| 0001659 | FreeCAD | Bug | public | 2014-07-31 20:20 | 2019-07-29 15:16 |
| Reporter | mghansen256 | Assigned To | |||
| Platform | Linux | OS | Kubuntu | OS Version | 14.04 |
| Summary | 0001659: 3dconnexion space navigator moves view even when FreeCAD is not the active application | ||||
| Description | When FreeCAD is not the active application, the viewport still reacts to space navigator actions. IMHO this is not convenient, because I do not notice that the space navigator is touched for example, and my viewport moves around. Also, this is problematic when two FreeCAD instances are running as both are simultaneously controlled by the space navigator... | ||||
| Additional Information | OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3702 (Git) Branch: releases/FreeCAD-0-14 Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 | ||||
Hi, I added a patch. Also available as pull request: https://github.com/FreeCAD/FreeCAD_sf_master/pull/32 Best regards, Michael |
FreeCAD: master 9419259f 2014-08-18 22:26:05 Committer: wmayer Details Diff |
1659: 3dconnexion space navigator moves view even when FreeCAD is not the active application Check whether the freecad window is active before relaying the space navigator events. |
Affected Issues 0001659 |
| mod - src/Gui/GuiApplicationNativeEventAware.cpp | Diff File | ||
FreeCAD: releases 3ecaf877 2014-08-28 15:27:35 wmayer Details Diff |
- fix focus issue with InputField - on document load set camera setting of the MDI views - do not try to use framebuffer objects when it's not supported on the system 0001690: sketch.getPoint crashes FreeCAD if the point does not exist 0001630: IGES-Export in [mm] turns to [Inches] 0001684: Sweep ignores the list of subshapes 0001667: 'Save file' disabled when viewing a drawing 0001682: Crash after updating editable texts in drawing 0001659: 3dconnexion space navigator moves view even when FreeCAD is not the active application 0001696: Quantity.getValueAs('rad') touches the Property 0001638: Not possible to draw anything |
Affected Issues 0001630, 0001638, 0001659, 0001667, 0001682, 0001684, 0001690, 0001696 |
| mod - src/Base/QuantityPy.xml | Diff File | ||
| mod - src/Gui/Document.cpp | Diff File | ||
| mod - src/Gui/InputField.cpp | Diff File | ||
| mod - src/Gui/MouseSelection.cpp | Diff File | ||
| mod - src/Mod/Drawing/App/FeaturePage.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/DrawingView.cpp | Diff File | ||
| mod - src/Mod/Part/App/PartFeatures.cpp | Diff File | ||
| mod - src/Mod/Part/App/TopoShape.cpp | Diff File | ||
| mod - src/Mod/Sketcher/App/SketchObjectPyImp.cpp | Diff File | ||
| 2014-07-31 20:20 | mghansen256 | New Issue | |
| 2014-08-18 20:35 | mghansen256 | File Added: 1659-patch.diff | |
| 2014-08-18 20:37 | mghansen256 | Note Added: 0004963 | |
| 2014-08-19 16:22 | wmayer | Changeset attached | => FreeCAD Master master 9419259f |
| 2014-08-19 16:23 | wmayer | Status | new => closed |
| 2014-08-19 16:23 | wmayer | Resolution | open => fixed |
| 2014-08-19 16:23 | wmayer | Fixed in Version | => 0.15 |
| 2015-03-23 01:12 | tanderson69 | Relationship added | related to 0002019 |
| 2019-07-29 15:16 | Kunda1 | Changeset attached | => FreeCAD releases 3ecaf877 |
