| 0002540 | FreeCAD | Bug | public | 2016-05-06 12:24 | 2017-07-11 20:06 |
| Reporter | dema | Assigned To | |||
| OS | Linux | OS Version | Gentoo | ||
| Summary | 0002540: Crash on startup | ||||
| Description | Latest version from git "FreeCAD 0.17, Libs: 0.17R7475 (Git)" crashes on startup. Under gdb it shows blank splash screen and crashes. gdb's "bt full" dump is in the attachment | ||||
| Steps To Reproduce | Just launch it. | ||||
| Additional Information | I have following relevant packages installed: dev-qt/qtgui-4.8.7 dev-qt/qtopengl-4.8.7 dev-qt/qtcore-4.8.7-r2 | ||||
To me it looks like a problem with Qt because there is a long cascade of Qt function calls. Did it work with older FreeCAD versions but using the exact same Qt version? When starting it from the console are there any output messages that are not FreeCAD-related? |
Yep, this is what I'm getting in the debugger: (gdb) run Starting program: /home/dema/tmp/freecad-build/bin/FreeCAD [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib64/libthread_db.so.1". FreeCAD 0.17, Libs: 0.17R7518 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## using visual class 4, id b1 Attach observer 0xaea7c0 Attach observer 0xafa110 Attach observer 0x1f504b0 Attach observer 0x1fbeb88 Attach observer 0x1fd35b8 Attach observer 0x1fd35b8 Attach observer 0x1fdd210 hijackWindow() context created for Gui::SplashScreen(0x25e5b50) 1 Program received signal SIGSEGV, Segmentation fault. 0x00007ffff1980808 in QWidgetPrivate::drawWidget (this=0x260b5b0, pdev=0x0, rgn=..., offset=..., flags=flags@entry=5, sharedPainter=sharedPainter@entry=0x0, backingStore=0x25ed950) at /var/tmp/portage/dev-qt/qtgui-4.8.7/work/qt-everywhere-opensource-src-4.8.7/src/gui/kernel/qwidget.cpp:5555 5555 QPaintEngine *paintEngine = pdev->paintEngine(); (gdb) p pdev $1 = (QPaintDevice *) 0x0 (gdb) up #1 0x00007ffff1b506e2 in QWidgetBackingStore::sync (this=0x25ed950) at /var/tmp/portage/dev-qt/qtgui-4.8.7/work/qt-everywhere-opensource-src-4.8.7/src/gui/painting/qbackingstore.cpp:1373 1373 tlw->d_func()->drawWidget(windowSurface->paintDevice(), dirtyCopy, tlwOffset, flags, 0, this); (gdb) p windowSurface $2 = (QWindowSurface *) 0x20782e0 (gdb) p windowSurface->paintDevice() warning: RTTI symbol not found for class 'QGLWindowSurface' warning: RTTI symbol not found for class 'QGLWindowSurface' warning: RTTI symbol not found for class 'QGLWindowSurface' $3 = (QPaintDevice *) 0x0 (gdb) Looks like some error in qtgl code. |
@dema is this still reproducible for you with Qt5 ? |
I'm sorry, I'm unable to compile latest FreeCAD due to missing libmed library on Gentoo. |
You can disable the FEM and MeshPart modules in order to avoid building the smesh library. |
dema, do you know how to do that ? |
@dema ping |
Looks like I unable to build FreeCAD with qt5 on gentoo yet. Gentoo doesn't have shiboken2 library yet. There is only 1.2.2 version. qt4 build is still failing. |
@dema I apologize but my question about qt5 was misleading. I don't think FC is ready to be built with Qt5 yet. Instead can you check building the way @wmayer asked in 0002540:0007662 ? > You can disable the FEM and MeshPart modules in order to avoid building the smesh library. |
Also moving forward please also include the Help > About FreeCAD > 'Copy to clipboard' data in your tickets |
