| 0004057 | FreeCAD | Bug | public | 2019-07-15 14:26 | 2019-11-26 20:57 |
| Reporter | rpress | Assigned To | pfirszt | ||
| Summary | 0004057: Nightly builds not working on Fedora 30 | ||||
| Description | I am trying to install freecad-0.19_pre-17320.x86_64 from here: https://copr.fedorainfracloud.org/coprs/g/freecad/nightly/package/freecad/ The first error I see is with DNF:
I can edit the RPM to remove that dependency, and it installs fine. I saw this commit but I guess it didn't work? https://github.com/FreeCAD/FreeCAD/commit/f53d8956c7a29846448a0781807975ed5cb77fcdWhen I try to run it I receive this error:
| Steps To Reproduce | Using Fedora 30, install freecad-0.19_pre-17320.x86_64 and simply run it. | ||||
| Tags | packaging, upstream | ||||
@rpress : could you please (according to reporting guidelines) open a new topic in the Install subforum ? Community will help and eventually confirm this is a bug needing a ticket. ;) Thanks |
I saw the same problem as mine here: https://forum.freecadweb.org/viewtopic.php?t=33810 It's not clear if "BUILD_QT5=ON" is the right solution, and if it is the right solution it hasn't made it way into the nightly build. Would you like me to add a comment in that thread or make a new one altogether? |
@rpress : my opinion is that opening a new one is better. The one you pointed was about a compilation while your case (if I'm correct) is an installation from distro repo. ;) |
I have created a new thread here: https://forum.freecadweb.org/viewtopic.php?f=4&t=37780 Let's hope it gets more replies than that other thread. |
@rpress hope that too. But for sure you'll have a better chance to get a reply than here on the tracker. ;) |
Oh. Well I guess I get it, bugs are no fun to work on. :( |
Ok you can just close this, thanks for trying to help. |
Well since it is still open, I have removed monitoring of this issue so I (hopefully) won't be bothered with emails when this is inevitably closed due to inactivity. |
Assigned to @pfirszt |
@rpress https://forum.freecadweb.org/viewtopic.php?f=4&t=37780&p=332097#p331531 |
Fedora is in the process of removing all python 2 packages from Fedora. The correct requirement is now Requires: python3-pivy Thanks, Richard |
Thanks hobbes1069! @pfirszt ping |
0004132 is an untested solution to this problem |
Hey, I tried FreeCAD nightly on Fedora 31, and what do you know, it works! Sorry I was being short before, but your bug reporting policies are not very friendly. I get it, there are lots of bogus bug reports. But requiring every bug to also be posted to the forum feels practically insulting. Of course you guys are entitled to run the bug reporting any way you see fit, and I see this has been the policy now for many years; I doubt my comments here will change that. But maybe it's fair I at least let you know my feelings. I greatly appreciate all the volunteer efforts of the developers here and I don't want to diminish your work, but perhaps the policy could use an update. |
@rpress thanks for hanging in there. It is a chore for sure but the positive side is that it opens an avenue for more interaction with the community. Again thank you and we hope to hear more from you in the forums :) Cheers. Closing ticket. |
| 2019-07-15 14:26 | rpress | New Issue | |
| 2019-07-15 16:36 | openBrain | Note Added: 0013346 | |
| 2019-07-15 16:37 | openBrain | Status | new => feedback |
| 2019-07-15 16:37 | openBrain | Tag Attached: #post-to-forum | |
| 2019-07-16 14:54 | rpress | Note Added: 0013351 | |
| 2019-07-16 14:54 | rpress | Status | feedback => new |
| 2019-07-16 17:24 | openBrain | Note Added: 0013352 | |
| 2019-07-16 20:43 | rpress | Note Added: 0013353 | |
| 2019-07-17 17:27 | openBrain | Note Added: 0013356 | |
| 2019-07-18 12:52 | rpress | Note Added: 0013360 | |
| 2019-07-22 11:46 | Kunda1 | Tag Detached: #post-to-forum | |
| 2019-08-04 14:12 | rpress | Note Added: 0013400 | |
| 2019-08-17 13:18 | rpress | Note Added: 0013428 | |
| 2019-08-20 21:30 | Kunda1 | Assigned To | => pfirszt |
| 2019-08-20 21:30 | Kunda1 | Status | new => assigned |
| 2019-08-20 21:30 | Kunda1 | Note Added: 0013438 | |
| 2019-09-01 19:54 | Kunda1 | Tag Attached: packaging | |
| 2019-09-05 20:32 | Kunda1 | Target Version | => 0.19 |
| 2019-09-05 20:33 | Kunda1 | Note Added: 0013541 | |
| 2019-09-05 20:33 | Kunda1 | Tag Attached: upstream | |
| 2019-09-14 12:47 | hobbes1069 | Note Added: 0013596 | |
| 2019-09-14 17:06 | Kunda1 | Note Added: 0013597 | |
| 2019-09-18 13:43 | pfirszt | Note Added: 0013630 | |
| 2019-09-18 13:43 | pfirszt | Note Edited: 0013630 | |
| 2019-09-18 13:44 | pfirszt | Note Edited: 0013630 | |
| 2019-11-26 15:16 | rpress | Note Added: 0013844 | |
| 2019-11-26 20:57 | Kunda1 | Status | assigned => closed |
| 2019-11-26 20:57 | Kunda1 | Resolution | open => fixed |
| 2019-11-26 20:57 | Kunda1 | Note Added: 0013845 |
