| 0004026 | FreeCAD | Bug | public | 2019-06-17 19:31 | 2020-12-08 15:57 |
| Reporter | mariojose | Assigned To | |||
| Platform | Intel i5-2430M | OS | Debian | OS Version | 9 Stretch Stable |
| Summary | 0004026: Crash when union object | ||||
| Description | When union a specific dimension of cubes, freecad crash and close. If I create 2 cubes with default size (10x10x10mm) and make a union, it works. But if I change size, like steps following, and make a union, freecad crash. When I start FreeCad in bash:
When I make a union of specific dimension of objects (steps following):
| Steps To Reproduce | Open FreeCAD Create a new project Select "Parts" Create a Cube and make it: length= 3mm; width: 3mm, height: 10mm Create another Cube and make it: length= 3mm; width: 3mm, height: 3mm Move the second cube bottom beside of the first cube as annexed image Select first cube and second cube and make a union Crash | ||||
| Additional Information | OS: Debian GNU/Linux 9 (stretch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16117 (Git) AppImage Build type: Release Branch: (HEAD detached at 0.18.2) Hash: dbb4cc6415bac848a294f03b80f65e888d531742 Python version: 3.6.7 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedKingdom (en_GB) | ||||
| Tags | #pending-forum, 0.18, appimage, boolean, Part | ||||
Can't reproduce neither with 0.18.1 (from stable PPA) nor with latest 0.19 (from daily PPA) @mariojose : thanks a lot for reporting. However as requested in the bug reporting policy (in the giant yellow banner on top of this page, and in the "Read this before reporting" on the left), may you please open a dedicated topic on the Help subforum ? This will allow other forumers to confirm the issue and help finding the root cause. Once issue is eventually confirmed, forum thread & ticket can be crosslinked to ease bug fixing. Could you please also provide a FCStd file containing the 2 cubes just before trying to make the union ("moving beside as in picture" isn't very precise ;) ) ? Thanks |
Excuse-me. Yes, I read the post of banner recommendation. I did several tests and in all I have problem (in appimage 0.18.16117 and in debian package 0.16). I think, apparently, that maybe a bug. I attached a file you requested. If I start new project, without saving it, and make a union, it crash. When open the file and make a union it works. Sorry for that. Best |
@mariojose thanks for this ticket. As @openBrain mentioned the guidelines, it's actually faster if you first post bugs to the forum for the community to verify and then recommend to open a ticket. Nevertheless, you provided a good report with a backtrace and we thank you for that. Also in addition to the above task, you could try testing this issue on the 0.19dev appimage (which is fine to work in parallel with 0.18 (just make a backup of your 0.18 project before opening it in 0.19_pre). |
@mariojose please respond |
@mariojose please test https://github.com/FreeCAD/FreeCAD/releases/tag/0.19_pre |
@mariojose ping |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=42487 |
Unable to reproduce. Opened attachement in freecad daily, went to part workbench, selected both cubes in model tree, and clicked union in the toolbar. |
I can't reproduce either on OS: Manjaro Linux (KDE//usr/share/xsessions/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.23237 (Git) Build type: Release Branch: master Hash: 71726a11d0844f263dad636fb98bb996a479e007 Python version: 3.8.6 Qt version: 5.15.2 Coin version: 4.0.1 OCC version: 7.5.0 Locale: English/United States (en_US) |
Closing ticket as it is not reproducible on v0.19 |
| 2019-06-17 19:31 | mariojose | New Issue | |
| 2019-06-17 19:31 | mariojose | Tag Attached: 0.18 | |
| 2019-06-17 19:31 | mariojose | Tag Attached: appimage | |
| 2019-06-17 19:31 | mariojose | Tag Attached: boolean | |
| 2019-06-17 19:31 | mariojose | Tag Attached: Part | |
| 2019-06-17 19:31 | mariojose | File Added: freecad_bug.png | |
| 2019-06-17 20:22 | openBrain | Note Added: 0013241 | |
| 2019-06-17 20:23 | openBrain | Status | new => feedback |
| 2019-06-17 20:54 | mariojose | File Added: union_crash.FCStd | |
| 2019-06-17 20:54 | mariojose | Note Added: 0013242 | |
| 2019-06-17 20:54 | mariojose | Status | feedback => new |
| 2019-06-17 20:58 | mariojose | Note Edited: 0013242 | |
| 2019-06-18 07:53 | Kunda1 | Status | new => feedback |
| 2019-06-18 07:53 | Kunda1 | Note Added: 0013249 | |
| 2019-07-22 11:04 | Kunda1 | Tag Attached: #post-to-forum | |
| 2019-07-23 23:40 | Kunda1 | Note Added: 0013376 | |
| 2019-08-22 20:34 | Kunda1 | Note Added: 0013452 | |
| 2020-01-14 18:17 | Kunda1 | Note Added: 0014075 | |
| 2020-01-16 13:40 | Kunda1 | Note Added: 0014088 | |
| 2020-01-16 13:41 | Kunda1 | Tag Detached: #post-to-forum | |
| 2020-01-16 13:41 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-12-08 00:38 | marthinwurer | Note Added: 0015114 | |
| 2020-12-08 15:54 | Kunda1 | Note Added: 0015117 | |
| 2020-12-08 15:57 | Kunda1 | Status | feedback => closed |
| 2020-12-08 15:57 | Kunda1 | Resolution | open => fixed |
| 2020-12-08 15:57 | Kunda1 | Fixed in Version | => 0.19 |
| 2020-12-08 15:57 | Kunda1 | Note Added: 0015118 |