Sorry, I meant that freecad built with qt4 is crashing in the same spot. If I comment out this line, it works. Index: freecad-9999/src/Gui/Splashscreen.cpp =================================================================== --- freecad-9999.orig/src/Gui/Splashscreen.cpp +++ freecad-9999/src/Gui/Splashscreen.cpp @@ -134,7 +134,7 @@ public: return; } - splash->showMessage(msg.replace(QLatin1String("\n"), QString()), alignment, textColor); + //splash->showMessage(msg.replace(QLatin1String("\n"), QString()), alignment, textColor); QMutex mutex; QMutexLocker ml(&mutex); QWaitCondition().wait(&mutex, 50); Here is there info from About screen: OS: "Gentoo Base System release 2.3" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9795 (Git) Build type: Debug Branch: master Hash: d9dda3fa1d26915bef1508c4bc31f3a7ef270dfe Python version: 2.7.12 Qt version: 4.8.6 Coin version: 3.1.3 OCC version: 6.9.0 |
Here is the "bt" log from gdb debugger Attach observer 0xc45768 Attach observer 0xc9ab10 hijackWindow() context created for Gui::SplashScreen(0xbe4030) 1 Program received signal SIGSEGV, Segmentation fault. 0x00007ffff03f93e8 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) () from /usr/lib64/qt4/libQtGui.so.4 (gdb) bt #0 0x00007ffff03f93e8 in QWidgetPrivate::drawWidget(QPaintDevice*, QRegion const&, QPoint const&, int, QPainter*, QWidgetBackingStore*) () from /usr/lib64/qt4/libQtGui.so.4 #1 0x00007ffff05c8fdd in QWidgetBackingStore::sync() () from /usr/lib64/qt4/libQtGui.so.4 0000002 0x00007ffff03ed9c0 in QWidgetPrivate::syncBackingStore() () from /usr/lib64/qt4/libQtGui.so.4 0000003 0x00007ffff03ff050 in QWidget::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000004 0x00007ffff07fe932 in QSplashScreen::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000005 0x00007ffff03aad5c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000006 0x00007ffff03b197b in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000007 0x00007ffff72151f0 in Gui::GUIApplication::notify (this=0x7fffffffc160, receiver=0xbe4030, event=0x7fffffff8cc0) at /home/dema/tmp/FreeCAD/src/Gui/GuiApplication.cpp:91 0000008 0x00007fffef8e766d in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/qt4/libQtCore.so.4 0000009 0x00007ffff05ca8d4 in QWidgetBackingStore::markDirty(QRect const&, QWidget*, bool, bool) () from /usr/lib64/qt4/libQtGui.so.4 0000010 0x00007ffff03ee055 in QWidget::repaint(QRect const&) () from /usr/lib64/qt4/libQtGui.so.4 0000011 0x00007ffff03ee0a3 in QWidget::repaint() () from /usr/lib64/qt4/libQtGui.so.4 0000012 0x00007ffff07fe1b9 in QSplashScreen::repaint() () from /usr/lib64/qt4/libQtGui.so.4 0000013 0x00007ffff758d304 in Gui::SplashObserver::Log (this=0x12dea20, s=0x7fffffff8ee0 "hijackWindow() context created for Gui::SplashScreen(0xbe4030) 1 \n") at /home/dema/tmp/FreeCAD/src/Gui/Splashscreen.cpp:143 0000014 0x00007ffff758d0c4 in Gui::SplashObserver::Message (this=0x12dea20, s=0x7fffffff8ee0 "hijackWindow() context created for Gui::SplashScreen(0xbe4030) 1 \n") at /home/dema/tmp/FreeCAD/src/Gui/Splashscreen.cpp:112 0000015 0x00007ffff5f2e4bb in Base::ConsoleSingleton::NotifyMessage (this=0x6a13d0, sMsg=0x7fffffff8ee0 "hijackWindow() context created for Gui::SplashScreen(0xbe4030) 1 \n") at /home/dema/tmp/FreeCAD/src/Base/Console.cpp:317 0000016 0x00007ffff5f2dff5 in Base::ConsoleSingleton::Message (this=0x6a13d0, pMsg=0x7ffff7659978 "%s\n") at /home/dema/tmp/FreeCAD/src/Base/Console.cpp:177 0000017 0x00007ffff71a4f63 in messageHandler (type=QtDebugMsg, msg=0x238e708 "hijackWindow() context created for Gui::SplashScreen(0xbe4030) 1 ") at /home/dema/tmp/FreeCAD/src/Gui/Application.cpp:1321 0000018 0x00007fffef7ceb96 in qt_message_output(QtMsgType, char const*) () from /usr/lib64/qt4/libQtCore.so.4 0000019 0x00007ffff2b5feed in QDebug::~QDebug (this=0x7fffffff9fc0, __in_chrg=<optimized out>) at ../../include/QtCore/../../../qt-everywhere-opensource-src-4.8.6/src/corelib/io/qdebug.h:85 0000020 QGLWindowSurface::hijackWindow (this=this@entry=0xd057e0, widget=<optimized out>) at /var/tmp/portage/dev-qt/qtopengl-4.8.6-r1/work/qt-everywhere-opensource-src-4.8.6/src/opengl/qwindowsurface_gl.cpp:478 0000021 0x00007ffff2b61773 in QGLWindowSurface::updateGeometry (this=this@entry=0xd057e0) at /var/tmp/portage/dev-qt/qtopengl-4.8.6-r1/work/qt-everywhere-opensource-src-4.8.6/src/opengl/qwindowsurface_gl.cpp:926 0000022 0x00007ffff2b626b8 in QGLWindowSurface::beginPaint (this=0xd057e0) at /var/tmp/portage/dev-qt/qtopengl-4.8.6-r1/work/qt-everywhere-opensource-src-4.8.6/src/opengl/qwindowsurface_gl.cpp:514 0000023 0x00007ffff05c8c81 in QWidgetBackingStore::sync() () from /usr/lib64/qt4/libQtGui.so.4 0000024 0x00007ffff03ed9c0 in QWidgetPrivate::syncBackingStore() () from /usr/lib64/qt4/libQtGui.so.4 0000025 0x00007ffff03ff050 in QWidget::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000026 0x00007ffff07fe932 in QSplashScreen::event(QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000027 0x00007ffff03aad5c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000028 0x00007ffff03b197b in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/qt4/libQtGui.so.4 0000029 0x00007ffff72151f0 in Gui::GUIApplication::notify (this=0x7fffffffc160, receiver=0xbe4030, event=0x7fffffffaa40) at /home/dema/tmp/FreeCAD/src/Gui/GuiApplication.cpp:91 0000030 0x00007fffef8e766d in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/qt4/libQtCore.so.4 0000031 0x00007ffff05ca924 in QWidgetBackingStore::markDirty(QRect const&, QWidget*, bool, bool) () from /usr/lib64/qt4/libQtGui.so.4 0000032 0x00007ffff03ee055 in QWidget::repaint(QRect const&) () from /usr/lib64/qt4/libQtGui.so.4 0000033 0x00007ffff03ee0a3 in QWidget::repaint() () from /usr/lib64/qt4/libQtGui.so.4 0000034 0x00007ffff07fe1b9 in QSplashScreen::repaint() () from /usr/lib64/qt4/libQtGui.so.4 0000035 0x00007ffff758d304 in Gui::SplashObserver::Log (this=0x12dea20, s=0x7fffffffac40 "Run Gui init script\n") at /home/dema/tmp/FreeCAD/src/Gui/Splashscreen.cpp:143 0000036 0x00007ffff5f2e6f5 in Base::ConsoleSingleton::NotifyLog (this=0x6a13d0, sMsg=0x7fffffffac40 "Run Gui init script\n") at /home/dema/tmp/FreeCAD/src/Base/Console.cpp:341 ---Type <return> to continue, or q <return> to quit---q "Run Gui init script\n" is a pretty innocent line :) |
Posted to forum: https://forum.freecadweb.org/viewtopic.php?f=4&t=20187 |
@wmayer writes in https://forum.freecadweb.org/viewtopic.php?f=4&t=20187&p=155831#p155831 > Thanks for the log file. When looking into it I found a suspicious line
> which apparently comes from Qt and is raised when trying to create a GL context. I wonder why Qt tries to that for a normal widget. According to http://stackoverflow.com/questions/8793303/hijackwindow-context-created-for you should pass
> on the command line when starting FreeCAD. |
Yep, my default graphics system was set to opengl. If I run FC with QT_GRAPHICSSYSTEM=raster it works flawlessly! That's why FC was not crashing on my other computer, because it was set to default there. |
I don't know what we can do on this since IMO it looks like a Qt bug. |
