| Description | I was importing an SVG and generated a Solid from it. I was then doing something in another window and after sometime FreeCad Daily from 06.09.2018 (0.18) crashed by segmentation fault.
I copied the full output in the terminal. Importent part is ofcause at the end.
Regards,
Max
FreeCAD 0.18, Libs: 0.18R14570 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
processing element 1: svg
existing group transform: []
done processing element 1
processing element 2: metadata
existing group transform: [Matrix ((29.5858,0,0,0),(0,29.5858,0,0),(0,0,1,0),(0,0,0,1))]
done processing element 2
processing element 3: rdf:RDF
done processing element 3
processing element 4: cc:Work
done processing element 4
processing element 5: dc:format
done processing element 5
processing element 6: dc:type
done processing element 6
processing element 7: dc:title
done processing element 7
processing element 8: sodipodi:namedview
done processing element 8
processing element 9: defs
done processing element 9
processing element 10: image
done processing element 10
processing element 11: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'M', u'52.370349', u'107.09884', u'36.452907', u'88.233721', u'55.318023', u'62.981976', u'l', u'22.795349', u'10.022093', u'7.369186', u'-6.386627', u'5.797093', u'-4.618024', u'5.40407', u'-3.635465', u'6.877909', u'-4.716279', u'-2.84942', u'-23.777907', u'29.86977', u'-11.888953', u'14.24709', u'20.928488', u'10.80814', u'-1.768605', u'10.12035', u'-0.68779', u'11.00465', u'0', u'10.2186', u'-22.107559', u'31.34361', u'6.976163', u'0.29477', u'24.465698', u'10.61162', u'4.912791', u'6.28838', u'3.438953', u'6.77965', u'4.028489', u'4.61802', u'3.242441', u'21.02674', u'-12.969767', u'22.40233', u'22.500581', u'-12.96977', u'21.223256', u'5.99361', u'9.432557', u'3.93023', u'7.07442', u'3.04593', u'7.17267', u'1.86686', u'4.32326', u'24.26919', u'-0.19651', u'6.97616', u'31.93314', u'-22.30407', u'9.92384', u'0.0983', u'6.97616', u'-0.29477', u'10.02209', u'-0.78605', u'8.45', u'-0.98256', u'6.87791', u'19.65117', u'12.87151', u'-10.80814', u'30.85233', u'-24.66221', u'-3.24245', u'-4.32326', u'7.27093', u'-3.63546', u'5.60059', u'-6.28842', u'7.7622', u'-4.61802', u'5.01105', u'8.74477', u'19.55291', u'0.58953', u'1.67035', u'0.29477', u'1.27732', u'-25.44825', u'18.76686', u'-18.76687', u'-15.91744', u'-9.13779', u'4.32326', u'-6.09186', u'2.25988', u'-8.54825', u'2.94768', u'-6.58314', u'1.47383', u'-3.14419', u'23.18837', u'-0.29477', u'1.76861', u'-31.73662', u'2.55465', u'-7.66396', u'-24.17093', u'-11.00465', u'-1.47384', u'-9.3343', u'-1.96511', u'-10.70988', u'-3.73372', u'-16.0157', u'18.57034', u'-28.887211', u'-16.60523', u'6.58314', u'-22.8936', u'-5.993605', u'-4.61803', u'-8.548256', u'-8.54825', u'-8.056977', u'-9.3343', u'-22.402325', u'6.38662', u'-1.768605', u'0.39303', u'-13.85407', u'-26.82384', u'-1.179069', u'-2.65291', u'19.258139', u'-15.3279', u'-3.733721', u'-12.87152', u'-2.947674', u'-13.75581', u'-0.393023', u'-4.61802', u'-23.581396', u'-6.77965', u'2.751163', u'-32.81745', u'23.777907', u'-3.93023', u'3.537209', u'-9.92384', u'4.814535', u'-12.28197', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4196'], u'fill': u'none'}
move Vector (52.370349, -107.09884, 0.0)
line Vector (52.370349, -107.09884, 0.0) Vector (36.452907, -88.233721, 0.0)
line Vector (36.452907, -88.233721, 0.0) Vector (55.318023, -62.981976, 0.0)
line Vector (55.318023, -62.981976, 0.0) Vector (78.113372, -73.004069, 0.0)
line Vector (78.113372, -73.004069, 0.0) Vector (85.482558, -66.617442, 0.0)
line Vector (85.482558, -66.617442, 0.0) Vector (91.279651, -61.999418, 0.0)
line Vector (91.279651, -61.999418, 0.0) Vector (96.683721, -58.363952999999995, 0.0)
line Vector (96.683721, -58.363952999999995, 0.0) Vector (103.56163000000001, -53.647673999999995, 0.0)
line Vector (103.56163000000001, -53.647673999999995, 0.0) Vector (100.71221000000001, -29.869766999999996, 0.0)
line Vector (100.71221000000001, -29.869766999999996, 0.0) Vector (130.58198000000002, -17.980813999999995, 0.0)
line Vector (130.58198000000002, -17.980813999999995, 0.0) Vector (144.82907, -38.909302, 0.0)
line Vector (144.82907, -38.909302, 0.0) Vector (155.63721, -37.140696999999996, 0.0)
line Vector (155.63721, -37.140696999999996, 0.0) Vector (165.75756, -36.452906999999996, 0.0)
line Vector (165.75756, -36.452906999999996, 0.0) Vector (176.76221, -36.452906999999996, 0.0)
line Vector (176.76221, -36.452906999999996, 0.0) Vector (186.98081000000002, -14.345347999999998, 0.0)
line Vector (186.98081000000002, -14.345347999999998, 0.0) Vector (218.32442000000003, -21.321510999999997, 0.0)
line Vector (218.32442000000003, -21.321510999999997, 0.0) Vector (218.61919000000003, -45.787209, 0.0)
line Vector (218.61919000000003, -45.787209, 0.0) Vector (229.23081000000002, -50.699999999999996, 0.0)
line Vector (229.23081000000002, -50.699999999999996, 0.0) Vector (235.51919, -54.138952999999994, 0.0)
line Vector (235.51919, -54.138952999999994, 0.0) Vector (242.29884, -58.167441999999994, 0.0)
line Vector (242.29884, -58.167441999999994, 0.0) Vector (246.91686, -61.409882999999994, 0.0)
line Vector (246.91686, -61.409882999999994, 0.0) Vector (267.9436, -48.440115999999996, 0.0)
line Vector (267.9436, -48.440115999999996, 0.0) Vector (290.34593, -70.940697, 0.0)
line Vector (290.34593, -70.940697, 0.0) Vector (277.37616, -92.16395299999999, 0.0)
line Vector (277.37616, -92.16395299999999, 0.0) Vector (283.36977, -101.59651, 0.0)
line Vector (283.36977, -101.59651, 0.0) Vector (287.3, -108.67093, 0.0)
line Vector (287.3, -108.67093, 0.0) Vector (290.34593, -115.8436, 0.0)
line Vector (290.34593, -115.8436, 0.0) Vector (292.21279, -120.16686, 0.0)
line Vector (292.21279, -120.16686, 0.0) Vector (316.48197999999996, -119.97035, 0.0)
line Vector (316.48197999999996, -119.97035, 0.0) Vector (323.45813999999996, -151.90349, 0.0)
line Vector (323.45813999999996, -151.90349, 0.0) Vector (301.15406999999993, -161.82733000000002, 0.0)
line Vector (301.15406999999993, -161.82733000000002, 0.0) Vector (301.2523699999999, -168.80349, 0.0)
line Vector (301.2523699999999, -168.80349, 0.0) Vector (300.9575999999999, -178.82558, 0.0)
line Vector (300.9575999999999, -178.82558, 0.0) Vector (300.1715499999999, -187.27558, 0.0)
line Vector (300.1715499999999, -187.27558, 0.0) Vector (299.18898999999993, -194.15348999999998, 0.0)
line Vector (299.18898999999993, -194.15348999999998, 0.0) Vector (318.8401599999999, -207.02499999999998, 0.0)
line Vector (318.8401599999999, -207.02499999999998, 0.0) Vector (308.03201999999993, -237.87732999999997, 0.0)
line Vector (308.03201999999993, -237.87732999999997, 0.0) Vector (283.3698099999999, -234.63487999999998, 0.0)
line Vector (283.3698099999999, -234.63487999999998, 0.0) Vector (279.0465499999999, -241.90580999999997, 0.0)
line Vector (279.0465499999999, -241.90580999999997, 0.0) Vector (275.4110899999999, -247.50639999999999, 0.0)
line Vector (275.4110899999999, -247.50639999999999, 0.0) Vector (269.1226699999999, -255.2686, 0.0)
line Vector (269.1226699999999, -255.2686, 0.0) Vector (264.5046499999999, -260.27965, 0.0)
line Vector (264.5046499999999, -260.27965, 0.0) Vector (273.24941999999993, -279.83256, 0.0)
line Vector (273.24941999999993, -279.83256, 0.0) Vector (273.83894999999995, -281.50291, 0.0)
line Vector (273.83894999999995, -281.50291, 0.0) Vector (274.13372, -282.78022999999996, 0.0)
line Vector (274.13372, -282.78022999999996, 0.0) Vector (248.68546999999998, -301.54708999999997, 0.0)
line Vector (248.68546999999998, -301.54708999999997, 0.0) Vector (229.91859999999997, -285.62964999999997, 0.0)
line Vector (229.91859999999997, -285.62964999999997, 0.0) Vector (220.78080999999997, -289.95291, 0.0)
line Vector (220.78080999999997, -289.95291, 0.0) Vector (214.68894999999998, -292.21279, 0.0)
line Vector (214.68894999999998, -292.21279, 0.0) Vector (206.14069999999998, -295.16047, 0.0)
line Vector (206.14069999999998, -295.16047, 0.0) Vector (199.55755999999997, -296.6343, 0.0)
line Vector (199.55755999999997, -296.6343, 0.0) Vector (196.41336999999996, -319.82267, 0.0)
line Vector (196.41336999999996, -319.82267, 0.0) Vector (196.11859999999996, -321.59128000000004, 0.0)
line Vector (196.11859999999996, -321.59128000000004, 0.0) Vector (164.38197999999997, -324.14593, 0.0)
line Vector (164.38197999999997, -324.14593, 0.0) Vector (156.71801999999997, -299.975, 0.0)
line Vector (156.71801999999997, -299.975, 0.0) Vector (145.71336999999997, -298.50116, 0.0)
line Vector (145.71336999999997, -298.50116, 0.0) Vector (136.37906999999996, -296.53605000000005, 0.0)
line Vector (136.37906999999996, -296.53605000000005, 0.0) Vector (125.66918999999996, -292.80233000000004, 0.0)
line Vector (125.66918999999996, -292.80233000000004, 0.0) Vector (109.65348999999996, -311.37267, 0.0)
line Vector (109.65348999999996, -311.37267, 0.0) Vector (80.76627899999997, -294.76744, 0.0)
line Vector (80.76627899999997, -294.76744, 0.0) Vector (87.34941899999997, -271.87384000000003, 0.0)
line Vector (87.34941899999997, -271.87384000000003, 0.0) Vector (81.35581399999997, -267.25581000000005, 0.0)
line Vector (81.35581399999997, -267.25581000000005, 0.0) Vector (72.80755799999997, -258.70756000000006, 0.0)
line Vector (72.80755799999997, -258.70756000000006, 0.0) Vector (64.75058099999997, -249.37326000000004, 0.0)
line Vector (64.75058099999997, -249.37326000000004, 0.0) Vector (42.348255999999964, -255.75988000000004, 0.0)
line Vector (42.348255999999964, -255.75988000000004, 0.0) Vector (40.57965099999996, -256.15291, 0.0)
line Vector (40.57965099999996, -256.15291, 0.0) Vector (26.725580999999963, -229.32907000000003, 0.0)
line Vector (26.725580999999963, -229.32907000000003, 0.0) Vector (25.546511999999964, -226.67616000000004, 0.0)
line Vector (25.546511999999964, -226.67616000000004, 0.0) Vector (44.804650999999964, -211.34826000000004, 0.0)
line Vector (44.804650999999964, -211.34826000000004, 0.0) Vector (41.07092999999996, -198.47674000000004, 0.0)
