| 0001624 | FreeCAD | Bug | public | 2014-07-21 15:35 | 2016-11-07 22:17 |
| Reporter | Azureviolin | Assigned To | |||
| Platform | Intel® Core™ i7-3840QM | OS | Ubuntu x64 | OS Version | 12.04 |
| Summary | 0001624: move a loft solid freezes Freecad | ||||
| Description | I create a part with "Part Design",and need to create a loft, so I switch to "Part" and create a loft with a sketch(large circle) and a draft(small circle) (showen in central part of the screenshot). After I created the loft, I rotate it a bit, and freecad freezes (not sure if freecad should be crashed by then since I'm running freecad within gdb all the time) | ||||
| Steps To Reproduce | Not sure if I can reproduce this. | ||||
| Additional Information | #0 0x00007ffff40bf7cc in SoAction::traverse(SoNode*) () from /usr/lib/libCoin.so.60 #1 0x00007ffff40ca143 in SoHandleEventAction::beginTraversal(SoNode*) () from /usr/lib/libCoin.so.60 0000002 0x00007ffff40c0452 in SoAction::apply(SoNode*) () from /usr/lib/libCoin.so.60 0000003 0x00007ffff4287399 in SoEventManager::actuallyProcessEvent(SoEvent const*) () from /usr/lib/libCoin.so.60 0000004 0x00007ffff3c0578c in SoQtRenderArea::processSoEvent(SoEvent const*) () from /usr/lib/libSoQt4.so.20 0000005 0x00007ffff3c3012b in SoQtViewer::processSoEvent(SoEvent const*) () from /usr/lib/libSoQt4.so.20 0000006 0x00007ffff775ba7f in Gui::CADNavigationStyle::processSoEvent(SoEvent const*) () from /usr/lib/freecad/lib/libFreeCADGui.so 0000007 0x00007ffff7759b60 in Gui::NavigationStyle::processEvent(SoEvent const*) () from /usr/lib/freecad/lib/libFreeCADGui.so 0000008 0x00007ffff7765a24 in Gui::View3DInventorViewer::processSoEvent(SoEvent const*) () from /usr/lib/freecad/lib/libFreeCADGui.so 0000009 0x00007ffff3c08182 in SoQtRenderArea::processEvent(QEvent*) () from /usr/lib/libSoQt4.so.20 0000010 0x00007ffff776ba71 in Gui::View3DInventorViewer::processEvent(QEvent*) () from /usr/lib/freecad/lib/libFreeCADGui.so 0000011 0x00007ffff3c02275 in SoQtGLWidgetP::eventFilter(QObject*, QEvent*) () ---Type <return> to continue, or q <return> to quit--- from /usr/lib/libSoQt4.so.20 0000012 0x00007ffff5548028 in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000013 0x00007ffff5caf85f in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000014 0x00007ffff5cb50bf in QApplication::notify(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000015 0x00007ffff7599d87 in Gui::GUIApplication::notify(QObject*, QEvent*) () from /usr/lib/freecad/lib/libFreeCADGui.so 0000016 0x00007ffff5547e9c in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000017 0x00007ffff5cb0862 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000018 0x00007ffff5d2fc35 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000019 0x00007ffff5d2ebee in QApplication::x11ProcessEvent(_XEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000020 0x00007ffff5d58112 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000021 0x00007fffee43dd13 in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 0000022 0x00007fffee43e060 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 0000023 0x00007fffee43e124 in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 ---Type <return> to continue, or q <return> to quit--- 0000024 0x00007ffff5577426 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000025 0x00007ffff5d57d9e in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000026 0x00007ffff5546c82 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000027 0x00007ffff5546ed7 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000028 0x00007ffff554bf67 in QCoreApplication::exec() () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000029 0x00007ffff75963a3 in Gui::Application::runApplication() () from /usr/lib/freecad/lib/libFreeCADGui.so 0000030 0x0000000000403e21 in main () | ||||
From the stack trace I can't detect any hint for a freeze or crash. And running FreeCAD with gdb all the time may slow down the performance dramatically. You should run it normally and check again if it still hangs. |
| 2014-07-21 15:35 | Azureviolin | New Issue | |
| 2014-07-21 15:35 | Azureviolin | File Added: Screenshot from 2014-07-21 23:26:18.png | |
| 2014-07-22 17:45 | wmayer | Note Added: 0004831 | |
| 2016-11-07 22:17 | wmayer | Status | new => closed |
| 2016-11-07 22:17 | wmayer | Resolution | open => unable to reproduce |