@wmayer I'm resolving since this seems to be a Qt4 issue and we have a workaround. Resolved as 'no change required' Thanks for all the work! |
FYI, when I set
under Ubuntu 14.04 then FreeCAD crashes for me too. Qt is 4.8.6. |
There was a bug that you couldn't set the graphic system from command line. This is fixed now and can be done with
I also looked for a way to read out which graphic system Qt uses to disable "showMessage" if it's OpenGL but the API doesn't offer a direct way. However, since it's OpenGL it creates a context and this can be used to distinguish between raster, native or opengl mode. So, now FreeCAD doesn't crash at startup any more. But also note that opengl mode may cause other problems. But the Qt doc clearly says that this mode is experimental: http://doc.qt.io/qt-4.8/qapplication.html#setGraphicsSystem |
FreeCAD: master a240f5dd 2017-01-27 22:53:48 Details Diff |
issue 0002540: Crash on startup |
Affected Issues 0002540 |
FreeCAD: master 0df4af4b 2017-01-27 23:14:15 Details Diff |
| mod - src/Gui/Splashscreen.cpp | Diff File | ||
| 2016-05-06 12:24 | dema | New Issue | |
| 2016-05-06 12:24 | dema | File Added: freecad_gdb.log | |
| 2016-05-06 16:02 | wmayer | Note Added: 0007063 | |
| 2016-05-12 06:44 | dema | Note Added: 0007084 | |
| 2017-01-09 19:16 | Kunda1 | Note Added: 0007583 | |
| 2017-01-11 18:43 | Kunda1 | Status | new => feedback |
| 2017-01-12 06:30 | dema | Note Added: 0007661 | |
| 2017-01-12 06:30 | dema | Status | feedback => new |
| 2017-01-12 08:46 | wmayer | Note Added: 0007662 | |
| 2017-01-12 15:48 | Kunda1 | Status | new => feedback |
| 2017-01-13 22:07 | Kunda1 | Note Added: 0007735 | |
| 2017-01-23 20:33 | Kunda1 | Note Added: 0007921 | |
| 2017-01-24 11:29 | dema | Note Added: 0007950 | |
| 2017-01-24 11:29 | dema | Status | feedback => new |
| 2017-01-24 12:31 | Kunda1 | File Added: freecad_gdb.txt | |
| 2017-01-24 12:31 | Kunda1 | File Deleted: freecad_gdb.log | |
| 2017-01-24 12:34 | Kunda1 | Note Added: 0007952 | |
| 2017-01-24 12:34 | Kunda1 | Status | new => feedback |
| 2017-01-24 12:35 | Kunda1 | Note Added: 0007954 | |
| 2017-01-24 13:59 | dema | Note Added: 0007959 | |
| 2017-01-24 13:59 | dema | Status | feedback => new |
| 2017-01-24 14:00 | dema | Note Added: 0007960 | |
| 2017-01-24 15:16 | Kunda1 | Note Added: 0007961 | |
| 2017-01-24 15:28 | Kunda1 | Tag Attached: #pending | |
| 2017-01-25 12:14 | Kunda1 | Note Added: 0007975 | |
| 2017-01-25 12:14 | Kunda1 | Status | new => feedback |
| 2017-01-25 12:29 | dema | Note Added: 0007977 | |
| 2017-01-25 12:29 | dema | Status | feedback => new |
| 2017-01-27 11:34 | wmayer | Note Added: 0008019 | |
| 2017-01-27 11:55 | Kunda1 | Note Added: 0008023 | |
| 2017-01-27 11:55 | Kunda1 | Status | new => resolved |
| 2017-01-27 11:55 | Kunda1 | Resolution | open => no change required |
| 2017-01-27 11:55 | Kunda1 | Assigned To | => Kunda1 |
| 2017-01-27 11:55 | Kunda1 | Assigned To | Kunda1 => |
| 2017-01-27 18:15 | wmayer | Note Added: 0008030 | |
| 2017-01-27 22:54 | wmayer | Changeset attached | => FreeCAD Master master a240f5dd |
| 2017-01-27 23:14 | wmayer | Changeset attached | => FreeCAD Master master 0df4af4b |
| 2017-01-27 23:19 | wmayer | Note Added: 0008033 | |
| 2017-01-27 23:19 | wmayer | Status | resolved => closed |
| 2017-01-27 23:19 | wmayer | Resolution | no change required => fixed |
| 2017-01-27 23:19 | wmayer | Fixed in Version | => 0.17 |
| 2017-07-11 20:06 | Kunda1 | Tag Detached: #pending |
