| 0000620 | FreeCAD | Bug | public | 2012-03-04 00:06 | 2012-03-11 08:53 |
| Reporter | djreichel | Assigned To | |||
| Summary | 0000620: Help -> About FreeCAD crashes program | ||||
| Description | launching "About FreeCAD" crashes. "About Qt" works fine. strace shows FreeCAD trying to load a missing image file "splash-image.png" I was not able to locate that in the source distribution. Copying another png file to that filename did not result in any change. The last thing FreeCAD appeared to do before crashing was to access /etc/localtime Fedora 16 | ||||
| Additional Information | Strace dump: stat64("/home/dennis/.FreeCAD/pixmaps/splash_image.png", {st_mode=S_IFREG|0644, st_size=66177, ...}) = 0 stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=3519, ...}) = 0 stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=3519, ...}) = 0 rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0 tgkill(18501, 18501, SIGABRT) = 0 --- {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=18501, si_uid=1000} (Aborted) --- write(1, "\33[1;31mAbnormal program terminat"..., 50Abnormal program termination... ) = 50 munmap(0xb2344000, 34756) = 0 write(5, "@", 1) = 1 close(5) = 0 close(4) = 0 rt_sigaction(SIGCHLD, NULL, {0x44cffcb0, [], SA_NOCLDSTOP}, 8) = 0 rt_sigaction(SIGCHLD, {SIG_DFL, [], 0}, NULL, 8) = 0 write(1, "\33[0m", 4) = 4 exit_group(3) = ? [dennis@verne .FreeCAD]$ | ||||
What version of FreeCAD do you have? Have you built it yourself? What is the Qt version? When starting FreeCAD does the splash screen appear normally? In FreeCAD it's possible to set an own splash screen. This can be done by creating this file: $HOME/.FreeCAD/pixmaps/splash_image.png When loading the splash image we check first the above file and I assume there might be a Qt issue which makes the application crashing. |
Here is a little demo example. You can build it with: qmake -project qmake <project_file>.pro # replace project_file with the actual name make run the executable #include <QtCore> #include <iostream> int main(int argc, char** argv) { QDir dir(QString::fromUtf8("/home/dennis/.FreeCAD")); QFileInfo fi(dir.filePath(QString::fromAscii("pixmaps/splash_image.png"))); if (fi.isFile() && fi.exists()) std::cout << "File is there!"; else std::cout << "File is not there!"; return 0; } |
This has crashed here with git snapshots for the past week. (previous to that I had not built and installed FreeCAD) And to clarify further, launching "Help->About.." did crash with or without the splash_image.png file in place. I'm using Qt4. When I saw that the trace was looking for $HOME/.FreeCAD/pixmaps/splash_image.png I created that file (which is now displayed while FreeCAD is loading) The test program you posted failed to complile (did not find QtCore) using qmake to set up Makefile. It did build and run successfully using qmake-qt4. (the result was "File is there!") From Makefile: INCPATH = -I/usr/lib/qt4/mkspecs/linux-g++ -I. -I/usr/include/QtCore -I/usr/include/QtGui -I/usr/include -I. -I. LINK = g++ LFLAGS = -Wl,-O1 LIBS = $(SUBLIBS) -L/usr/lib -lQtGui -lQtCore -lpthread AR = ar cqs RANLIB = QMAKE = /usr/bin/qmake-qt4 |
That's really odd. I don't see what's causing this crash. Maybe you can test this modified example: #include <QtCore> #include <iostream> #include <stdlib.h> QString myDecoderFunc(const QByteArray &localFileName) { QTextCodec* codec = QTextCodec::codecForName("UTF-8"); return codec->toUnicode(localFileName); } QByteArray myEncoderFunc(const QString &fileName) { QTextCodec* codec = QTextCodec::codecForName("UTF-8"); return codec->fromUnicode(fileName); } int main(int argc, char** argv) { (void)QLocale::system(); QFile::setEncodingFunction(myEncoderFunc); QFile::setDecodingFunction(myDecoderFunc); putenv("LANG=C"); putenv("LC_ALL=C"); QDir dir(QString::fromUtf8("/home/dennis/.FreeCAD")); QFileInfo fi(dir.filePath(QString::fromAscii("pixmaps/splash_image.png"))); if (fi.isFile() && fi.exists()) std::cout << "File is there!"; else std::cout << "File is not there!"; return 0; } |
the new code with the unicode testing works fine.. [dennis@verne test_wmayer2]$ qmake-qt4 -project [dennis@verne test_wmayer2]$ qmake-qt4 [dennis@verne test_wmayer2]$ make g++ -c -pipe -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom -fasynchronous-unwind-tables -O2 -Wall -W -D_REENTRANT -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/lib/qt4/mkspecs/linux-g++ -I. -I/usr/include/QtCore -I/usr/include/QtGui -I/usr/include -I. -I. -o test_wmayer2.o test_wmayer2.cpp test_wmayer2.cpp: In function ‘int main(int, char**)’: test_wmayer2.cpp:22:21: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings] test_wmayer2.cpp:23:23: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings] test_wmayer2.cpp: At global scope: test_wmayer2.cpp:17:5: warning: unused parameter ‘argc’ [-Wunused-parameter] test_wmayer2.cpp:17:5: warning: unused parameter ‘argv’ [-Wunused-parameter] g++ -Wl,-O1 -o test_wmayer2 test_wmayer2.o -L/usr/lib -lQtGui -lQtCore -lpthread [dennis@verne test_wmayer2]$ ./test_wmayer2 File is there! [dennis@verne test_wmayer2]$ |
