| 0004149 | PartDesign | Bug | public | 2019-09-28 09:13 | 2020-01-07 17:07 |
| Reporter | Igor_De | Assigned To | Kunda1 | ||
| OS | Linux Mint | OS Version | 19.2 | ||
| Summary | 0004149: Freecad crashes or spoil solids on fillet operation | ||||
| Description | Fillet works wrong (or crash Freecad) if side of fillet goes to cilindrical surfase combined from 2 different extrusions. | ||||
| Steps To Reproduce | Try to apply fillet on edge in attached file. | ||||
| Additional Information | OS: Linux 4.15.0-64-generic Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14555 (Git shallow) Build type: Release Branch: (HEAD detached at 0.18.3) Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3 Python version: 2.7.15 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Russian/Russia (ru_RU) | ||||
One more edge to crash. |
The same problem on 0.19 version. I've tested it : OS: Linux Mint 19.2 (X-Cinnamon/cinnamon) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18323 (Git) AppImage Build type: Release Branch: master Hash: af2e97da7b21d4e5ffef587c97f3ab99e720cd59 Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Russian/Russia (ru_RU) |
@Igor_De : this is a well known limitation caused by interaction with seam line. ;) If you need more information or think there is more to do, please open a forum topic according guidelines in the big yellow box on top of the page. Thanks. :) |
If it is a "well known limitation" - it shold not completly crash software ;-) Just show message: "Impossible" |
@openBrain do you know if this is listed in the Known Issues thread, btw? Is there a ticket open for this crash bug already ? |
@Kunda1 : 0002715, 0003436, 0004076 IMO describes the exact same issue. 0003310, 0003970, 0003977 may be same kind of issue. 0003142, 0003554 describes other known limitations of (tricky) fillet/chamfer tools. Unfortunately I think all cases are OCC issues. :/ |
@Igor_De : this is sensible but not so simple. 0003436:0012736 can be of interest for your understanding. FC uses external pieces of software, especially OCC as a geometric kernel. Limitations (as cases where they appear) are multiple. Raising a ticket for each basically clutters the tracker, that's why we ask you to post to forum first. In this case, your file would probably has been added to an existing ticket as test case. ;) Notice that refining your model before filleting solves the issue. :) |
Thanks a lot (for detailed answer and for Freecad). Sorry for delay - I had no time for answer. And sorry for troble - my English is still not so fluent. I am novice in Freecad, but not in design. I studied russian lessons and articles. It makes me cry (it looks like mind masturbation). So, I am going to make good manuals/lessons for russian language. That was the reason for this ticket. Let's close this ticket (I have no rights to change ticket state). |
| 2019-09-28 09:13 | Igor_De | New Issue | |
| 2019-09-28 09:13 | Igor_De | File Added: Fillet test.FCStd | |
| 2019-09-28 09:13 | Igor_De | File Added: Edge.jpg | |
| 2019-09-28 09:22 | Igor_De | OS | => Linux Mint |
| 2019-09-28 09:22 | Igor_De | OS Version | => 19.2 |
| 2019-09-28 09:22 | Igor_De | File Added: Edge 2.jpg | |
| 2019-09-28 09:22 | Igor_De | Note Added: 0013691 | |
| 2019-09-28 10:40 | Igor_De | Note Added: 0013692 | |
| 2019-09-28 10:49 | Igor_De | Note Edited: 0013692 | |
| 2019-09-29 13:30 | openBrain | Note Added: 0013693 | |
| 2019-09-29 13:31 | openBrain | Status | new => feedback |
| 2019-09-29 13:31 | openBrain | Tag Attached: #tobeclosed | |
| 2019-09-29 19:18 | Igor_De | Note Added: 0013694 | |
| 2019-09-29 19:18 | Igor_De | Status | feedback => new |
| 2019-09-30 00:46 | Kunda1 | Note Added: 0013697 | |
| 2019-09-30 13:34 | openBrain | Note Added: 0013699 | |
| 2019-09-30 13:41 | openBrain | Note Added: 0013700 | |
| 2019-09-30 19:11 | Igor_De | Note Added: 0013701 | |
| 2020-01-07 17:07 | Kunda1 | Assigned To | => Kunda1 |
| 2020-01-07 17:07 | Kunda1 | Status | new => closed |
| 2020-01-07 17:07 | Kunda1 | Resolution | open => no change required |
| 2020-01-07 17:07 | Kunda1 | Tag Detached: #tobeclosed |
