| 0001215 | FreeCAD | Bug | public | 2013-08-15 09:02 | 2013-12-29 13:55 |
| Reporter | nahshon | Assigned To | wmayer | ||
| Priority | normal | Severity | crash | Reproducibility | sometimes |
| Summary | 0001215: Sweeping along a helix causes exception | ||||
| Description | Use "Created primitives..." from the Part menu to create an ellipse and a helix. Ellipse parameters (on XY plane): Major radius 4.0 Minor radius 2.0 Angle 1 0.0 Angle 2 360.0 Helix parameters (extends along the Z axis): Pitch 5.0 Height 200.0 Radius 5.0 Angle 0.0 then use the Sweep tool to sweep the ellipse along the helix. In the sweep tool set (check) the "Create Solid" and the "Frenet" options. Result (in most cases) segmentation fault in OpenCASCADE code. If an exception does not happen immediately, change the Helix parameters from the Data tab and refresh. Gdb stack trace: Program received signal SIGSEGV, Segmentation fault. 0xa595035d in BRepFill_Sweep::BuildShell(BRepFill_TransitionStyle, int, int, double, double) () from /lib/libTKBool.so.5 (gdb) where #0 0xa595035d in BRepFill_Sweep::BuildShell(BRepFill_TransitionStyle, int, int, double, double) () from /lib/libTKBool.so.5 #1 0xa5952002 in BRepFill_Sweep::Build(BRepFill_TransitionStyle, GeomFill_ApproxStyle, GeomAbs_Shape, int, int) () from /lib/libTKBool.so.5 0000002 0xa59e434b in BRepFill_PipeShell::Build() () from /lib/libTKBool.so.5 0000003 0x4a522211 in BRepOffsetAPI_MakePipeShell::Build() () from /lib/libTKOffset.so.5 0000004 0xa6262cb6 in Part::Sweep::execute (this=0x9962428) at /home/itai/FreeCAD-src/FreeCAD/src/Mod/Part/App/PartFeatures.cpp:406 0000005 0xb74372b5 in App::DocumentObject::recompute (this=0x9962428) at /home/itai/FreeCAD-src/FreeCAD/src/App/DocumentObject.cpp:85 0000006 0xa6265fcb in Part::Feature::recompute (this=0x9962428) at /home/itai/FreeCAD-src/FreeCAD/src/Mod/Part/App/PartFeature.cpp:81 0000007 0xb73f579a in App::Document::_recomputeFeature (this=0xa0fe190, Feat=0x9962428) at /home/itai/FreeCAD-src/FreeCAD/src/App/Document.cpp:1306 0000008 0xb73f5484 in App::Document::recompute (this=0xa0fe190) at /home/itai/FreeCAD-src/FreeCAD/src/App/Document.cpp:1273 0000009 0xa6589b3a in PartGui::SweepWidget::accept (this=0xa5ed008) at /home/itai/FreeCAD-src/FreeCAD/src/Mod/Part/Gui/TaskSweep.cpp:186 0000010 0xa658a3e8 in PartGui::TaskSweep::accept (this=0xa5a4458) at /home/itai/FreeCAD-src/FreeCAD/src/Mod/Part/Gui/TaskSweep.cpp:250 0000011 0xb7adcc98 in Gui::TaskView::TaskView::accept (this=0x846eec0) at /home/itai/FreeCAD-src/FreeCAD/src/Gui/TaskView/TaskView.cpp:484 0000012 0xb7add10a in Gui::TaskView::TaskView::qt_static_metacall (_o=0x846eec0, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0xbfffda58) at /home/itai/FreeCAD-src/build/src/Gui/TaskView/moc_TaskView.cpp:242 0000013 0xb3da271b in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /lib/libQtCore.so.4 0000014 0xb46083d6 in QDialogButtonBox::accepted() () from /lib/libQtGui.so.4 0000015 0xb46084e0 in QDialogButtonBoxPrivate::_q_handleButtonClicked() () from /lib/libQtGui.so.4 0000016 0xb3da271b in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /lib/libQtCore.so.4 0000017 0xb48c52ee in QAbstractButton::clicked(bool) () from /lib/libQtGui.so.4 0000018 0xb45d7a52 in QAbstractButtonPrivate::emitClicked() () from /lib/libQtGui.so.4 0000019 0xb45d8ea8 in QAbstractButtonPrivate::click() () from /lib/libQtGui.so.4 0000020 0xb45d8fae in QAbstractButton::mouseReleaseEvent(QMouseEvent*) () from /lib/libQtGui.so.4 0000021 0xb4215bd4 in QWidget::event(QEvent*) () from /lib/libQtGui.so.4 0000022 0xb45da042 in QAbstractButton::event(QEvent*) () from /lib/libQtGui.so.4 0000023 0xb4676aed in QPushButton::event(QEvent*) () from /lib/libQtGui.so.4 0000024 0xb41bae94 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /lib/libQtGui.so.4 0000025 0xb41c35dc in QApplication::notify(QObject*, QEvent*) () from /lib/libQtGui.so.4 0000026 0xb78d3840 in Gui::GUIApplication::notify (this=0xbfffe68c, receiver=0xa5e4f78, event=0xbfffe144) at /home/itai/FreeCAD-src/FreeCAD/src/Gui/Application.cpp:1510 0000027 0xb3d8d53a in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /lib/libQtCore.so.4 0000028 0xb41c1224 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /lib/libQtGui.so.4 0000029 0xb4242908 in QETWidget::translateMouseEvent(_XEvent const*) () from /lib/libQtGui.so.4 0000030 0xb4240ff3 in QApplication::x11ProcessEvent(_XEvent*) () from /lib/libQtGui.so.4 0000031 0xb426bdeb in x11EventSourceDispatch(_GSource*, int (*)(void*), void*) () from /lib/libQtGui.so.4 0000032 0xb368e0f6 in g_main_context_dispatch () from /lib/libglib-2.0.so.0 0000033 0xb368e4a8 in g_main_context_iterate.isra.21 () from /lib/libglib-2.0.so.0 0000034 0xb368e569 in g_main_context_iteration () from /lib/libglib-2.0.so.0 0000035 0xb3dbd660 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib/libQtCore.so.4 0000036 0xb426bf9f in QGuiEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib/libQtGui.so.4 0000037 0xb3d8bf44 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib/libQtCore.so.4 0000038 0xb3d8c281 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib/libQtCore.so.4 #39 0xb3d91d1f in QCoreApplication::exec() () from /lib/libQtCore.so.4 #40 0xb41b92e5 in QApplication::exec() () from /lib/libQtGui.so.4 0000041 0xb78cece9 in Gui::Application::runApplication () at /home/itai/FreeCAD-src/FreeCAD/src/Gui/Application.cpp:1766 0000042 0x0804f466 in main (argc=1, argv=0xbfffeea4) at /home/itai/FreeCAD-src/FreeCAD/src/Main/MainGui.cpp:310 (gdb) | ||||
| Additional Information | Fedora 19, 32 bit FreeCAD 0.14, Libs: 0.14R2393 (Git) OCE-devel-0.11-2.fc19.i686 OCE-ocaf-0.11-2.fc19.i686 OCE-modeling-0.11-2.fc19.i686 OCE-foundation-0.11-2.fc19.i686 OCE-visualization-0.11-2.fc19.i686 OCE-draw-0.11-2.fc19.i686 python-2.7.5-3.fc19.i686 Coin2-2.5.0-18.fc19.i686 qt-4.8.5-5.fc19.i686 SoQt-1.5.0-9.fc19.i686 This bug is possibly related to 0000954. | ||||
| 2013-08-15 09:02 | nahshon | New Issue | |
| 2013-12-29 13:54 | wmayer | Assigned To | => wmayer |
| 2013-12-29 13:54 | wmayer | Status | new => assigned |
| 2013-12-29 13:54 | wmayer | Relationship added | related to 0000954 |
| 2013-12-29 13:55 | wmayer | Note Added: 0003988 | |
| 2013-12-29 13:55 | wmayer | Status | assigned => closed |
| 2013-12-29 13:55 | wmayer | Resolution | open => fixed |
| 2013-12-29 13:55 | wmayer | Fixed in Version | => 0.14 |