line Vector (41.07092999999996, -198.47674000000004, 0.0) Vector (38.12325599999996, -184.72093000000004, 0.0)
line Vector (38.12325599999996, -184.72093000000004, 0.0) Vector (37.73023299999996, -180.10291000000004, 0.0)
line Vector (37.73023299999996, -180.10291000000004, 0.0) Vector (14.148836999999961, -173.32326000000003, 0.0)
line Vector (14.148836999999961, -173.32326000000003, 0.0) Vector (16.899999999999963, -140.50581000000003, 0.0)
line Vector (16.899999999999963, -140.50581000000003, 0.0) Vector (40.67790699999996, -136.57558000000003, 0.0)
line Vector (40.67790699999996, -136.57558000000003, 0.0) Vector (44.21511599999996, -126.65174000000003, 0.0)
line Vector (44.21511599999996, -126.65174000000003, 0.0) Vector (49.02965099999996, -114.36977000000003, 0.0)
applying group transform: Matrix ((29.5858,0,0,0),(0,29.5858,0,0),(0,0,1,0),(0,0,0,1))
done processing element 11
processing element 12: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'110.34128', u'110.93081', u'7.95872', u'-6.97616', u'11.49593', u'-7.565697', u'11.7907', u'-5.305814', u'12.28197', u'-3.144186', u'10.61163', u'-1.277325', u'15.03314', u'0.491279', u'12.18372', u'2.259883', u'13.95233', u'5.207559', u'11.10291', u'6.681391', u'10.51337', u'9.03954', u'6.48488', u'7.27093', u'6.97616', u'10.51337', u'5.20756', u'10.70988', u'3.63547', u'11.00466', u'1.96511', u'14.05058', u'-0.29476', u'15.81918', u'-1.37558', u'6.38663', u'-4.61803', u'14.93489', u'-4.91279', u'9.72732', u'-6.58314', u'9.13779', u'-6.19011', u'7.5657', u'-8.35175', u'7.27093', u'-9.3343', u'5.9936', u'-7.86047', u'3.73373', u'-9.43255', u'3.5372', u'-6.77966', u'1.86686', u'-12.18372', u'1.27733', u'-10.2186', u'0.0983', u'-9.82558', u'-1.47384', u'-9.03954', u'-2.06337', u'-10.31686', u'-3.93024', u'-10.02209', u'-5.50232', u'-9.23605', u'-6.77965', u'-9.3343', u'-9.23605', u'-8.548256', u'-13.06802', u'-6.09186', u'-14.14884', u'-3.144186', u'-14.34535', u'-1.572093', u'-13.16628', u'1.375581', u'-14.14883', u'2.652907', u'-9.1378', u'4.618023', u'-10.80813', u'5.011047', u'-9.23605', u'5.109307', u'-7.66395', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4198'], u'fill': u'none'}
move Vector (110.34128, -110.93081, 0.0)
line Vector (110.34128, -110.93081, 0.0) Vector (118.3, -103.95464999999999, 0.0)
line Vector (118.3, -103.95464999999999, 0.0) Vector (129.79593, -96.38895299999999, 0.0)
line Vector (129.79593, -96.38895299999999, 0.0) Vector (141.58662999999999, -91.08313899999999, 0.0)
line Vector (141.58662999999999, -91.08313899999999, 0.0) Vector (153.8686, -87.93895299999998, 0.0)
line Vector (153.8686, -87.93895299999998, 0.0) Vector (164.48022999999998, -86.66162799999998, 0.0)
line Vector (164.48022999999998, -86.66162799999998, 0.0) Vector (179.51336999999998, -87.15290699999998, 0.0)
line Vector (179.51336999999998, -87.15290699999998, 0.0) Vector (191.69708999999997, -89.41278999999999, 0.0)
line Vector (191.69708999999997, -89.41278999999999, 0.0) Vector (205.64941999999996, -94.62034899999999, 0.0)
line Vector (205.64941999999996, -94.62034899999999, 0.0) Vector (216.75232999999997, -101.30174, 0.0)
line Vector (216.75232999999997, -101.30174, 0.0) Vector (227.26569999999998, -110.34128, 0.0)
line Vector (227.26569999999998, -110.34128, 0.0) Vector (233.75057999999999, -117.61221, 0.0)
line Vector (233.75057999999999, -117.61221, 0.0) Vector (240.72673999999998, -128.12558, 0.0)
line Vector (240.72673999999998, -128.12558, 0.0) Vector (245.93429999999998, -138.83546, 0.0)
line Vector (245.93429999999998, -138.83546, 0.0) Vector (249.56976999999998, -149.84012, 0.0)
line Vector (249.56976999999998, -149.84012, 0.0) Vector (251.53488, -163.8907, 0.0)
line Vector (251.53488, -163.8907, 0.0) Vector (251.24012, -179.70988, 0.0)
line Vector (251.24012, -179.70988, 0.0) Vector (249.86453999999998, -186.09651, 0.0)
line Vector (249.86453999999998, -186.09651, 0.0) Vector (245.24650999999997, -201.0314, 0.0)
line Vector (245.24650999999997, -201.0314, 0.0) Vector (240.33371999999997, -210.75871999999998, 0.0)
line Vector (240.33371999999997, -210.75871999999998, 0.0) Vector (233.75057999999996, -219.89650999999998, 0.0)
line Vector (233.75057999999996, -219.89650999999998, 0.0) Vector (227.56046999999995, -227.46220999999997, 0.0)
line Vector (227.56046999999995, -227.46220999999997, 0.0) Vector (219.20871999999994, -234.73313999999996, 0.0)
line Vector (219.20871999999994, -234.73313999999996, 0.0) Vector (209.87441999999993, -240.72673999999995, 0.0)
line Vector (209.87441999999993, -240.72673999999995, 0.0) Vector (202.01394999999994, -244.46046999999996, 0.0)
line Vector (202.01394999999994, -244.46046999999996, 0.0) Vector (192.58139999999995, -247.99766999999997, 0.0)
line Vector (192.58139999999995, -247.99766999999997, 0.0) Vector (185.80173999999994, -249.86452999999997, 0.0)
line Vector (185.80173999999994, -249.86452999999997, 0.0) Vector (173.61801999999994, -251.14185999999998, 0.0)
line Vector (173.61801999999994, -251.14185999999998, 0.0) Vector (163.39941999999994, -251.24015999999997, 0.0)
line Vector (163.39941999999994, -251.24015999999997, 0.0) Vector (153.57383999999993, -249.76631999999998, 0.0)
line Vector (153.57383999999993, -249.76631999999998, 0.0) Vector (144.53429999999994, -247.70295, 0.0)
line Vector (144.53429999999994, -247.70295, 0.0) Vector (134.21743999999995, -243.77271, 0.0)
line Vector (134.21743999999995, -243.77271, 0.0) Vector (124.19534999999995, -238.27039, 0.0)
line Vector (124.19534999999995, -238.27039, 0.0) Vector (114.95929999999994, -231.49074, 0.0)
line Vector (114.95929999999994, -231.49074, 0.0) Vector (105.62499999999994, -222.25468999999998, 0.0)
line Vector (105.62499999999994, -222.25468999999998, 0.0) Vector (97.07674399999995, -209.18667, 0.0)
line Vector (97.07674399999995, -209.18667, 0.0) Vector (90.98488399999995, -195.03782999999999, 0.0)
line Vector (90.98488399999995, -195.03782999999999, 0.0) Vector (87.84069799999995, -180.69248, 0.0)
line Vector (87.84069799999995, -180.69248, 0.0) Vector (86.26860499999995, -167.5262, 0.0)
line Vector (86.26860499999995, -167.5262, 0.0) Vector (87.64418599999995, -153.37736999999998, 0.0)
line Vector (87.64418599999995, -153.37736999999998, 0.0) Vector (90.29709299999995, -144.23957, 0.0)
line Vector (90.29709299999995, -144.23957, 0.0) Vector (94.91511599999994, -133.43143999999998, 0.0)
line Vector (94.91511599999994, -133.43143999999998, 0.0) Vector (99.92616299999995, -124.19538999999997, 0.0)
line Vector (99.92616299999995, -124.19538999999997, 0.0) Vector (105.03546999999995, -116.53143999999998, 0.0)
done processing element 12
processing element 13: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'81.496934', u'146.10355', u'3.612823', u'-11.0469', u'5.558188', u'-11.18585', u'5.836098', u'-9.5184', u'9.587877', u'-10.07421', u'9.58787', u'-8.406763', u'7.15617', u'-4.654983', u'8.19833', u'-4.72446', u'12.92278', u'-4.654982', u'11.46377', u'-2.848572', u'13.27017', u'-0.903205', u'14.24286', u'1.111637', u'9.30996', u'1.736934', u'9.17101', u'2.848571', u'9.86579', u'4.307596', u'10.4216', u'6.669826', u'6.94774', u'5.280281', u'8.12885', u'7.92042', u'6.32244', u'8.05937', u'6.53087', u'10.4216', u'5.00237', u'11.88063', u'3.61282', u'11.74167', u'1.38955', u'14.79868', u'-0.48635', u'14.93763', u'-2.84857', u'13.82599', u'-4.44655', u'11.60272', u'-4.86341', u'9.79631', u'-6.4614', u'9.24048', u'-8.19832', u'8.96258', u'-8.54572', u'7.43408', u'-10.76899', u'6.60035', u'-11.81115', u'5.55819', u'-13.68704', u'4.23811', u'-9.44892', u'1.32007', u'-16.74404', u'0.34739', u'-17.09143', u'-3.12648', u'-14.03442', u'-5.41923', u'-13.2007', u'-8.05938', u'-9.79631', u'-8.19832', u'-9.032051', u'-10.21317', u'-6.947735', u'-9.72683', u'-4.168641', u'-9.37945', u'-5.00237', u'-13.40913', u'-1.597979', u'-9.03205', u'-1.806411', u'-10.28265', u'0.694773', u'-12.99226', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4219'], u'fill': u'none'}
move Vector (81.496934, -146.10355, 0.0)
line Vector (81.496934, -146.10355, 0.0) Vector (85.109757, -135.05665000000002, 0.0)
line Vector (85.109757, -135.05665000000002, 0.0) Vector (90.667945, -123.87080000000002, 0.0)
line Vector (90.667945, -123.87080000000002, 0.0) Vector (96.504043, -114.35240000000002, 0.0)
line Vector (96.504043, -114.35240000000002, 0.0) Vector (106.09192, -104.27819000000002, 0.0)
line Vector (106.09192, -104.27819000000002, 0.0) Vector (115.67979, -95.87142700000003, 0.0)
line Vector (115.67979, -95.87142700000003, 0.0) Vector (122.83596, -91.21644400000002, 0.0)
line Vector (122.83596, -91.21644400000002, 0.0) Vector (131.03429, -86.49198400000003, 0.0)
line Vector (131.03429, -86.49198400000003, 0.0) Vector (143.95707, -81.83700200000003, 0.0)
line Vector (143.95707, -81.83700200000003, 0.0) Vector (155.42084, -78.98843000000002, 0.0)
line Vector (155.42084, -78.98843000000002, 0.0) Vector (168.69101, -78.08522500000002, 0.0)
line Vector (168.69101, -78.08522500000002, 0.0) Vector (182.93387, -79.19686200000002, 0.0)
line Vector (182.93387, -79.19686200000002, 0.0) Vector (192.24383, -80.93379600000003, 0.0)
line Vector (192.24383, -80.93379600000003, 0.0) Vector (201.41484, -83.78236700000004, 0.0)
line Vector (201.41484, -83.78236700000004, 0.0) Vector (211.28063, -88.08996300000004, 0.0)
line Vector (211.28063, -88.08996300000004, 0.0) Vector (221.70223000000001, -94.75978900000004, 0.0)
line Vector (221.70223000000001, -94.75978900000004, 0.0) Vector (228.64997000000002, -100.04007000000004, 0.0)
line Vector (228.64997000000002, -100.04007000000004, 0.0) Vector (236.77882000000002, -107.96049000000005, 0.0)
line Vector (236.77882000000002, -107.96049000000005, 0.0) Vector (243.10126000000002, -116.01986000000005, 0.0)
line Vector (243.10126000000002, -116.01986000000005, 0.0) Vector (249.63213000000002, -126.44146000000005, 0.0)
line Vector (249.63213000000002, -126.44146000000005, 0.0) Vector (254.63450000000003, -138.32209000000006, 0.0)
line Vector (254.63450000000003, -138.32209000000006, 0.0) Vector (258.24732000000006, -150.06376000000006, 0.0)
