOOL ok = SetDllDirectory(binPath.c_str()); into Application::FindHomePath and making sure tbb.dll is in the bin directory everything works OK. With SetDllDirectory the DLL search order changes that with the specified path comes BEFORE system32 and system. Also, the CWD is dropped which we don't need anyway. The reason why moving tbb.dll to the lib directory fixes this problem is because the dynamically loaded Python module lies there and apparently this counts as the "application" and not the FreeCAD executable which is inside bin. To sum up: + Add the three liner to fix this issue + Remove the block to extend PATH and create all .pyd's under lib is optional. |
Downgrade severity as the actual problem is solved |
FreeCAD: master e327662d 2014-07-30 18:21:53 Details Diff |
Affected Issues 0001638 |
FreeCAD: releases 3ecaf877 2014-08-28 15:27:35 wmayer Details Diff |
- fix focus issue with InputField - on document load set camera setting of the MDI views - do not try to use framebuffer objects when it's not supported on the system 0001690: sketch.getPoint crashes FreeCAD if the point does not exist 0001630: IGES-Export in [mm] turns to [Inches] 0001684: Sweep ignores the list of subshapes 0001667: 'Save file' disabled when viewing a drawing 0001682: Crash after updating editable texts in drawing 0001659: 3dconnexion space navigator moves view even when FreeCAD is not the active application 0001696: Quantity.getValueAs('rad') touches the Property 0001638: Not possible to draw anything |
Affected Issues 0001630, 0001638, 0001659, 0001667, 0001682, 0001684, 0001690, 0001696 |
| mod - src/Base/QuantityPy.xml | Diff File | ||
| mod - src/Gui/Document.cpp | Diff File | ||
| mod - src/Gui/GuiApplicationNativeEventAware.cpp | Diff File | ||
| mod - src/Gui/InputField.cpp | Diff File | ||
| mod - src/Gui/MouseSelection.cpp | Diff File | ||
| mod - src/Mod/Drawing/App/FeaturePage.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/DrawingView.cpp | Diff File | ||
| mod - src/Mod/Part/App/PartFeatures.cpp | Diff File | ||
| mod - src/Mod/Part/App/TopoShape.cpp | Diff File | ||
| mod - src/Mod/Sketcher/App/SketchObjectPyImp.cpp | Diff File | ||
| 2014-07-25 11:51 | worstsalad | New Issue | |
| 2014-07-25 11:52 | worstsalad | File Added: FreeCAD_dependency_walker-Log.csv | |
| 2014-07-25 11:52 | worstsalad | File Added: Dependencywalker-Profile-Log.txt | |
| 2014-07-25 13:56 | wmayer | Note Added: 0004851 | |
| 2014-07-25 14:46 | wmayer | Note Added: 0004853 | |
| 2014-07-25 14:46 | wmayer | Status | new => feedback |
| 2014-07-28 13:18 | worstsalad | Note Added: 0004862 | |
| 2014-07-28 13:18 | worstsalad | Status | feedback => new |
| 2014-07-28 14:07 | worstsalad | Note Added: 0004863 | |
| 2014-07-30 12:05 | wmayer | Note Added: 0004880 | |
| 2014-07-30 15:45 | wmayer | Note Added: 0004891 | |
| 2014-07-30 16:16 | wmayer | Note Added: 0004892 | |
| 2014-07-30 18:53 | wmayer | Changeset attached | => FreeCAD Master master e327662d |
| 2014-08-24 09:04 | wmayer | Assigned To | => wmayer |
| 2014-08-24 09:04 | wmayer | Status | new => assigned |
| 2014-12-31 16:36 | wmayer | Status | assigned => resolved |
| 2014-12-31 16:36 | wmayer | Fixed in Version | => 0.15 |
| 2014-12-31 16:36 | wmayer | Resolution | open => fixed |
| 2015-01-12 12:08 | wmayer | Note Added: 0005632 | |
| 2015-01-12 12:08 | wmayer | Severity | block => minor |
| 2015-02-22 17:20 | yorik | Status | resolved => closed |
| 2019-07-29 15:16 | Kunda1 | Changeset attached | => FreeCAD releases 3ecaf877 |
