| 0002261 | Draft | Bug | public | 2015-09-13 07:20 | 2015-12-15 13:15 |
| Reporter | f3nix | Assigned To | yorik | ||
| Summary | 0002261: Unhandled exceptions with Draft->Downgrade 2 | ||||
| Description | Hi, I get: Found 1 face: extracting its wires Found only wires: extracting their edges Catchpoint 1 (exception thrown), 0x00007fffee61384d in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #0 0x00007fffee61384d in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6 #1 0x00007ffff657561c in Base::InterpreterSingleton::runString (this=0x696d40, sCmd=0x4d88040 "Draft.downgrade(FreeCADGui.Selection.getSelection(),delete=True)") at /home/f3nix/devel/freecad/FreeCAD/src/Base/Interpreter.cpp:162 0000002 0x00007ffff73a5703 in Gui::Command::doCommand (eType=Gui::Command::Doc, sCmd=0x7fffcc4a280c "Draft.downgrade(FreeCADGui.Selection.getSelection(),delete=True)") at /home/f3nix/devel/freecad/FreeCAD/src/Gui/Command.cpp:432 0000003 0x00007ffff733ead8 in Gui::Application::sDoCommand (args=0x7fffcd3eb490) at /home/f3nix/devel/freecad/FreeCAD/src/Gui/ApplicationPy.cpp:893 0000004 0x00007ffff5feff92 in PyEval_EvalFrameEx () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 0000005 0x00007ffff6082740 in PyEval_EvalCodeEx () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 0000006 0x00007ffff601d2ac in ?? () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 0000007 0x00007ffff60592e3 in PyObject_Call () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 0000008 0x00007ffff6081347 in PyEval_CallObjectWithKeywords () from /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 0000009 0x00007fffee8c7cac in PySide::SignalManager::callPythonMetaMethod(QMetaMethod const&, void**, _object*, bool) () from /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2 0000010 0x00007fffee8cde10 in ?? () from /usr/lib/x86_64-linux-gnu/libpyside-python2.7.so.1.2 0000011 0x00007ffff073772b in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000012 0x00007fffd135acb3 in ?? () from /usr/lib/python2.7/dist-packages/PySide/QtCore.so 0000013 0x00007ffff073b953 in QObject::event(QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000014 0x00007fffd135a85b in ?? () from /usr/lib/python2.7/dist-packages/PySide/QtCore.so 0000015 0x00007ffff11ea7bc in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000016 0x00007ffff11f12d8 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000017 0x00007ffff7328631 in Gui::GUIApplication::notify (this=0x7fffffffce20, receiver=0x376b880, event=0x7fffffffcb20) at /home/f3nix/devel/freecad/FreeCAD/src/Gui/Application.cpp:1552 0000018 0x00007ffff072236d in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000019 0x00007ffff0753ffb in ?? () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000020 0x00007ffff0751031 in ?? () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000021 0x00007fffe9813c3d in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 0000022 0x00007fffe9813f20 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 0000023 0x00007fffe9813fcc in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0 0000024 0x00007ffff075198d in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000025 0x00007ffff1292396 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000026 0x00007ffff0720ec1 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000027 0x00007ffff0721225 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000028 0x00007ffff0726ca9 in QCoreApplication::exec() () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000029 0x00007ffff7323a14 in Gui::Application::runApplication () at /home/f3nix/devel/freecad/FreeCAD/src/Gui/Application.cpp:1851 0000030 0x0000000000405a82 in main (argc=1, argv=0x7fffffffe1b8) at /home/f3nix/devel/freecad/FreeCAD/src/Main/MainGui.cpp:235 Unhandled Base::Exception caught in GUIApplication::notify. The error message is: local variable 'result' referenced before assignment | ||||
| Steps To Reproduce | 1. Open Draft WB 2. Select object. 3. Draft->Downgrade 4. Select Face004 5. Draft->Downgrade 6. Select Wire003 7. Draft->Downgrade 8. Select Edge 9. Draft->Downgrade | ||||
| Additional Information | OS: Debian GNU/Linux testing (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5519 (Git) Build type: Debug Branch: master Hash: 216a7479785ef998f552829f2a03de775c2469f4 Python version: 2.7.10 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| 2015-09-13 07:20 | f3nix | New Issue | |
| 2015-09-13 07:20 | f3nix | File Added: frame-xz-v2.FCStd | |
| 2015-09-13 08:52 | wmayer | Relationship added | related to 0002260 |
| 2015-09-13 08:53 | wmayer | Project | FreeCAD => Draft |
| 2015-09-13 08:53 | wmayer | Assigned To | => yorik |
| 2015-09-13 08:53 | wmayer | Status | new => assigned |
| 2015-12-02 23:32 | yorik | Changeset attached | => FreeCAD Master master d0dac0c6 |
| 2015-12-02 23:32 | yorik | Status | assigned => closed |
| 2015-12-02 23:32 | yorik | Resolution | open => fixed |