line Vector (258.24732000000006, -150.06376000000006, 0.0) Vector (259.63687000000004, -164.86244000000005, 0.0)
line Vector (259.63687000000004, -164.86244000000005, 0.0) Vector (259.15052000000003, -179.80007000000006, 0.0)
line Vector (259.15052000000003, -179.80007000000006, 0.0) Vector (256.30195000000003, -193.62606000000005, 0.0)
line Vector (256.30195000000003, -193.62606000000005, 0.0) Vector (251.85540000000003, -205.22878000000006, 0.0)
line Vector (251.85540000000003, -205.22878000000006, 0.0) Vector (246.99199000000004, -215.02509000000006, 0.0)
line Vector (246.99199000000004, -215.02509000000006, 0.0) Vector (240.53059000000005, -224.26557000000005, 0.0)
line Vector (240.53059000000005, -224.26557000000005, 0.0) Vector (232.33227000000005, -233.22815000000006, 0.0)
line Vector (232.33227000000005, -233.22815000000006, 0.0) Vector (223.78655000000006, -240.66223000000005, 0.0)
line Vector (223.78655000000006, -240.66223000000005, 0.0) Vector (213.01756000000006, -247.26258000000004, 0.0)
line Vector (213.01756000000006, -247.26258000000004, 0.0) Vector (201.20641000000006, -252.82077000000004, 0.0)
line Vector (201.20641000000006, -252.82077000000004, 0.0) Vector (187.51937000000007, -257.05888000000004, 0.0)
line Vector (187.51937000000007, -257.05888000000004, 0.0) Vector (178.07045000000008, -258.37895000000003, 0.0)
line Vector (178.07045000000008, -258.37895000000003, 0.0) Vector (161.32641000000007, -258.72634000000005, 0.0)
line Vector (161.32641000000007, -258.72634000000005, 0.0) Vector (144.23498000000006, -255.59986000000006, 0.0)
line Vector (144.23498000000006, -255.59986000000006, 0.0) Vector (130.20056000000005, -250.18063000000006, 0.0)
line Vector (130.20056000000005, -250.18063000000006, 0.0) Vector (116.99986000000006, -242.12125000000006, 0.0)
line Vector (116.99986000000006, -242.12125000000006, 0.0) Vector (107.20355000000005, -233.92293000000006, 0.0)
line Vector (107.20355000000005, -233.92293000000006, 0.0) Vector (98.17149900000005, -223.70976000000007, 0.0)
line Vector (98.17149900000005, -223.70976000000007, 0.0) Vector (91.22376400000006, -213.98293000000007, 0.0)
line Vector (91.22376400000006, -213.98293000000007, 0.0) Vector (87.05512300000007, -204.60348000000008, 0.0)
line Vector (87.05512300000007, -204.60348000000008, 0.0) Vector (82.05275300000007, -191.19435000000007, 0.0)
line Vector (82.05275300000007, -191.19435000000007, 0.0) Vector (80.45477400000007, -182.16230000000007, 0.0)
line Vector (80.45477400000007, -182.16230000000007, 0.0) Vector (78.64836300000007, -171.87965000000008, 0.0)
line Vector (78.64836300000007, -171.87965000000008, 0.0) Vector (79.34313600000007, -158.8873900000001, 0.0)
done processing element 13
processing element 14: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'116.09666', u'125.88564', u'42.937', u'42.86753', u'-43.35387', u'43.35387', u'-2.70961', u'-3.54335', u'-3.54335', u'-5.8361', u'-3.26544', u'-5.97505', u'-2.77909', u'-8.47623', u'-2.36223', u'-8.47624', u'-0.0695', u'-12.92279', u'0.27791', u'-10.21317', u'4.16864', u'-12.5754', u'5.48871', u'-11.11638', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4221'], u'fill': u'none'}
move Vector (116.09666, -125.88564, 0.0)
line Vector (116.09666, -125.88564, 0.0) Vector (159.03366, -168.75317, 0.0)
line Vector (159.03366, -168.75317, 0.0) Vector (115.67979, -212.10704, 0.0)
line Vector (115.67979, -212.10704, 0.0) Vector (112.97018, -208.56369, 0.0)
line Vector (112.97018, -208.56369, 0.0) Vector (109.42683, -202.72759000000002, 0.0)
line Vector (109.42683, -202.72759000000002, 0.0) Vector (106.16139, -196.75254, 0.0)
line Vector (106.16139, -196.75254, 0.0) Vector (103.3823, -188.27631000000002, 0.0)
line Vector (103.3823, -188.27631000000002, 0.0) Vector (101.02007, -179.80007000000003, 0.0)
line Vector (101.02007, -179.80007000000003, 0.0) Vector (100.95057, -166.87728000000004, 0.0)
line Vector (100.95057, -166.87728000000004, 0.0) Vector (101.22848, -156.66411000000005, 0.0)
line Vector (101.22848, -156.66411000000005, 0.0) Vector (105.39712, -144.08871000000005, 0.0)
line Vector (105.39712, -144.08871000000005, 0.0) Vector (110.88583, -132.97233000000006, 0.0)
done processing element 14
processing element 15: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'110.53847', u'151.45331', u'7.08669', u'-0.27791', u'7.43407', u'21.67693', u'-0.20843', u'-21.67693', u'6.66983', u'0.13895', u'0', u'17.29986', u'2.64014', u'2.01485', u'-2.36223', u'1.87589', u'-0.48634', u'17.57777', u'-6.53088', u'-0.0695', u'-7.36459', u'-20.98216', u'0.0695', u'20.63477', u'-7.22564', u'-0.13895', u'0.41686', u'-16.74404', u'-2.91805', u'-2.29276', u'2.98753', u'-1.87589', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4223'], u'fill': u'none'}
move Vector (110.53847, -151.45331, 0.0)
line Vector (110.53847, -151.45331, 0.0) Vector (117.62516000000001, -151.1754, 0.0)
line Vector (117.62516000000001, -151.1754, 0.0) Vector (125.05923000000001, -172.85233, 0.0)
line Vector (125.05923000000001, -172.85233, 0.0) Vector (124.8508, -151.1754, 0.0)
line Vector (124.8508, -151.1754, 0.0) Vector (131.52063, -151.31435, 0.0)
line Vector (131.52063, -151.31435, 0.0) Vector (131.52063, -168.61420999999999, 0.0)
line Vector (131.52063, -168.61420999999999, 0.0) Vector (134.16077, -170.62905999999998, 0.0)
line Vector (134.16077, -170.62905999999998, 0.0) Vector (131.79854, -172.50494999999998, 0.0)
line Vector (131.79854, -172.50494999999998, 0.0) Vector (131.3122, -190.08272, 0.0)
line Vector (131.3122, -190.08272, 0.0) Vector (124.78132, -190.01322, 0.0)
line Vector (124.78132, -190.01322, 0.0) Vector (117.41673, -169.03106, 0.0)
line Vector (117.41673, -169.03106, 0.0) Vector (117.48623, -189.66583, 0.0)
line Vector (117.48623, -189.66583, 0.0) Vector (110.26059000000001, -189.52688, 0.0)
line Vector (110.26059000000001, -189.52688, 0.0) Vector (110.67745000000001, -172.78284000000002, 0.0)
line Vector (110.67745000000001, -172.78284000000002, 0.0) Vector (107.75940000000001, -170.49008000000003, 0.0)
line Vector (107.75940000000001, -170.49008000000003, 0.0) Vector (110.74693000000002, -168.61419000000004, 0.0)
done processing element 15
processing element 16: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'126.03192', u'221.83387', u'42.79805', u'-43.21492', u'43.42334', u'43.5623', u'-5.8361', u'4.16864', u'-6.53087', u'3.54335', u'-6.87825', u'3.12648', u'-8.6152', u'2.64014', u'-7.3646', u'1.32007', u'-8.47623', u'0.48634', u'-13.96495', u'-0.83373', u'-11.18585', u'-4.02968', u'-9.58788', u'-4.3076', u'-7.22564', u'-5.28028', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4225'], u'fill': u'none'}
move Vector (126.03192, -221.83387, 0.0)
line Vector (126.03192, -221.83387, 0.0) Vector (168.82997, -178.61894999999998, 0.0)
line Vector (168.82997, -178.61894999999998, 0.0) Vector (212.25331, -222.18124999999998, 0.0)
line Vector (212.25331, -222.18124999999998, 0.0) Vector (206.41721, -226.34989, 0.0)
line Vector (206.41721, -226.34989, 0.0) Vector (199.88634000000002, -229.89324, 0.0)
line Vector (199.88634000000002, -229.89324, 0.0) Vector (193.00809, -233.01971999999998, 0.0)
line Vector (193.00809, -233.01971999999998, 0.0) Vector (184.39289000000002, -235.65985999999998, 0.0)
line Vector (184.39289000000002, -235.65985999999998, 0.0) Vector (177.02829000000003, -236.97992999999997, 0.0)
line Vector (177.02829000000003, -236.97992999999997, 0.0) Vector (168.55206000000004, -237.46626999999998, 0.0)
line Vector (168.55206000000004, -237.46626999999998, 0.0) Vector (154.58711000000005, -236.63253999999998, 0.0)
line Vector (154.58711000000005, -236.63253999999998, 0.0) Vector (143.40126000000006, -232.60285999999996, 0.0)
line Vector (143.40126000000006, -232.60285999999996, 0.0) Vector (133.81338000000005, -228.29525999999996, 0.0)
line Vector (133.81338000000005, -228.29525999999996, 0.0) Vector (126.58774000000005, -223.01497999999995, 0.0)
done processing element 16
processing element 17: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'157.92202', u'208.35526', u'0.34739', u'-10.83847', u'2.08432', u'-3.96021', u'3.057', u'-2.22327', u'3.47387', u'-0.48634', u'4.09916', u'0.48634', u'3.26544', u'1.18111', u'2.70962', u'4.51603', u'0.34738', u'2.08432', u'0.0695', u'9.37945', u'3.19596', u'2.64013', u'-3.26544', u'2.43171', u'-0.13895', u'12.36697', u'0.62529', u'1.38955', u'0.13896', u'5.48871', u'-2.70962', u'0.13895', u'-2.50118', u'-1.59798', u'-1.45903', u'-0.34738', u'-6.53087', u'-0.0695', u'-3.057', u'-1.66746', u'-2.36223', u'-2.77909', u'-1.04216', u'-3.057', u'-0.41687', u'-9.93527', u'-2.91804', u'-2.4317', u'3.057', u'-2.1538', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4227'], u'fill': u'none'}
move Vector (157.92202, -208.35526, 0.0)
line Vector (157.92202, -208.35526, 0.0) Vector (158.26941, -197.51679, 0.0)
line Vector (158.26941, -197.51679, 0.0) Vector (160.35372999999998, -193.55658, 0.0)
line Vector (160.35372999999998, -193.55658, 0.0) Vector (163.41072999999997, -191.33330999999998, 0.0)
line Vector (163.41072999999997, -191.33330999999998, 0.0) Vector (166.88459999999998, -190.84696999999997, 0.0)
line Vector (166.88459999999998, -190.84696999999997, 0.0) Vector (170.98376, -191.33330999999998, 0.0)
line Vector (170.98376, -191.33330999999998, 0.0) Vector (174.2492, -192.51441999999997, 0.0)
line Vector (174.2492, -192.51441999999997, 0.0) Vector (176.95882, -197.03044999999997, 0.0)
line Vector (176.95882, -197.03044999999997, 0.0) Vector (177.3062, -199.11476999999996, 0.0)
line Vector (177.3062, -199.11476999999996, 0.0) Vector (177.3757, -208.49421999999996, 0.0)
line Vector (177.3757, -208.49421999999996, 0.0) Vector (180.57166, -211.13434999999996, 0.0)
line Vector (180.57166, -211.13434999999996, 0.0) Vector (177.30622, -213.56605999999996, 0.0)
line Vector (177.30622, -213.56605999999996, 0.0) Vector (177.16727, -225.93302999999997, 0.0)
line Vector (177.16727, -225.93302999999997, 0.0) Vector (177.79256, -227.32258, 0.0)
line Vector (177.79256, -227.32258, 0.0) Vector (177.93152, -232.81128999999999, 0.0)
