| 0000922 | FreeCAD | Feature | public | 2012-12-20 17:05 | 2021-02-20 14:08 |
| Reporter | Assigned To | realthunder | |||
| Summary | 0000922: Topological Naming | ||||
| Description | Group issue for all issues regarding Topological Naming. All bugs and features will be collected under this issue and targeted by the Naming Project: http://www.freecadweb.org/wiki/Naming_project | ||||
| Tags | toponaming | ||||
| parent of | 0000876 | assigned | realthunder | PartDesign | Topological naming interface |
| parent of | 0000873 | closed | jrheinlaender | FreeCAD | RefineModel() does not mark edges/faces as modified |
| parent of | 0002742 | closed | FreeCAD | Unrelated features lost on edit. | |
| parent of | 0002462 | new | FreeCAD | Manage Object Display Order in Tree View | |
| parent of | 0004112 | closed | PartDesign | Fillet segment association are "randomly" changed after inserting a new PAD/POCKET when Tip is changed to a previous state. | |
| has duplicate | 0000883 | closed | realthunder | FreeCAD | Sketch editing corrupts fillet |
| has duplicate | 0000523 | closed | FreeCAD | Fillet Updates is failling! | |
| has duplicate | 0000794 | closed | PartDesign | External reference in sketch changes | |
| has duplicate | 0000796 | closed | realthunder | FreeCAD | Sketch of a feature "jumps" to another face after adding/deleting elements from the sketch of its support |
| has duplicate | 0001625 | closed | realthunder | PartDesign | change something old in the design tree didn't update the latest result |
| has duplicate | 0001765 | closed | realthunder | PartDesign | Fillet object not updated after change to underlying sketch |
| has duplicate | 0002188 | closed | realthunder | PartDesign | Modifying a pocket sketch destroys orientation and position of another pocket |
| has duplicate | 0002522 | closed | realthunder | PartDesign | part design fillet and chamfer tool will not reproduce same edge# or face# |
| has duplicate | 0002769 | closed | realthunder | FreeCAD | Recomputation breaks sketch |
| has duplicate | 0002948 | closed | FreeCAD | Ruled Surfaces get mixed up | |
| has duplicate | 0003140 | closed | FreeCAD | external geometry not kept consistently | |
| has duplicate | 0002721 | assigned | realthunder | Part | Face order instability with Part Extrude and friends |
| Not all the children of this issue are yet resolved or closed. | |||||
|  | link on new wiki http://www.freecadweb.org/wiki/index.php?title=Naming_project |
|  | Assigning to @jnxd since his project was accepted for GSOC 2017 |
|  | What's the latest status on topological naming? |
|  | @mihai.dumitresq currently the best prospects look like in realthunder's link3/Assembly3 brnaches. You can find the discussion on the Forum: https://forum.freecadweb.org/viewtopic.php?f=10&t=27278 |
|  | This ticket has been migrated to GitHub as issue 6317. |
| 2012-12-20 17:05 |  | New Issue | |
| 2012-12-20 17:06 |  | Relationship added | parent of 0000883 |
| 2012-12-20 17:06 |  | Relationship added | parent of 0000876 |
| 2012-12-20 17:07 |  | Assigned To | => Jriegel |
| 2012-12-20 17:07 |  | Status | new => assigned |
| 2012-12-20 17:07 |  | Projection | none => major rework |
| 2012-12-20 17:07 |  | Target Version | => 0.14 |
| 2012-12-20 19:27 |  | Relationship added | parent of 0000873 |
| 2012-12-20 20:01 |  | Relationship added | parent of 0000523 |
| 2012-12-20 20:40 | logari81 | Relationship added | parent of 0000794 |
| 2012-12-20 20:48 | logari81 | Relationship added | parent of 0000796 |
| 2014-04-26 17:32 | berndhahnebach | Note Added: 0004577 | |
| 2014-06-25 12:09 | wmayer | Target Version | 0.14 => 0.15 |
| 2014-07-22 13:26 | wmayer | Relationship added | related to 0001625 |
| 2014-09-25 16:24 | shoogen | Relationship added | related to 0001765 |
| 2015-01-25 16:14 | yorik | Target Version | 0.15 => |
| 2016-02-28 20:23 | wmayer | Relationship added | related to 0002188 |
| 2016-04-27 12:19 | ickby | Relationship added | parent of 0002522 |
| 2016-11-20 21:30 | normandc | Description Updated | |
| 2017-01-14 13:12 | Kunda1 | Relationship added | parent of 0002769 |
| 2017-02-15 04:40 | Kunda1 | Relationship replaced | has duplicate 0002769 |
| 2017-03-09 17:22 | Kunda1 | Relationship added | has duplicate 0002948 |
| 2017-05-05 12:08 | Kunda1 | Assigned To | Jriegel => jnxd |
| 2017-05-05 12:11 | Kunda1 | Note Added: 0008890 | |
| 2017-05-24 18:08 | Kunda1 | Relationship added | parent of 0002742 |
| 2017-07-27 17:01 | Kunda1 | Relationship added | has duplicate 0003140 |
| 2017-11-06 13:19 | Kunda1 | Relationship added | parent of 0002462 |
| 2017-11-06 13:19 | Kunda1 | Description Updated | |
| 2018-01-02 14:16 | wmayer | Relationship added | parent of 0002721 |
| 2019-03-16 13:22 | mihai.dumitresq | Note Added: 0012919 | |
| 2019-03-16 16:49 | Kunda1 | Note Added: 0012924 | |
| 2019-09-03 15:19 | openBrain | Relationship added | parent of 0004112 |
| 2021-02-20 13:43 | Kunda1 | Relationship replaced | has duplicate 0000523 |
| 2021-02-20 13:46 | Kunda1 | Relationship replaced | has duplicate 0000794 |
| 2021-02-20 13:47 | Kunda1 | Assigned To | jnxd => realthunder |
| 2021-02-20 13:48 | Kunda1 | Relationship replaced | has duplicate 0001625 |
| 2021-02-20 13:50 | Kunda1 | Relationship replaced | has duplicate 0001765 |
| 2021-02-20 13:52 | Kunda1 | Relationship replaced | has duplicate 0002188 |
| 2021-02-20 13:53 | Kunda1 | Relationship replaced | has duplicate 0000883 |
| 2021-02-20 13:56 | Kunda1 | Relationship replaced | has duplicate 0000796 |
| 2021-02-20 13:58 | Kunda1 | Relationship replaced | has duplicate 0002522 |
| 2021-02-20 14:07 | Kunda1 | Relationship replaced | has duplicate 0002721 |
| 2021-02-20 14:08 | Kunda1 | Tag Attached: toponaming |
