0002730FreeCADBugpublic2017-01-30 15:22
Reportereephyne Assigned Toyorik
Status closedResolutionfixed
PlatformLinuxOSArch
Product Version0.16
Summary0002730: Fillet are not showed in drawing
DescriptionI can reproduce this everytime.
the fillet of parts are not showed in side view (but in isometric its there).
Its even more than that because where fillet should be there, it show everything behind. (you don't see it in my exemple but to see it symple replace the cylinder with a tube and you will see the inside)
Steps To ReproduceYou simply sketch a circle and extrude it. then make a fillet to one edge.
Then go to drawing, insert a new one and put a projection of the cylinder with fillet on it. The fillet show in iso view but not in side view
TagsOCC Bug, upstream
Relationships
related to 0002354 closedyorik Drawing Arcs missing in projections of revolved sketches
related to 0002383 closedyorik Drawing Drawing lines missing or incorrect
child of 0001931 closedwmayer FreeCAD migration to OCCT 7.1
eephyne
2016-10-08 08:39
reporter
Capture du 2016-10-08 10-34-38.png (Attachment missing)
eephyne
2016-10-08 08:40
reporter
Capture du 2016-10-08 10-22-29.png (Attachment missing)
wandererfan
2016-10-08 13:04
manager   ~0007348
This is a known problem with OCC. It has been reported:
https://tracker.dev.opencascade.org/view.php?id=27782
eephyne
2016-10-08 13:16
reporter   ~0007349
This concern every version/os/config or its relative to something that can be updated/modified ?
wandererfan
2016-10-09 12:18
manager   ~0007351
As far as I know, it affects all versions & platforms. There is a workaround that works sometimes - change your projection direction slightly, say from [0,1,0] to [0.01,1,0] (thanks to @aron)
2017-01-17 04:29
administrator   ~0007831
Upstream bug has been fixed in OCC 7.1
Made this ticket a child of 0001931
2017-01-25 22:25
administrator   ~0007989
Resolving based on comment from @triplus in https://forum.freecad.org/viewtopic.php?f=10&t=16952&start=50#p154772
> Both issues issue 0002730 and issue 0002354 where resolved and can be closed:
> [based on] https://forum.freecad.org/viewtopic.php?f=3&t=17015&start=10#p142531
2016-10-08 08:39 eephyne New Issue
2016-10-08 08:39 eephyne File Added: Capture du 2016-10-08 10-34-38.png
2016-10-08 08:40 eephyne File Added: Capture du 2016-10-08 10-22-29.png
2016-10-08 13:00 wandererfan Relationship added related to 0002354
2016-10-08 13:00 wandererfan Relationship added related to 0002383
2016-10-08 13:04 wandererfan Note Added: 0007348
2016-10-08 13:16 eephyne Note Added: 0007349
2016-10-09 12:18 wandererfan Note Added: 0007351
2017-01-17 04:26 Kunda1 Tag Attached: OCC Bug
2017-01-17 04:26 Kunda1 Tag Attached: upstream
2017-01-17 04:28 Kunda1 Relationship added child of 0001931
2017-01-17 04:29 Kunda1 Note Added: 0007831
2017-01-25 22:25 Kunda1 Note Added: 0007989
2017-01-25 22:25 Kunda1 Status new => resolved
2017-01-25 22:25 Kunda1 Resolution open => fixed
2017-01-25 22:25 Kunda1 Assigned To => Kunda1
2017-01-25 22:25 Kunda1 Assigned To Kunda1 =>
2017-01-30 15:22 yorik Status resolved => closed
2017-01-30 15:22 yorik Assigned To => yorik