line Vector (177.93152, -232.81128999999999, 0.0) Vector (175.2219, -232.95023999999998, 0.0)
line Vector (175.2219, -232.95023999999998, 0.0) Vector (172.72072, -231.35225999999997, 0.0)
line Vector (172.72072, -231.35225999999997, 0.0) Vector (171.26169, -231.00487999999999, 0.0)
line Vector (171.26169, -231.00487999999999, 0.0) Vector (164.73082, -230.93537999999998, 0.0)
line Vector (164.73082, -230.93537999999998, 0.0) Vector (161.67382, -229.26791999999998, 0.0)
line Vector (161.67382, -229.26791999999998, 0.0) Vector (159.31159, -226.48882999999998, 0.0)
line Vector (159.31159, -226.48882999999998, 0.0) Vector (158.26943, -223.43183, 0.0)
line Vector (158.26943, -223.43183, 0.0) Vector (157.85256, -213.49656, 0.0)
line Vector (157.85256, -213.49656, 0.0) Vector (154.93452000000002, -211.06485999999998, 0.0)
line Vector (154.93452000000002, -211.06485999999998, 0.0) Vector (157.99152, -208.91106, 0.0)
done processing element 17
processing element 18: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'164.24446', u'200.22641', u'0.20843', u'21.81589', u'0.55582', u'1.73693', u'1.59798', u'1.04216', u'1.32007', u'0.27791', u'1.59798', u'-0.34738', u'1.11164', u'-1.52851', u'0.20843', u'-0.9032', u'-0.13896', u'-22.37171', u'-0.97268', u'-1.45902', u'-1.38955', u'-0.55582', u'-1.87588', u'-0.27791', u'-1.18112', u'0.62529', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4229'], u'fill': u'none'}
move Vector (164.24446, -200.22641, 0.0)
line Vector (164.24446, -200.22641, 0.0) Vector (164.45289, -222.04229999999998, 0.0)
line Vector (164.45289, -222.04229999999998, 0.0) Vector (165.00871, -223.77922999999998, 0.0)
line Vector (165.00871, -223.77922999999998, 0.0) Vector (166.60669000000001, -224.82138999999998, 0.0)
line Vector (166.60669000000001, -224.82138999999998, 0.0) Vector (167.92676, -225.09929999999997, 0.0)
line Vector (167.92676, -225.09929999999997, 0.0) Vector (169.52474, -224.75191999999998, 0.0)
line Vector (169.52474, -224.75191999999998, 0.0) Vector (170.63638, -223.22340999999997, 0.0)
line Vector (170.63638, -223.22340999999997, 0.0) Vector (170.84481, -222.32020999999997, 0.0)
line Vector (170.84481, -222.32020999999997, 0.0) Vector (170.70585, -199.94849999999997, 0.0)
line Vector (170.70585, -199.94849999999997, 0.0) Vector (169.73317, -198.48947999999996, 0.0)
line Vector (169.73317, -198.48947999999996, 0.0) Vector (168.34362, -197.93365999999995, 0.0)
line Vector (168.34362, -197.93365999999995, 0.0) Vector (166.46774, -197.65574999999995, 0.0)
line Vector (166.46774, -197.65574999999995, 0.0) Vector (165.28662, -198.28103999999996, 0.0)
done processing element 18
processing element 19: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'M', u'125.96395', u'115.8436', u'169', u'159.17442', u'l', u'43.33081', u'-43.52733', u'-7.66395', u'-5.69883', u'-11.39767', u'-5.50233', u'-10.80814', u'-3.14419', u'-13.16628', u'-1.375577', u'-11.98721', u'1.080817', u'-11.20116', u'2.75116', u'-11.10291', u'5.50232', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4231'], u'fill': u'none'}
move Vector (125.96395, -115.8436, 0.0)
line Vector (125.96395, -115.8436, 0.0) Vector (169.0, -159.17442, 0.0)
line Vector (169.0, -159.17442, 0.0) Vector (212.33080999999999, -115.64708999999999, 0.0)
line Vector (212.33080999999999, -115.64708999999999, 0.0) Vector (204.66685999999999, -109.94825999999999, 0.0)
line Vector (204.66685999999999, -109.94825999999999, 0.0) Vector (193.26918999999998, -104.44592999999999, 0.0)
line Vector (193.26918999999998, -104.44592999999999, 0.0) Vector (182.46104999999997, -101.30174, 0.0)
line Vector (182.46104999999997, -101.30174, 0.0) Vector (169.29476999999997, -99.92616299999999, 0.0)
line Vector (169.29476999999997, -99.92616299999999, 0.0) Vector (157.30755999999997, -101.00697999999998, 0.0)
line Vector (157.30755999999997, -101.00697999999998, 0.0) Vector (146.10639999999998, -103.75813999999998, 0.0)
line Vector (146.10639999999998, -103.75813999999998, 0.0) Vector (135.00348999999997, -109.26045999999998, 0.0)
done processing element 19
processing element 20: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'160.15698', u'106.60756', u'-0.0983', u'16.70349', u'-2.94767', u'2.55465', u'2.84942', u'2.06337', u'0.19651', u'16.9', u'17.88256', u'0.19651', u'-0.0983', u'-6.77965', u'-10.21861', u'-0.0983', u'-0.78604', u'0', u'0.0982', u'-9.3343', u'8.05698', u'-0.68779', u'-0.29477', u'-6.19012', u'-7.76221', u'-0.0983', u'-0.19651', u'-9.72733', u'11.59419', u'-0.19651', u'0.0983', u'-6.28837', u'-18.47209', u'0.0983', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4233'], u'fill': u'none'}
move Vector (160.15698, -106.60756, 0.0)
line Vector (160.15698, -106.60756, 0.0) Vector (160.05868, -123.31105000000001, 0.0)
line Vector (160.05868, -123.31105000000001, 0.0) Vector (157.11101000000002, -125.8657, 0.0)
line Vector (157.11101000000002, -125.8657, 0.0) Vector (159.96043000000003, -127.92907000000001, 0.0)
line Vector (159.96043000000003, -127.92907000000001, 0.0) Vector (160.15694000000002, -144.82907, 0.0)
line Vector (160.15694000000002, -144.82907, 0.0) Vector (178.03950000000003, -145.02558, 0.0)
line Vector (178.03950000000003, -145.02558, 0.0) Vector (177.94120000000004, -138.24593, 0.0)
line Vector (177.94120000000004, -138.24593, 0.0) Vector (167.72259000000003, -138.14763, 0.0)
line Vector (167.72259000000003, -138.14763, 0.0) Vector (166.93655, -138.14763, 0.0)
line Vector (166.93655, -138.14763, 0.0) Vector (167.03475, -128.81332999999998, 0.0)
line Vector (167.03475, -128.81332999999998, 0.0) Vector (175.09173, -128.12553999999997, 0.0)
line Vector (175.09173, -128.12553999999997, 0.0) Vector (174.79696, -121.93541999999997, 0.0)
line Vector (174.79696, -121.93541999999997, 0.0) Vector (167.03475, -121.83711999999997, 0.0)
line Vector (167.03475, -121.83711999999997, 0.0) Vector (166.83824, -112.10978999999998, 0.0)
line Vector (166.83824, -112.10978999999998, 0.0) Vector (178.43243, -111.91327999999997, 0.0)
line Vector (178.43243, -111.91327999999997, 0.0) Vector (178.53073, -105.62490999999997, 0.0)
line Vector (178.53073, -105.62490999999997, 0.0) Vector (160.05864, -105.72320999999997, 0.0)
done processing element 20
processing element 21: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'179.51337', u'168.60698', u'42.64303', u'-43.13431', u'4.225', u'6.09186', u'5.60058', u'10.21861', u'3.14418', u'9.43256', u'2.06338', u'7.86046', u'0.58953', u'10.9064', u'-0.29477', u'9.72732', u'-3.3407', u'12.38024', u'-4.225', u'9.23604', u'-7.27093', u'10.41512', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4235'], u'fill': u'none'}
move Vector (179.51337, -168.60698, 0.0)
line Vector (179.51337, -168.60698, 0.0) Vector (222.15640000000002, -125.47267, 0.0)
line Vector (222.15640000000002, -125.47267, 0.0) Vector (226.3814, -131.56453, 0.0)
line Vector (226.3814, -131.56453, 0.0) Vector (231.98198000000002, -141.78314, 0.0)
line Vector (231.98198000000002, -141.78314, 0.0) Vector (235.12616000000003, -151.2157, 0.0)
line Vector (235.12616000000003, -151.2157, 0.0) Vector (237.18954000000002, -159.07616, 0.0)
line Vector (237.18954000000002, -159.07616, 0.0) Vector (237.77907000000002, -169.98255999999998, 0.0)
line Vector (237.77907000000002, -169.98255999999998, 0.0) Vector (237.48430000000002, -179.70987999999997, 0.0)
line Vector (237.48430000000002, -179.70987999999997, 0.0) Vector (234.14360000000002, -192.09011999999996, 0.0)
line Vector (234.14360000000002, -192.09011999999996, 0.0) Vector (229.91860000000003, -201.32615999999996, 0.0)
line Vector (229.91860000000003, -201.32615999999996, 0.0) Vector (222.64767000000003, -211.74127999999996, 0.0)
done processing element 21
processing element 22: path
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'206.73023', u'189.33895', u'6.6814', u'-16.70349', u'-2.75116', u'-1.96511', u'2.84941', u'-2.16163', u'-6.97616', u'-17.09651', u'7.27093', u'-0.19651', u'4.12675', u'10.41511', u'4.32325', u'-10.61162', u'6.97616', u'-0.0983', u'-6.58314', u'17.98081', u'2.06338', u'1.47384', u'-2.25989', u'2.06337', u'6.6814', u'16.80175', u'-6.97616', u'0', u'-3.83198', u'-9.53082', u'-4.12675', u'10.12035', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'1px', u'id': [u'path4237'], u'fill': u'none'}
move Vector (206.73023, -189.33895, 0.0)
line Vector (206.73023, -189.33895, 0.0) Vector (213.41163, -172.63546000000002, 0.0)
line Vector (213.41163, -172.63546000000002, 0.0) Vector (210.66047, -170.67035, 0.0)
line Vector (210.66047, -170.67035, 0.0) Vector (213.50988, -168.50872, 0.0)
line Vector (213.50988, -168.50872, 0.0) Vector (206.53372000000002, -151.41221000000002, 0.0)
line Vector (206.53372000000002, -151.41221000000002, 0.0) Vector (213.80465, -151.21570000000003, 0.0)
line Vector (213.80465, -151.21570000000003, 0.0) Vector (217.9314, -161.63081000000003, 0.0)
line Vector (217.9314, -161.63081000000003, 0.0) Vector (222.25465, -151.01919000000004, 0.0)
line Vector (222.25465, -151.01919000000004, 0.0) Vector (229.23081, -150.92089000000004, 0.0)
line Vector (229.23081, -150.92089000000004, 0.0) Vector (222.64767, -168.90170000000003, 0.0)
line Vector (222.64767, -168.90170000000003, 0.0) Vector (224.71105, -170.37554000000003, 0.0)
line Vector (224.71105, -170.37554000000003, 0.0) Vector (222.45116, -172.43891000000002, 0.0)
line Vector (222.45116, -172.43891000000002, 0.0) Vector (229.13255999999998, -189.24066000000002, 0.0)
line Vector (229.13255999999998, -189.24066000000002, 0.0) Vector (222.1564, -189.24066000000002, 0.0)
line Vector (222.1564, -189.24066000000002, 0.0) Vector (218.32442, -179.70984, 0.0)
line Vector (218.32442, -179.70984, 0.0) Vector (214.19767000000002, -189.83019000000002, 0.0)
done processing element 22
closing group
distance = 9173.079259462469mm unit distance = 9173,08 mm
solution count: 1
solution 1:
point1 418.6046449704131 -5127.907100591717 0
point2 9569.767455621301 -4494.186094674556 0
DeltaX 9151.162810650887
DeltaY 633.7210059171603
DeltaZ 0
shape type on object1 is: Vertex
