| 0003310 | FreeCAD | Bug | public | 2018-01-14 15:25 | 2022-01-15 13:00 |
| Reporter | Goulou | Assigned To | chennes | ||
| Platform | Linux | OS | 4.9.56-21 x86_64 | OS Version | Fedora 25 |
| Summary | 0003310: Application crash when adding a fillet on an edge (SIGSEGV) (Target OCC7.5) | ||||
| Description | When adding a fillet on a specific edge, FreeCAD crashes. I am running latest version from GIT (commit 8ba4e0c5d0284fd8a631d24db607f0d0039991d1). | ||||
| Steps To Reproduce | -open the file support.fcstd with FreeCAD -select the PartDesign workbench -Select the edge highlighted on the screenshot -click the icon "Make a fillet on a edge, face or body" | ||||
| Additional Information | Full stacktrace :
Additional version information :
| Tags | crash, fillet, OCC 7.6, OCC Bug, upstream | ||||
Version informations : OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13031 (Git) Build type: Release Branch: master Hash: 8ba4e0c5d0284fd8a631d24db607f0d0039991d1 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 Locale: English/UnitedStates (en_US) |
Confirmed with: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13188 (Git) Build type: Debug Branch: master Hash: 76d27f46456ee46905361e9646b0976a38a830fd Python version: 2.7.8 Qt version: 5.6.0 Coin version: 4.0.0a OCC version: 7.0.0 Locale: German/Germany (de_DE) Unfortunately, it's an OCCT issue which we are not able to fix. |
Who should I report it to then? |
Added to https://forum.freecad.org/viewtopic.php?f=10&t=20264#p156236 |
Upstream ticket: https://tracker.dev.opencascade.org/view.php?id=29493 |
Upstream has targeted fix for OCC7.4 |
Upstream bumped this to OCC7.5 tagged this ticket accordingly updated OCC buglist https://forum.freecad.org/viewtopic.php?f=10&t=20264 |
Could you check wether this is a duplicate? - create a fillet with r>=1.2mm on this selected edge: forum thread I created because I didn't find this ticket earlier: https://forum.freecad.org/viewtopic.php?f=3&t=39163&sid=d976b4594a9a704395d041b4472668dc |
Upstream ticket was was bumped to OCC 7.6 roadmap. Tagged this ticket OCC7.6 Notated in OCC bugtracker list: https://forum.freecad.org/viewtopic.php?f=10&t=20264 |
In my testing, this is resolved by the fix discussed in 0004543. |
@chennes has created a downstream patch that fixes the crash. It is slowly being integrated in to downstream packages (ATM libpack is the only one but more will follow). This issue is therefore being marked as resolved. It will be closed one all packages are patched or when (if) upstream merges. |
This patch has been merged into OpenCASCADE 7.6, and the patch for earlier OCCT versions has been incorporated into all packages of FreeCAD 0.19.3 that I am aware of. |
| 2018-01-14 15:25 | Goulou | New Issue | |
| 2018-01-14 15:25 | Goulou | File Added: crash_fillet_on_edge.png | |
| 2018-01-14 15:25 | Goulou | File Added: support.fcstd | |
| 2018-01-14 15:25 | Goulou | Tag Attached: crash | |
| 2018-01-14 15:25 | Goulou | Tag Attached: fillet | |
| 2018-01-14 15:26 | Goulou | Note Added: 0010764 | |
| 2018-01-16 14:53 | Kunda1 | Tag Attached: #post-to-forum | |
| 2018-01-16 14:54 | Kunda1 | Target Version | => 0.17 |
| 2018-01-30 15:13 | wmayer | Status | new => confirmed |
| 2018-01-30 15:13 | wmayer | Target Version | 0.17 => |
| 2018-01-30 15:13 | wmayer | Note Added: 0010899 | |
| 2018-02-02 20:28 | Goulou | Note Added: 0010914 | |
| 2018-02-05 16:59 | Kunda1 | Tag Attached: OCC Bug | |
| 2018-02-05 17:01 | Kunda1 | Note Added: 0010922 | |
| 2018-02-05 17:15 | Kunda1 | Tag Attached: upstream | |
| 2018-02-08 14:47 | Kunda1 | Note Added: 0010935 | |
| 2018-02-08 14:47 | Kunda1 | Tag Attached: OCC 7.3 | |
| 2018-02-08 14:47 | Kunda1 | Tag Detached: #post-to-forum | |
| 2018-02-08 14:48 | Kunda1 | Summary | Application crash when adding a fillet on an edge (SIGSEGV, full stacktrace available) => Application crash when adding a fillet on an edge (SIGSEGV) (Target OCC7.3) |
| 2018-03-03 10:46 | Kunda1 | Tag Attached: OCC 7.4 | |
| 2018-03-03 10:46 | Kunda1 | Tag Detached: OCC 7.3 | |
| 2018-03-03 10:47 | Kunda1 | Note Added: 0010989 | |
| 2018-03-03 10:47 | Kunda1 | Summary | Application crash when adding a fillet on an edge (SIGSEGV) (Target OCC7.3) => Application crash when adding a fillet on an edge (SIGSEGV) (Target OCC7.4) |
| 2019-09-01 19:41 | Kunda1 | Tag Detached: OCC 7.4 | |
| 2019-09-01 19:41 | Kunda1 | Tag Attached: OCC 7.5 | |
| 2019-09-01 19:41 | Kunda1 | Summary | Application crash when adding a fillet on an edge (SIGSEGV) (Target OCC7.4) => Application crash when adding a fillet on an edge (SIGSEGV) (Target OCC7.5) |
| 2019-09-01 19:41 | Kunda1 | Note Added: 0013515 | |
| 2019-09-14 10:11 | ari | File Added: fillet crashes freecad.png | |
| 2019-09-14 10:11 | ari | File Added: usb-c case.FCStd | |
| 2019-09-14 10:11 | ari | Note Added: 0013595 | |
| 2020-10-08 13:54 | Kunda1 | Tag Detached: OCC 7.5 | |
| 2020-10-08 13:54 | Kunda1 | Tag Attached: OCC 7.6 | |
| 2020-10-08 13:54 | Kunda1 | Note Added: 0014801 | |
| 2021-02-04 05:15 | chennes | Note Added: 0015258 | |
| 2021-02-27 13:22 | Kunda1 | Assigned To | => chennes |
| 2021-02-27 13:22 | Kunda1 | Status | confirmed => resolved |
| 2021-02-27 13:22 | Kunda1 | Resolution | open => fixed |
| 2021-02-27 13:22 | Kunda1 | Fixed in Version | => 0.20 |
| 2021-02-27 13:22 | Kunda1 | Note Added: 0015445 | |
| 2021-02-27 13:24 | Kunda1 | Relationship added | duplicate of 0004543 |
| 2021-12-29 03:49 | chennes | Status | resolved => closed |
| 2021-12-29 03:49 | chennes | Note Added: 0016141 | |
| 2022-01-15 12:44 | Kunda1 | Tag Attached: OCC 7.7 | |
| 2022-01-15 12:45 | Kunda1 | Tag Detached: OCC 7.6 | |
| 2022-01-15 12:59 | Kunda1 | Tag Detached: OCC 7.7 | |
| 2022-01-15 13:00 | Kunda1 | Tag Attached: OCC 7.6 |
