| Description | application crashes when create wall object from 2-point line or restangle.
Приложение падает при попытке создать стену из линии, прямоугольника, многоугольника, окружности ets...
Is observed only in the Russian localization.
https://youtu.be/nsdc26lCarc (link to effect demonstration)
~ $ freecad
FreeCAD 0.17, Libs: 0.17R13509 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Fasteners workbench Loaded
Sheet Metal workbench loaded
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7fc132fad4b0]
#1 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyString_AsString+0x4) [0x7fc134bb7844]
0000002 0x7fc13551e720 in App::DocumentPy::openTransaction(_object*) from /usr/lib/freecad/lib/libFreeCADApp.so+0x140
0000003 0x7fc13551e7e7 in App::DocumentPy::staticCallback_openTransaction(_object*, _object*) from /usr/lib/freecad/lib/libFreeCADApp.so+0x37
0000004 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x8a51) [0x7fc134b73971]
0000005 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x85c) [0x7fc134ca905c]
0000006 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(+0x13e370) [0x7fc134bff370]
0000007 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fc134bd2273]
0000008 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(+0x1853ac) [0x7fc134c463ac]
0000009 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyObject_Call+0x43) [0x7fc134bd2273]
0000010 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_CallObjectWithKeywords+0x47) [0x7fc134ca8487]
0000011 /usr/lib/freecad/lib/libFreeCADBase.so(PP_Run_Method+0xe7) [0x7fc1351716c7]
0000012 0x7fc1350fc8f9 in Base::InterpreterSingleton::runMethodVoid(_object*, char const*) from /usr/lib/freecad/lib/libFreeCADBase.so+0x29
0000013 0x7fc135c1aace in Gui::PythonCommand::activated(int) from /usr/lib/freecad/lib/libFreeCADGui.so+0x9e
0000014 0x7fc135c1d63c in Gui::Command::invoke(int) from /usr/lib/freecad/lib/libFreeCADGui.so+0x7c
0000015 0x7fc133a78f80 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x4d0
0000016 0x7fc133f8ad62 in QAction::triggered(bool) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x42
0000017 0x7fc133f8c0b3 in QAction::activate(QAction::ActionEvent) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x83
0000018 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x5a0cd3) [0x7fc13436ccd3]
0000019 0x7fc13436ce24 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x74
0000020 0x7fc134432dea in QToolButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0xa
0000021 0x7fc133fe78d0 in QWidget::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x2a0
0000022 0x7fc133f90fdc in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x8c
0000023 0x7fc133f980d6 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x476
0000024 0x7fc135bf8464 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x54
0000025 0x7fc133a648bd in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x8d
0000026 0x7fc133f976dd in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x14d
0000027 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x2493f2) [0x7fc1340153f2]
0000028 0x7fc134014c83 in QApplication::x11ProcessEvent(_XEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x16b3
0000029 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272542) [0x7fc13403e542]
0000030 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2a7) [0x7fc12c6cc197]
0000031 /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4a3f0) [0x7fc12c6cc3f0]
0000032 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7fc12c6cc49c]
0000033 0x7fc133a9521e in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x7e
0000034 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272616) [0x7fc13403e616]
0000035 0x7fc133a6313f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x3f
0000036 0x7fc133a634a5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x1b5
0000037 0x7fc133a69469 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x99
0000038 0x7fc135bb1240 in Gui::Application::runApplication() from /usr/lib/freecad/lib/libFreeCADGui.so+0x15b0
#39 freecad(main+0x8b4) [0x403804]
#40 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fc132f98830]
0000041 freecad(_start+0x29) [0x404a49]
Укажите первую точку Укажите следующую точку cynabr@linux-2mol ~ $