shape type on object2 is: Vertex
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'165.33129', u'167.35926', u'-0.47752', u'-0.56595', u'0.56595', u'-0.75756', u'0.68386', u'0.30067', u'0.22108', u'-0.1916', u'0.17391', u'-0.13854', u'0.16212', u'-0.10907', u'0.20634', u'-0.14149', u'-0.0855', u'-0.71333', u'0.89609', u'-0.35667', u'0.42741', u'0.62785', u'0.32425', u'-0.053', u'0.30361', u'-0.0206', u'0.33014', u'0', u'0.30656', u'-0.66323', u'0.9403', u'0.20929', u'0.009', u'0.73397', u'0.31835', u'0.14738', u'0.18865', u'0.10317', u'0.20339', u'0.12086', u'0.13854', u'0.0973', u'0.6308', u'-0.38909', u'0.67207', u'0.67502', u'-0.38909', u'0.63669', u'0.17981', u'0.28298', u'0.1179', u'0.21223', u'0.0914', u'0.21518', u'0.056', u'0.1297', u'0.72807', u'-0.006', u'0.20929', u'0.958', u'-0.66913', u'0.29771', u'0.003', u'0.20929', u'-0.009', u'0.30066', u'-0.0236', u'0.2535', u'-0.0295', u'0.20634', u'0.58954', u'0.38614', u'-0.32425', u'0.92557', u'-0.73986', u'-0.0973', u'-0.1297', u'0.21813', u'-0.10907', u'0.16802', u'-0.18865', u'0.23286', u'-0.13854', u'0.15033', u'0.26234', u'0.58659', u'0.0177', u'0.0501', u'0.009', u'0.0383', u'-0.76344', u'0.56301', u'-0.56301', u'-0.47753', u'-0.27413', u'0.1297', u'-0.18276', u'0.0678', u'-0.25645', u'0.0884', u'-0.19749', u'0.0442', u'-0.0943', u'0.69565', u'-0.009', u'0.0531', u'-0.9521', u'0.0766', u'-0.22992', u'-0.72513', u'-0.33014', u'-0.0442', u'-0.28003', u'-0.0589', u'-0.32129', u'-0.11202', u'-0.48047', u'0.55711', u'-0.86662', u'-0.49815', u'0.19749', u'-0.68681', u'-0.1798', u'-0.13854', u'-0.25645', u'-0.25645', u'-0.24171', u'-0.28003', u'-0.67207', u'0.1916', u'-0.0531', u'0.0118', u'-0.41562', u'-0.80471', u'-0.0354', u'-0.0796', u'0.57774', u'-0.45984', u'-0.11201', u'-0.38614', u'-0.0884', u'-0.41268', u'-0.0118', u'-0.13854', u'-0.70744', u'-0.20339', u'0.0825', u'-0.98452', u'0.71334', u'-0.11791', u'0.10612', u'-0.29771', u'0.14443', u'-0.36846', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4196'], u'fill': u'none'}
move Vector (165.33129, -167.35926, 0.0)
line Vector (165.33129, -167.35926, 0.0) Vector (164.85377, -166.79331000000002, 0.0)
line Vector (164.85377, -166.79331000000002, 0.0) Vector (165.41971999999998, -166.03575, 0.0)
line Vector (165.41971999999998, -166.03575, 0.0) Vector (166.10358, -166.33642, 0.0)
line Vector (166.10358, -166.33642, 0.0) Vector (166.32466, -166.14482, 0.0)
line Vector (166.32466, -166.14482, 0.0) Vector (166.49857, -166.00628, 0.0)
line Vector (166.49857, -166.00628, 0.0) Vector (166.66069, -165.89721, 0.0)
line Vector (166.66069, -165.89721, 0.0) Vector (166.86703, -165.75572, 0.0)
line Vector (166.86703, -165.75572, 0.0) Vector (166.78153, -165.04238999999998, 0.0)
line Vector (166.78153, -165.04238999999998, 0.0) Vector (167.67762, -164.68571999999998, 0.0)
line Vector (167.67762, -164.68571999999998, 0.0) Vector (168.10503, -165.31356999999997, 0.0)
line Vector (168.10503, -165.31356999999997, 0.0) Vector (168.42928, -165.26056999999997, 0.0)
line Vector (168.42928, -165.26056999999997, 0.0) Vector (168.73289, -165.23996999999997, 0.0)
line Vector (168.73289, -165.23996999999997, 0.0) Vector (169.06303, -165.23996999999997, 0.0)
line Vector (169.06303, -165.23996999999997, 0.0) Vector (169.36959, -164.57673999999997, 0.0)
line Vector (169.36959, -164.57673999999997, 0.0) Vector (170.30989, -164.78602999999998, 0.0)
line Vector (170.30989, -164.78602999999998, 0.0) Vector (170.31888999999998, -165.51999999999998, 0.0)
line Vector (170.31888999999998, -165.51999999999998, 0.0) Vector (170.63724, -165.66737999999998, 0.0)
line Vector (170.63724, -165.66737999999998, 0.0) Vector (170.82589, -165.77055, 0.0)
line Vector (170.82589, -165.77055, 0.0) Vector (171.02928, -165.89140999999998, 0.0)
line Vector (171.02928, -165.89140999999998, 0.0) Vector (171.16782, -165.98870999999997, 0.0)
line Vector (171.16782, -165.98870999999997, 0.0) Vector (171.79862, -165.59961999999996, 0.0)
line Vector (171.79862, -165.59961999999996, 0.0) Vector (172.47069, -166.27463999999995, 0.0)
line Vector (172.47069, -166.27463999999995, 0.0) Vector (172.08159999999998, -166.91132999999994, 0.0)
line Vector (172.08159999999998, -166.91132999999994, 0.0) Vector (172.26140999999998, -167.19430999999994, 0.0)
line Vector (172.26140999999998, -167.19430999999994, 0.0) Vector (172.37930999999998, -167.40653999999995, 0.0)
line Vector (172.37930999999998, -167.40653999999995, 0.0) Vector (172.47070999999997, -167.62171999999995, 0.0)
line Vector (172.47070999999997, -167.62171999999995, 0.0) Vector (172.52670999999998, -167.75141999999997, 0.0)
line Vector (172.52670999999998, -167.75141999999997, 0.0) Vector (173.25477999999998, -167.74541999999997, 0.0)
line Vector (173.25477999999998, -167.74541999999997, 0.0) Vector (173.46407, -168.70341999999997, 0.0)
line Vector (173.46407, -168.70341999999997, 0.0) Vector (172.79494, -169.00112999999996, 0.0)
line Vector (172.79494, -169.00112999999996, 0.0) Vector (172.79793999999998, -169.21041999999997, 0.0)
line Vector (172.79793999999998, -169.21041999999997, 0.0) Vector (172.78894, -169.51107999999996, 0.0)
line Vector (172.78894, -169.51107999999996, 0.0) Vector (172.76534, -169.76457999999997, 0.0)
line Vector (172.76534, -169.76457999999997, 0.0) Vector (172.73584, -169.97091999999998, 0.0)
line Vector (172.73584, -169.97091999999998, 0.0) Vector (173.32538, -170.35706, 0.0)
line Vector (173.32538, -170.35706, 0.0) Vector (173.00113, -171.28262999999998, 0.0)
line Vector (173.00113, -171.28262999999998, 0.0) Vector (172.26127, -171.18533, 0.0)
line Vector (172.26127, -171.18533, 0.0) Vector (172.13156999999998, -171.40346, 0.0)
line Vector (172.13156999999998, -171.40346, 0.0) Vector (172.02249999999998, -171.57148, 0.0)
line Vector (172.02249999999998, -171.57148, 0.0) Vector (171.83384999999998, -171.80434, 0.0)
line Vector (171.83384999999998, -171.80434, 0.0) Vector (171.69530999999998, -171.95467, 0.0)
line Vector (171.69530999999998, -171.95467, 0.0) Vector (171.95764999999997, -172.54126, 0.0)
line Vector (171.95764999999997, -172.54126, 0.0) Vector (171.97534999999996, -172.59135999999998, 0.0)
line Vector (171.97534999999996, -172.59135999999998, 0.0) Vector (171.98434999999995, -172.62965999999997, 0.0)
line Vector (171.98434999999995, -172.62965999999997, 0.0) Vector (171.22090999999995, -173.19266999999996, 0.0)
line Vector (171.22090999999995, -173.19266999999996, 0.0) Vector (170.65789999999996, -172.71513999999996, 0.0)
line Vector (170.65789999999996, -172.71513999999996, 0.0) Vector (170.38376999999994, -172.84483999999998, 0.0)
line Vector (170.38376999999994, -172.84483999999998, 0.0) Vector (170.20100999999994, -172.91263999999998, 0.0)
line Vector (170.20100999999994, -172.91263999999998, 0.0) Vector (169.94455999999994, -173.00104, 0.0)
line Vector (169.94455999999994, -173.00104, 0.0) Vector (169.74706999999995, -173.04523999999998, 0.0)
line Vector (169.74706999999995, -173.04523999999998, 0.0) Vector (169.65276999999995, -173.74088999999998, 0.0)
line Vector (169.65276999999995, -173.74088999999998, 0.0) Vector (169.64376999999996, -173.79398999999998, 0.0)
line Vector (169.64376999999996, -173.79398999999998, 0.0) Vector (168.69166999999996, -173.87059, 0.0)
line Vector (168.69166999999996, -173.87059, 0.0) Vector (168.46174999999997, -173.14545999999999, 0.0)
line Vector (168.46174999999997, -173.14545999999999, 0.0) Vector (168.13160999999997, -173.10126, 0.0)
line Vector (168.13160999999997, -173.10126, 0.0) Vector (167.85157999999996, -173.04236, 0.0)
line Vector (167.85157999999996, -173.04236, 0.0) Vector (167.53028999999995, -172.93034, 0.0)
line Vector (167.53028999999995, -172.93034, 0.0) Vector (167.04981999999995, -173.48745, 0.0)
line Vector (167.04981999999995, -173.48745, 0.0) Vector (166.18319999999994, -172.9893, 0.0)
line Vector (166.18319999999994, -172.9893, 0.0) Vector (166.38068999999993, -172.30248999999998, 0.0)
line Vector (166.38068999999993, -172.30248999999998, 0.0) Vector (166.20088999999993, -172.16394999999997, 0.0)
line Vector (166.20088999999993, -172.16394999999997, 0.0) Vector (165.94443999999993, -171.90749999999997, 0.0)
line Vector (165.94443999999993, -171.90749999999997, 0.0) Vector (165.70272999999992, -171.62746999999996, 0.0)
line Vector (165.70272999999992, -171.62746999999996, 0.0) Vector (165.03065999999993, -171.81906999999995, 0.0)
line Vector (165.03065999999993, -171.81906999999995, 0.0) Vector (164.97755999999993, -171.83086999999995, 0.0)
line Vector (164.97755999999993, -171.83086999999995, 0.0) Vector (164.56193999999994, -171.02615999999995, 0.0)
line Vector (164.56193999999994, -171.02615999999995, 0.0) Vector (164.52653999999993, -170.94655999999995, 0.0)
line Vector (164.52653999999993, -170.94655999999995, 0.0) Vector (165.10427999999993, -170.48671999999993, 0.0)
line Vector (165.10427999999993, -170.48671999999993, 0.0) Vector (164.99226999999993, -170.10057999999992, 0.0)
line Vector (164.99226999999993, -170.10057999999992, 0.0) Vector (164.90386999999993, -169.68789999999993, 0.0)
line Vector (164.90386999999993, -169.68789999999993, 0.0) Vector (164.89206999999993, -169.54935999999992, 0.0)
line Vector (164.89206999999993, -169.54935999999992, 0.0) Vector (164.18462999999994, -169.3459699999999, 0.0)
line Vector (164.18462999999994, -169.3459699999999, 0.0) Vector (164.26712999999995, -168.3614499999999, 0.0)
line Vector (164.26712999999995, -168.3614499999999, 0.0) Vector (164.98046999999994, -168.2435399999999, 0.0)
line Vector (164.98046999999994, -168.2435399999999, 0.0) Vector (165.08658999999994, -167.94582999999992, 0.0)
line Vector (165.08658999999994, -167.94582999999992, 0.0) Vector (165.23101999999994, -167.57736999999992, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'167.07042', u'167.47422', u'0.23876', u'-0.20929', u'0.34488', u'-0.22697', u'0.35372', u'-0.15917', u'0.36846', u'-0.0943', u'0.31835', u'-0.0383', u'0.45099', u'0.0147', u'0.36551', u'0.0678', u'0.41857', u'0.15622', u'0.33309', u'0.20045', u'0.3154', u'0.27118', u'0.19455', u'0.21813', u'0.20928', u'0.3154', u'0.15623', u'0.3213', u'0.10907', u'0.33014', u'0.059', u'0.42152', u'-0.009', u'0.47457', u'-0.0413', u'0.1916', u'-0.13854', u'0.44805', u'-0.14739', u'0.29182', u'-0.19749', u'0.27413', u'-0.1857', u'0.22697', u'-0.25056', u'0.21813', u'-0.28003', u'0.17981', u'-0.23581', u'0.11201', u'-0.28298', u'0.10611', u'-0.20339', u'0.056', u'-0.36551', u'0.0383', u'-0.30656', u'0.003', u'-0.29476', u'-0.0442', u'-0.27119', u'-0.0619', u'-0.3095', u'-0.1179', u'-0.30067', u'-0.16507', u'-0.27708', u'-0.20339', u'-0.28003', u'-0.27709', u'-0.25645', u'-0.39204', u'-0.18275', u'-0.42446', u'-0.0943', u'-0.43036', u'-0.0472', u'-0.39499', u'0.0413', u'-0.42446', u'0.0796', u'-0.27414', u'0.13855', u'-0.32424', u'0.15033', u'-0.27708', u'0.15328', u'-0.22992', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4198'], u'fill': u'none'}
move Vector (167.07042, -167.47422, 0.0)
line Vector (167.07042, -167.47422, 0.0) Vector (167.30918000000003, -167.26493, 0.0)
line Vector (167.30918000000003, -167.26493, 0.0) Vector (167.65406000000002, -167.03796, 0.0)
line Vector (167.65406000000002, -167.03796, 0.0) Vector (168.00778000000003, -166.87879, 0.0)
line Vector (168.00778000000003, -166.87879, 0.0) Vector (168.37624000000002, -166.78449, 0.0)
line Vector (168.37624000000002, -166.78449, 0.0) Vector (168.69459000000003, -166.74619, 0.0)
line Vector (168.69459000000003, -166.74619, 0.0) Vector (169.14558000000002, -166.76089000000002, 0.0)
line Vector (169.14558000000002, -166.76089000000002, 0.0) Vector (169.51109000000002, -166.82869000000002, 0.0)
line Vector (169.51109000000002, -166.82869000000002, 0.0) Vector (169.92966, -166.98491, 0.0)
line Vector (169.92966, -166.98491, 0.0) Vector (170.26275, -167.18536, 0.0)
line Vector (170.26275, -167.18536, 0.0) Vector (170.57815000000002, -167.45654, 0.0)
line Vector (170.57815000000002, -167.45654, 0.0) Vector (170.77270000000001, -167.67467, 0.0)
line Vector (170.77270000000001, -167.67467, 0.0) Vector (170.98198000000002, -167.99007, 0.0)
line Vector (170.98198000000002, -167.99007, 0.0) Vector (171.13821000000002, -168.31137, 0.0)
line Vector (171.13821000000002, -168.31137, 0.0) Vector (171.24728000000002, -168.64151, 0.0)
line Vector (171.24728000000002, -168.64151, 0.0) Vector (171.30628000000002, -169.06303, 0.0)
line Vector (171.30628000000002, -169.06303, 0.0) Vector (171.29728000000003, -169.5376, 0.0)
line Vector (171.29728000000003, -169.5376, 0.0) Vector (171.25598000000002, -169.7292, 0.0)
line Vector (171.25598000000002, -169.7292, 0.0) Vector (171.11744000000002, -170.17725, 0.0)
line Vector (171.11744000000002, -170.17725, 0.0) Vector (170.97005000000001, -170.46907, 0.0)
line Vector (170.97005000000001, -170.46907, 0.0) Vector (170.77256000000003, -170.7432, 0.0)
line Vector (170.77256000000003, -170.7432, 0.0) Vector (170.58686000000003, -170.97017, 0.0)
line Vector (170.58686000000003, -170.97017, 0.0) Vector (170.33630000000002, -171.1883, 0.0)
line Vector (170.33630000000002, -171.1883, 0.0) Vector (170.05627, -171.36811, 0.0)
line Vector (170.05627, -171.36811, 0.0) Vector (169.82046000000003, -171.48012, 0.0)
line Vector (169.82046000000003, -171.48012, 0.0) Vector (169.53748000000002, -171.58623, 0.0)
line Vector (169.53748000000002, -171.58623, 0.0) Vector (169.33409, -171.64223, 0.0)
line Vector (169.33409, -171.64223, 0.0) Vector (168.96858, -171.68053, 0.0)
line Vector (168.96858, -171.68053, 0.0) Vector (168.66202, -171.68353, 0.0)
line Vector (168.66202, -171.68353, 0.0) Vector (168.36726000000002, -171.63933, 0.0)
line Vector (168.36726000000002, -171.63933, 0.0) Vector (168.09607000000003, -171.57743, 0.0)
line Vector (168.09607000000003, -171.57743, 0.0) Vector (167.78657, -171.45953, 0.0)
line Vector (167.78657, -171.45953, 0.0) Vector (167.48590000000002, -171.29446000000002, 0.0)
line Vector (167.48590000000002, -171.29446000000002, 0.0) Vector (167.20882, -171.09107, 0.0)
line Vector (167.20882, -171.09107, 0.0) Vector (166.92879, -170.81398000000002, 0.0)
line Vector (166.92879, -170.81398000000002, 0.0) Vector (166.67234, -170.42194, 0.0)
line Vector (166.67234, -170.42194, 0.0) Vector (166.48959, -169.99748, 0.0)
line Vector (166.48959, -169.99748, 0.0) Vector (166.39529, -169.56712, 0.0)
line Vector (166.39529, -169.56712, 0.0) Vector (166.34808999999998, -169.17212999999998, 0.0)
line Vector (166.34808999999998, -169.17212999999998, 0.0) Vector (166.38939, -168.74766999999997, 0.0)
line Vector (166.38939, -168.74766999999997, 0.0) Vector (166.46899, -168.47352999999998, 0.0)
line Vector (166.46899, -168.47352999999998, 0.0) Vector (166.60754, -168.14928999999998, 0.0)
line Vector (166.60754, -168.14928999999998, 0.0) Vector (166.75787, -167.87220999999997, 0.0)
line Vector (166.75787, -167.87220999999997, 0.0) Vector (166.91115, -167.64228999999997, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'166.20509', u'168.5294', u'0.10838', u'-0.33141', u'0.16675', u'-0.33557', u'0.17508', u'-0.28555', u'0.28764', u'-0.30223', u'0.28764', u'-0.2522', u'0.21468', u'-0.13965', u'0.24595', u'-0.14174', u'0.38768', u'-0.13965', u'0.34392', u'-0.0855', u'0.3981', u'-0.0271', u'0.42729', u'0.0333', u'0.2793', u'0.0521', u'0.27513', u'0.0855', u'0.29597', u'0.12922', u'0.31265', u'0.2001', u'0.20843', u'0.15841', u'0.24387', u'0.23761', u'0.18967', u'0.24178', u'0.19593', u'0.31265', u'0.15007', u'0.35642', u'0.10838', u'0.35225', u'0.0417', u'0.44396', u'-0.0146', u'0.44813', u'-0.0855', u'0.41478', u'-0.1334', u'0.34808', u'-0.1459', u'0.29389', u'-0.19384', u'0.27721', u'-0.24595', u'0.26888', u'-0.25637', u'0.22302', u'-0.32307', u'0.19801', u'-0.35434', u'0.16675', u'-0.41061', u'0.12714', u'-0.28346', u'0.0396', u'-0.50233', u'0.0104', u'-0.51274', u'-0.0938', u'-0.42103', u'-0.16258', u'-0.39602', u'-0.24178', u'-0.29389', u'-0.24595', u'-0.27096', u'-0.30639', u'-0.20843', u'-0.29181', u'-0.12506', u'-0.28138', u'-0.15008', u'-0.40228', u'-0.0479', u'-0.27096', u'-0.0542', u'-0.30848', u'0.0208', u'-0.38976', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4219'], u'fill': u'none'}
move Vector (166.20509, -168.5294, 0.0)
line Vector (166.20509, -168.5294, 0.0) Vector (166.31347000000002, -168.19799, 0.0)
line Vector (166.31347000000002, -168.19799, 0.0) Vector (166.48022000000003, -167.86242000000001, 0.0)
line Vector (166.48022000000003, -167.86242000000001, 0.0) Vector (166.65530000000004, -167.57687, 0.0)
line Vector (166.65530000000004, -167.57687, 0.0) Vector (166.94294000000005, -167.27464, 0.0)
line Vector (166.94294000000005, -167.27464, 0.0) Vector (167.23058000000006, -167.02244000000002, 0.0)
line Vector (167.23058000000006, -167.02244000000002, 0.0) Vector (167.44526000000005, -166.88279000000003, 0.0)
line Vector (167.44526000000005, -166.88279000000003, 0.0) Vector (167.69121000000004, -166.74105000000003, 0.0)
line Vector (167.69121000000004, -166.74105000000003, 0.0) Vector (168.07889000000003, -166.60140000000004, 0.0)
line Vector (168.07889000000003, -166.60140000000004, 0.0) Vector (168.42281000000003, -166.51590000000004, 0.0)
line Vector (168.42281000000003, -166.51590000000004, 0.0) Vector (168.82091000000003, -166.48880000000005, 0.0)
line Vector (168.82091000000003, -166.48880000000005, 0.0) Vector (169.24820000000003, -166.52210000000005, 0.0)
line Vector (169.24820000000003, -166.52210000000005, 0.0) Vector (169.52750000000003, -166.57420000000005, 0.0)
line Vector (169.52750000000003, -166.57420000000005, 0.0) Vector (169.80263000000002, -166.65970000000004, 0.0)
line Vector (169.80263000000002, -166.65970000000004, 0.0) Vector (170.09860000000003, -166.78892000000005, 0.0)
line Vector (170.09860000000003, -166.78892000000005, 0.0) Vector (170.41125000000002, -166.98902000000004, 0.0)
line Vector (170.41125000000002, -166.98902000000004, 0.0) Vector (170.61968000000002, -167.14743000000004, 0.0)
line Vector (170.61968000000002, -167.14743000000004, 0.0) Vector (170.86355, -167.38504000000003, 0.0)
line Vector (170.86355, -167.38504000000003, 0.0) Vector (171.05322, -167.62682000000004, 0.0)
line Vector (171.05322, -167.62682000000004, 0.0) Vector (171.24915000000001, -167.93947000000003, 0.0)
line Vector (171.24915000000001, -167.93947000000003, 0.0) Vector (171.39922, -168.29589000000004, 0.0)
line Vector (171.39922, -168.29589000000004, 0.0) Vector (171.50760000000002, -168.64814000000004, 0.0)
line Vector (171.50760000000002, -168.64814000000004, 0.0) Vector (171.54930000000002, -169.09210000000004, 0.0)
line Vector (171.54930000000002, -169.09210000000004, 0.0) Vector (171.53470000000002, -169.54023000000004, 0.0)
line Vector (171.53470000000002, -169.54023000000004, 0.0) Vector (171.44920000000002, -169.95501000000004, 0.0)
line Vector (171.44920000000002, -169.95501000000004, 0.0) Vector (171.31580000000002, -170.30309000000005, 0.0)
line Vector (171.31580000000002, -170.30309000000005, 0.0) Vector (171.1699, -170.59698000000006, 0.0)
line Vector (171.1699, -170.59698000000006, 0.0) Vector (170.97606000000002, -170.87419000000006, 0.0)
line Vector (170.97606000000002, -170.87419000000006, 0.0) Vector (170.73011000000002, -171.14307000000005, 0.0)
line Vector (170.73011000000002, -171.14307000000005, 0.0) Vector (170.47374000000002, -171.36609000000004, 0.0)
line Vector (170.47374000000002, -171.36609000000004, 0.0) Vector (170.15067000000002, -171.56410000000005, 0.0)
line Vector (170.15067000000002, -171.56410000000005, 0.0) Vector (169.79633, -171.73085000000006, 0.0)
line Vector (169.79633, -171.73085000000006, 0.0) Vector (169.38572000000002, -171.85799000000006, 0.0)
line Vector (169.38572000000002, -171.85799000000006, 0.0) Vector (169.10226000000003, -171.89759000000006, 0.0)
line Vector (169.10226000000003, -171.89759000000006, 0.0) Vector (168.59993000000003, -171.90799000000007, 0.0)
line Vector (168.59993000000003, -171.90799000000007, 0.0) Vector (168.08719000000002, -171.81419000000008, 0.0)
line Vector (168.08719000000002, -171.81419000000008, 0.0) Vector (167.66616000000002, -171.6516100000001, 0.0)
line Vector (167.66616000000002, -171.6516100000001, 0.0) Vector (167.27014000000003, -171.40983000000008, 0.0)
line Vector (167.27014000000003, -171.40983000000008, 0.0) Vector (166.97625000000002, -171.1638800000001, 0.0)
line Vector (166.97625000000002, -171.1638800000001, 0.0) Vector (166.70529000000002, -170.8574900000001, 0.0)
line Vector (166.70529000000002, -170.8574900000001, 0.0) Vector (166.49686000000003, -170.5656800000001, 0.0)
line Vector (166.49686000000003, -170.5656800000001, 0.0) Vector (166.37180000000004, -170.2843000000001, 0.0)
line Vector (166.37180000000004, -170.2843000000001, 0.0) Vector (166.22172000000003, -169.8820200000001, 0.0)
line Vector (166.22172000000003, -169.8820200000001, 0.0) Vector (166.17382000000003, -169.6110600000001, 0.0)
line Vector (166.17382000000003, -169.6110600000001, 0.0) Vector (166.11962000000003, -169.3025800000001, 0.0)
line Vector (166.11962000000003, -169.3025800000001, 0.0) Vector (166.14042000000003, -168.9128200000001, 0.0)
existing group transform: [Matrix ((29.5858,0,0,0),(0,29.5858,0,0),(0,0,1,0),(0,0,0,1))]
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'167.24308', u'167.92286', u'1.28811', u'1.28603', u'-1.30061', u'1.30062', u'-0.0813', u'-0.10631', u'-0.1063', u'-0.17508', u'-0.098', u'-0.17925', u'-0.0834', u'-0.25429', u'-0.0709', u'-0.25428', u'-0.002', u'-0.38769', u'0.008', u'-0.30639', u'0.12506', u'-0.37726', u'0.16466', u'-0.3335', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4221'], u'fill': u'none'}
move Vector (167.24308, -167.92286, 0.0)
line Vector (167.24308, -167.92286, 0.0) Vector (168.53118999999998, -169.20889, 0.0)
line Vector (168.53118999999998, -169.20889, 0.0) Vector (167.23057999999997, -170.50951, 0.0)
line Vector (167.23057999999997, -170.50951, 0.0) Vector (167.14927999999998, -170.4032, 0.0)
line Vector (167.14927999999998, -170.4032, 0.0) Vector (167.04297999999997, -170.22812, 0.0)
line Vector (167.04297999999997, -170.22812, 0.0) Vector (166.94497999999996, -170.04887, 0.0)
line Vector (166.94497999999996, -170.04887, 0.0) Vector (166.86157999999995, -169.79458, 0.0)
line Vector (166.86157999999995, -169.79458, 0.0) Vector (166.79067999999995, -169.5403, 0.0)
line Vector (166.79067999999995, -169.5403, 0.0) Vector (166.78867999999994, -169.15261, 0.0)
line Vector (166.78867999999994, -169.15261, 0.0) Vector (166.79667999999995, -168.84622000000002, 0.0)
line Vector (166.79667999999995, -168.84622000000002, 0.0) Vector (166.92173999999994, -168.46896, 0.0)
line Vector (166.92173999999994, -168.46896, 0.0) Vector (167.08639999999994, -168.13546000000002, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'167.07634', u'168.68989', u'0.2126', u'-0.008', u'0.22302', u'0.6503', u'-0.006', u'-0.6503', u'0.20009', u'0.004', u'0', u'0.519', u'0.0792', u'0.0605', u'-0.0709', u'0.0563', u'-0.0146', u'0.52734', u'-0.19593', u'-0.002', u'-0.22094', u'-0.62946', u'0.002', u'0.61904', u'-0.21677', u'-0.004', u'0.0125', u'-0.50232', u'-0.0875', u'-0.0688', u'0.0896', u'-0.0563', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4223'], u'fill': u'none'}
move Vector (167.07634, -168.68989, 0.0)
line Vector (167.07634, -168.68989, 0.0) Vector (167.28894, -168.68188999999998, 0.0)
line Vector (167.28894, -168.68188999999998, 0.0) Vector (167.51196, -169.33218999999997, 0.0)
line Vector (167.51196, -169.33218999999997, 0.0) Vector (167.50596, -168.68188999999998, 0.0)
line Vector (167.50596, -168.68188999999998, 0.0) Vector (167.70604999999998, -168.68588999999997, 0.0)
line Vector (167.70604999999998, -168.68588999999997, 0.0) Vector (167.70604999999998, -169.20488999999998, 0.0)
line Vector (167.70604999999998, -169.20488999999998, 0.0) Vector (167.78524999999996, -169.26538999999997, 0.0)
line Vector (167.78524999999996, -169.26538999999997, 0.0) Vector (167.71434999999997, -169.32168999999996, 0.0)
line Vector (167.71434999999997, -169.32168999999996, 0.0) Vector (167.69974999999997, -169.84902999999997, 0.0)
line Vector (167.69974999999997, -169.84902999999997, 0.0) Vector (167.50381999999996, -169.84702999999996, 0.0)
line Vector (167.50381999999996, -169.84702999999996, 0.0) Vector (167.28287999999995, -169.21756999999997, 0.0)
line Vector (167.28287999999995, -169.21756999999997, 0.0) Vector (167.28487999999996, -169.83660999999998, 0.0)
line Vector (167.28487999999996, -169.83660999999998, 0.0) Vector (167.06810999999996, -169.83261, 0.0)
line Vector (167.06810999999996, -169.83261, 0.0) Vector (167.08060999999995, -169.33029, 0.0)
line Vector (167.08060999999995, -169.33029, 0.0) Vector (166.99310999999994, -169.26148999999998, 0.0)
line Vector (166.99310999999994, -169.26148999999998, 0.0) Vector (167.08270999999993, -169.20519, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'167.54114', u'170.80131', u'1.28394', u'-1.29645', u'1.3027', u'1.30687', u'-0.17508', u'0.12506', u'-0.19593', u'0.1063', u'-0.20635', u'0.0938', u'-0.25845', u'0.0792', u'-0.22094', u'0.0396', u'-0.25429', u'0.0146', u'-0.41894', u'-0.025', u'-0.33558', u'-0.12089', u'-0.28764', u'-0.12923', u'-0.21677', u'-0.15841', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4225'], u'fill': u'none'}
move Vector (167.54114, -170.80131, 0.0)
line Vector (167.54114, -170.80131, 0.0) Vector (168.82508, -169.50486, 0.0)
line Vector (168.82508, -169.50486, 0.0) Vector (170.12778, -170.81173, 0.0)
line Vector (170.12778, -170.81173, 0.0) Vector (169.9527, -170.93679, 0.0)
line Vector (169.9527, -170.93679, 0.0) Vector (169.75677, -171.04309, 0.0)
line Vector (169.75677, -171.04309, 0.0) Vector (169.55042, -171.13689, 0.0)
line Vector (169.55042, -171.13689, 0.0) Vector (169.29197, -171.21608999999998, 0.0)
line Vector (169.29197, -171.21608999999998, 0.0) Vector (169.07102999999998, -171.25569, 0.0)
line Vector (169.07102999999998, -171.25569, 0.0) Vector (168.81673999999998, -171.27029, 0.0)
line Vector (168.81673999999998, -171.27029, 0.0) Vector (168.3978, -171.24528999999998, 0.0)
line Vector (168.3978, -171.24528999999998, 0.0) Vector (168.06222, -171.12439999999998, 0.0)
line Vector (168.06222, -171.12439999999998, 0.0) Vector (167.77458, -170.99516999999997, 0.0)
line Vector (167.77458, -170.99516999999997, 0.0) Vector (167.55781, -170.83675999999997, 0.0)
applying group transform: Matrix ((29.5858,0,0,0),(0,29.5858,0,0),(0,0,1,0),(0,0,0,1))
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'168.49784', u'170.39695', u'0.0104', u'-0.32515', u'0.0625', u'-0.11881', u'0.0917', u'-0.0667', u'0.10422', u'-0.0146', u'0.12297', u'0.0146', u'0.098', u'0.0354', u'0.0813', u'0.13548', u'0.0104', u'0.0625', u'0.002', u'0.28138', u'0.0959', u'0.0792', u'-0.098', u'0.073', u'-0.004', u'0.37101', u'0.0188', u'0.0417', u'0.004', u'0.16466', u'-0.0813', u'0.004', u'-0.075', u'-0.0479', u'-0.0438', u'-0.0104', u'-0.19592', u'-0.002', u'-0.0917', u'-0.05', u'-0.0709', u'-0.0834', u'-0.0313', u'-0.0917', u'-0.0125', u'-0.29806', u'-0.0875', u'-0.0729', u'0.0917', u'-0.0646', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4227'], u'fill': u'none'}
move Vector (168.49784, -170.39695, 0.0)
line Vector (168.49784, -170.39695, 0.0) Vector (168.50824, -170.0718, 0.0)
line Vector (168.50824, -170.0718, 0.0) Vector (168.57074, -169.95299, 0.0)
line Vector (168.57074, -169.95299, 0.0) Vector (168.66244, -169.88629, 0.0)
line Vector (168.66244, -169.88629, 0.0) Vector (168.76666, -169.87169, 0.0)
line Vector (168.76666, -169.87169, 0.0) Vector (168.88963, -169.88629, 0.0)
line Vector (168.88963, -169.88629, 0.0) Vector (168.98763000000002, -169.92169, 0.0)
line Vector (168.98763000000002, -169.92169, 0.0) Vector (169.06893000000002, -170.05717, 0.0)
line Vector (169.06893000000002, -170.05717, 0.0) Vector (169.07933000000003, -170.11967, 0.0)
line Vector (169.07933000000003, -170.11967, 0.0) Vector (169.08133000000004, -170.40105000000003, 0.0)
line Vector (169.08133000000004, -170.40105000000003, 0.0) Vector (169.17723000000004, -170.48025, 0.0)
line Vector (169.17723000000004, -170.48025, 0.0) Vector (169.07923000000002, -170.55325000000002, 0.0)
line Vector (169.07923000000002, -170.55325000000002, 0.0) Vector (169.07523000000003, -170.92426000000003, 0.0)
line Vector (169.07523000000003, -170.92426000000003, 0.0) Vector (169.09403000000003, -170.96596000000002, 0.0)
line Vector (169.09403000000003, -170.96596000000002, 0.0) Vector (169.09803000000002, -171.13062000000002, 0.0)
line Vector (169.09803000000002, -171.13062000000002, 0.0) Vector (169.01673000000002, -171.13462, 0.0)
line Vector (169.01673000000002, -171.13462, 0.0) Vector (168.94173000000004, -171.08672, 0.0)
line Vector (168.94173000000004, -171.08672, 0.0) Vector (168.89793000000003, -171.07632, 0.0)
line Vector (168.89793000000003, -171.07632, 0.0) Vector (168.70201000000003, -171.07432, 0.0)
line Vector (168.70201000000003, -171.07432, 0.0) Vector (168.61031000000003, -171.02432, 0.0)
line Vector (168.61031000000003, -171.02432, 0.0) Vector (168.53941000000003, -170.94091999999998, 0.0)
line Vector (168.53941000000003, -170.94091999999998, 0.0) Vector (168.50811000000004, -170.84921999999997, 0.0)
line Vector (168.50811000000004, -170.84921999999997, 0.0) Vector (168.49561000000006, -170.55115999999998, 0.0)
line Vector (168.49561000000006, -170.55115999999998, 0.0) Vector (168.40811000000005, -170.47825999999998, 0.0)
line Vector (168.40811000000005, -170.47825999999998, 0.0) Vector (168.49981000000005, -170.41365999999996, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'168.68752', u'170.15309', u'0.006', u'0.65447', u'0.0167', u'0.0521', u'0.0479', u'0.0313', u'0.0396', u'0.008', u'0.0479', u'-0.0104', u'0.0333', u'-0.0459', u'0.006', u'-0.0271', u'-0.004', u'-0.67115', u'-0.0292', u'-0.0438', u'-0.0417', u'-0.0167', u'-0.0563', u'-0.008', u'-0.0354', u'0.0188', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4229'], u'fill': u'none'}
move Vector (168.68752, -170.15309, 0.0)
line Vector (168.68752, -170.15309, 0.0) Vector (168.69352, -170.80756, 0.0)
line Vector (168.69352, -170.80756, 0.0) Vector (168.71022, -170.85966, 0.0)
line Vector (168.71022, -170.85966, 0.0) Vector (168.75812, -170.89095999999998, 0.0)
line Vector (168.75812, -170.89095999999998, 0.0) Vector (168.79772, -170.89896, 0.0)
line Vector (168.79772, -170.89896, 0.0) Vector (168.84562, -170.88855999999998, 0.0)
line Vector (168.84562, -170.88855999999998, 0.0) Vector (168.87892, -170.84266, 0.0)
line Vector (168.87892, -170.84266, 0.0) Vector (168.88492, -170.81556, 0.0)
line Vector (168.88492, -170.81556, 0.0) Vector (168.88092, -170.14441, 0.0)
line Vector (168.88092, -170.14441, 0.0) Vector (168.85172, -170.10061, 0.0)
line Vector (168.85172, -170.10061, 0.0) Vector (168.81002, -170.08391, 0.0)
line Vector (168.81002, -170.08391, 0.0) Vector (168.75372000000002, -170.07591, 0.0)
line Vector (168.75372000000002, -170.07591, 0.0) Vector (168.71832, -170.09471, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'167.5391', u'167.6216', u'1.29108', u'1.29993', u'1.29993', u'-1.30582', u'-0.22992', u'-0.17097', u'-0.34193', u'-0.16507', u'-0.32425', u'-0.0943', u'-0.39498', u'-0.0413', u'-0.35962', u'0.0324', u'-0.33604', u'0.0825', u'-0.33308', u'0.16507', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4231'], u'fill': u'none'}
move Vector (167.5391, -167.6216, 0.0)
line Vector (167.5391, -167.6216, 0.0) Vector (168.83017999999998, -168.92153, 0.0)
line Vector (168.83017999999998, -168.92153, 0.0) Vector (170.13010999999997, -167.61570999999998, 0.0)
line Vector (170.13010999999997, -167.61570999999998, 0.0) Vector (169.90018999999998, -167.44473999999997, 0.0)
line Vector (169.90018999999998, -167.44473999999997, 0.0) Vector (169.55826, -167.27966999999998, 0.0)
line Vector (169.55826, -167.27966999999998, 0.0) Vector (169.23400999999998, -167.18536999999998, 0.0)
line Vector (169.23400999999998, -167.18536999999998, 0.0) Vector (168.83902999999998, -167.14406999999997, 0.0)
line Vector (168.83902999999998, -167.14406999999997, 0.0) Vector (168.47940999999997, -167.17646999999997, 0.0)
line Vector (168.47940999999997, -167.17646999999997, 0.0) Vector (168.14336999999998, -167.25896999999998, 0.0)
line Vector (168.14336999999998, -167.25896999999998, 0.0) Vector (167.81028999999998, -167.42403999999996, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'168.56489', u'167.34452', u'-0.003', u'0.50111', u'-0.0884', u'0.0766', u'0.0855', u'0.0619', u'0.006', u'0.507', u'0.53648', u'0.006', u'-0.003', u'-0.20339', u'-0.30656', u'-0.003', u'-0.0236', u'0', u'0.003', u'-0.28003', u'0.24171', u'-0.0206', u'-0.009', u'-0.1857', u'-0.23287', u'-0.003', u'-0.006', u'-0.29182', u'0.34783', u'-0.006', u'0.003', u'-0.18865', u'-0.55416', u'0.003', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4233'], u'fill': u'none'}
move Vector (168.56489, -167.34452, 0.0)
line Vector (168.56489, -167.34452, 0.0) Vector (168.56189, -167.84563, 0.0)
line Vector (168.56189, -167.84563, 0.0) Vector (168.47349, -167.92223, 0.0)
line Vector (168.47349, -167.92223, 0.0) Vector (168.55899, -167.98413000000002, 0.0)
line Vector (168.55899, -167.98413000000002, 0.0) Vector (168.56499, -168.49113000000003, 0.0)
line Vector (168.56499, -168.49113000000003, 0.0) Vector (169.10147, -168.49713000000003, 0.0)
line Vector (169.10147, -168.49713000000003, 0.0) Vector (169.09847000000002, -168.29374, 0.0)
line Vector (169.09847000000002, -168.29374, 0.0) Vector (168.79191000000003, -168.29074000000003, 0.0)
line Vector (168.79191000000003, -168.29074000000003, 0.0) Vector (168.76831000000004, -168.29074000000003, 0.0)
line Vector (168.76831000000004, -168.29074000000003, 0.0) Vector (168.77131000000003, -168.01071000000002, 0.0)
line Vector (168.77131000000003, -168.01071000000002, 0.0) Vector (169.01302000000004, -167.99011000000002, 0.0)
line Vector (169.01302000000004, -167.99011000000002, 0.0) Vector (169.00402000000005, -167.80441000000002, 0.0)
line Vector (169.00402000000005, -167.80441000000002, 0.0) Vector (168.77115000000006, -167.80141000000003, 0.0)
line Vector (168.77115000000006, -167.80141000000003, 0.0) Vector (168.76515000000006, -167.50959000000003, 0.0)
line Vector (168.76515000000006, -167.50959000000003, 0.0) Vector (169.11298000000005, -167.50359000000003, 0.0)
line Vector (169.11298000000005, -167.50359000000003, 0.0) Vector (169.11598000000004, -167.31494000000004, 0.0)
line Vector (169.11598000000004, -167.31494000000004, 0.0) Vector (168.56182000000004, -167.31794000000002, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'169.14558', u'169.2045', u'1.27929', u'-1.29403', u'0.12675', u'0.18276', u'0.16802', u'0.30656', u'0.0943', u'0.28298', u'0.0619', u'0.23581', u'0.0177', u'0.32719', u'-0.009', u'0.29182', u'-0.10022', u'0.37141', u'-0.12675', u'0.27708', u'-0.21813', u'0.31245', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4235'], u'fill': u'none'}
move Vector (169.14558, -169.2045, 0.0)
line Vector (169.14558, -169.2045, 0.0) Vector (170.42487, -167.91047, 0.0)
line Vector (170.42487, -167.91047, 0.0) Vector (170.55161999999999, -168.09323, 0.0)
line Vector (170.55161999999999, -168.09323, 0.0) Vector (170.71964, -168.39979, 0.0)
line Vector (170.71964, -168.39979, 0.0) Vector (170.81394, -168.68277, 0.0)
line Vector (170.81394, -168.68277, 0.0) Vector (170.87584, -168.91858, 0.0)
line Vector (170.87584, -168.91858, 0.0) Vector (170.89354, -169.24577, 0.0)
line Vector (170.89354, -169.24577, 0.0) Vector (170.88454000000002, -169.53759, 0.0)
line Vector (170.88454000000002, -169.53759, 0.0) Vector (170.78432, -169.909, 0.0)
line Vector (170.78432, -169.909, 0.0) Vector (170.65757000000002, -170.18608, 0.0)
line Vector (170.65757000000002, -170.18608, 0.0) Vector (170.43944000000002, -170.49853000000002, 0.0)
data: {u'stroke-linejoin': u'miter', u'style': u'fill:none;fill-rule:evenodd;stroke:#000000;stroke-width:0.03px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1', u'd': [u'm', u'169.96209', u'169.82646', u'0.20044', u'-0.5011', u'-0.0825', u'-0.059', u'0.0855', u'-0.0648', u'-0.20929', u'-0.5129', u'0.21813', u'-0.006', u'0.1238', u'0.31245', u'0.1297', u'-0.31835', u'0.20929', u'-0.003', u'-0.1975', u'0.53943', u'0.0619', u'0.0442', u'-0.0678', u'0.0619', u'0.20044', u'0.50405', u'-0.20929', u'0', u'-0.11496', u'-0.28592', u'-0.1238', u'0.30361', u'z'], u'stroke-opacity': u'1', u'fill-rule': u'evenodd', u'inkscape:connector-curvature': [u'0'], u'stroke': u'#000000', u'stroke-linecap': u'butt', u'stroke-width': u'0.03px', u'id': [u'path4237'], u'fill': u'none'}
move Vector (169.96209, -169.82646, 0.0)
line Vector (169.96209, -169.82646, 0.0) Vector (170.16252999999998, -169.32536, 0.0)
line Vector (170.16252999999998, -169.32536, 0.0) Vector (170.08002999999997, -169.26636, 0.0)
line Vector (170.08002999999997, -169.26636, 0.0) Vector (170.16552999999996, -169.20156, 0.0)
line Vector (170.16552999999996, -169.20156, 0.0) Vector (169.95623999999995, -168.68866, 0.0)
line Vector (169.95623999999995, -168.68866, 0.0) Vector (170.17436999999995, -168.68266, 0.0)
line Vector (170.17436999999995, -168.68266, 0.0) Vector (170.29816999999994, -168.99511, 0.0)
line Vector (170.29816999999994, -168.99511, 0.0) Vector (170.42786999999996, -168.67676, 0.0)
line Vector (170.42786999999996, -168.67676, 0.0) Vector (170.63715999999997, -168.67376000000002, 0.0)
line Vector (170.63715999999997, -168.67376000000002, 0.0) Vector (170.43965999999998, -169.21319000000003, 0.0)
line Vector (170.43965999999998, -169.21319000000003, 0.0) Vector (170.50155999999998, -169.25739000000002, 0.0)
line Vector (170.50155999999998, -169.25739000000002, 0.0) Vector (170.43375999999998, -169.31929000000002, 0.0)
line Vector (170.43375999999998, -169.31929000000002, 0.0) Vector (170.63419999999996, -169.82334000000003, 0.0)
line Vector (170.63419999999996, -169.82334000000003, 0.0) Vector (170.42490999999995, -169.82334000000003, 0.0)
line Vector (170.42490999999995, -169.82334000000003, 0.0) Vector (170.30994999999996, -169.53742000000003, 0.0)
line Vector (170.30994999999996, -169.53742000000003, 0.0) Vector (170.18614999999997, -169.84103000000002, 0.0)
closing group
OpenSCAD executable not found
Cannot find icon: python
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f00a04424b0]
#1 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x2a96fa) [0x7f00a150b6fa]
0000002 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x2a994b) [0x7f00a150b94b]
0000003 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x2a758b) [0x7f00a150958b]
0000004 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x2a78b5) [0x7f00a15098b5]
0000005 0x7f00a0f13c83 in QObject::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0xa3
0000006 0x7f00a1426fdc in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x8c
0000007 0x7f00a142df16 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x2b6
0000008 0x7f00a309ba14 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x54
0000009 0x7f00a0ef990d in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x8d
0000010 /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1bd780) [0x7f00a0f2c780]
0000011 /usr/lib/x86_64-linux-gnu/libQtCore.so.4(+0x1ba8f1) [0x7f00a0f298f1]
0000012 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2a7) [0x7f0099b61197]
0000013 /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4a3f0) [0x7f0099b613f0]
0000014 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7f0099b6149c]
0000015 0x7f00a0f2a2ae in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x7e
0000016 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272616) [0x7f00a14d4616]
0000017 0x7f00a0ef818f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x3f
0000018 0x7f00a0ef84f5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x1b5
0000019 0x7f00a0efe4b9 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x99
0000020 0x7f00a304d4cd in Gui::Application::runApplication() from /usr/lib/freecad-daily/lib/libFreeCADGui.so+0x1aed
0000021 freecad-daily(main+0x8b4) [0x403754]
0000022 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f00a042d830]
0000023 freecad-daily(_start+0x29) [0x404999]
fish: “freecad-daily” terminated by signal SIGSEGV (Address boundary error)