Is it an option to compile the FreeCAD sources and run it in the debugger? This way we should get a more detailed error description than what we have now. |
I added some qDebug() diagnostic output to SplashScreen.cpp and built with --enable-loginfo. Attach observer 0x895dec0 Attach observer 0x8949540 Attach observer 0x8955ba8 Attach observer 0x8997604 Attach observer 0x89df674 Attach observer 0x89df674 Attach observer 0x89eba70 Attach observer 0x89fb290 * diagnostic message from within SplashObserver.. loaded the Generic plugin * const AboutDialogFactory *AboutDialogFactory::defaultFactory() * QDialog *AboutDialogFactory::create(QWidget *parent) const * Entering AboutDialog::AboutDialog * Leaving AboutDialog::AboutDialog QSharedPointer: pointer 0x8e2a9d8 already has reference counting Abnormal program termination... [dennis@verne ~]$ I'll try running in gdb. |
Here's the console output and backtrace of a session ending with a crash at Help -> About FreeCAD (note: the lines beginnging with "*" are QtDebug diagnostic messages I added to some SplashScreen methods.) GNU gdb (GDB) Fedora (7.3.50.20110722-10.fc16) Copyright (C) 2011 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "i686-redhat-linux-gnu". For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/> Reading symbols from /home/dennis/.FreeCAD/freecad-0.12...Reading symbols from /usr/lib/debug/usr/bin/freecad-0.12.debug...done. done. (gdb) run Starting program: /home/dennis/.FreeCAD/freecad-0.12 warning: "/usr/lib/debug/usr/lib/libQt3Support.so.4.8.0.debug": separate debug info file has no debug info [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/libthread_db.so.1". warning: "/usr/lib/debug/usr/lib/libicudata.so.46.0.debug": separate debug info file has no debug info FreeCAD 0.12, Libs: 0.12R5382 © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Attach observer 0x82f7d88 Attach observer 0x82fd5c0 Attach observer 0x8303590 Attach observer 0x8382ffc Attach observer 0x8388c34 Attach observer 0x8388c34 Attach observer 0x83a3358 Attach observer 0x83acf48 [New Thread 0xb6e39b40 (LWP 16824)] * diagnostic message from within SplashObserver.. [New Thread 0xb5ab8b40 (LWP 16827)] [New Thread 0xb518fb40 (LWP 16828)] loaded the Generic plugin [New Thread 0xae20cb40 (LWP 16829)] [New Thread 0xad8ffb40 (LWP 16830)] [New Thread 0xad0feb40 (LWP 16831)] loaded the Generic plugin [New Thread 0xae20cb40 (LWP 16829)] [New Thread 0xad8ffb40 (LWP 16830)] [New Thread 0xad0feb40 (LWP 16831)] * const AboutDialogFactory *AboutDialogFactory::defaultFactory() QDialog *AboutDialogFactory::create(QWidget *parent) const * Entering AboutDialog::AboutDialog * Leaving AboutDialog::AboutDialog QSharedPointer: pointer 0x8380698 already has reference counting Program received signal SIGABRT, Aborted. 0xb7fff424 in __kernel_vsyscall () (gdb) bt #0 0xb7fff424 in __kernel_vsyscall () #1 0x43b1498f in __GI_raise (sig=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:64 0000002 0x43b162d5 in __GI_abort () at abort.c:91 0000003 0x422568fc in messageHandler (type=QtFatalMsg, msg= 0x8879a78 "QSharedPointer: pointer 0x8380698 already has reference counting") at Application.cpp:1316 0000004 0x44c08a86 in qt_message_output (msgType=QtFatalMsg, buf= 0x8879a78 "QSharedPointer: pointer 0x8380698 already has reference counting") at global/qglobal.cpp:2200 0000005 0x44c08cdd in qt_message (msgType=QtFatalMsg, msg= 0x44dd3368 "QSharedPointer: pointer %p already has reference counting", ap= 0xbfffd4b4 "\230\006\070\b\230\006\070\b\360\271\305D\350\316\202B\350f\206\b(VF\b\321\t)B\350f\206\b\230\006\070\b\001") at global/qglobal.cpp:2298 0000006 0x44c08df9 in qFatal (msg=0x44dd3368 "QSharedPointer: pointer %p already has reference counting") at global/qglobal.cpp:2481 0000007 0x44c5ba2f in QtSharedPointer::ExternalRefCountData::setQObjectShared (this=0x88666e8, obj=0x8380698) at tools/qsharedpointer.cpp:1242 0000008 0x422909d1 in QtSharedPointer::ExternalRefCount<QDialog>::internalFinishConstruction (this=0xbfffd564, ptr=0x8380698) at /usr/include/QtCore/qsharedpointer_impl.h:381 0000009 0x422908ef in QtSharedPointer::ExternalRefCount<QDialog>::internalConstruct (this=0xbfffd564, ptr=0x8380698) at /usr/include/QtCore/qsharedpointer_impl.h:357 0000010 0x4229084b in QtSharedPointer::ExternalRefCount<QDialog>::ExternalRefCount (this=0xbfffd564, ptr=0x8380698) at /usr/include/QtCore/qsharedpointer_impl.h:391 0000011 0x422905b8 in QSharedPointer<QDialog>::QSharedPointer (this=0xbfffd564, ptr=0x8380698) at /usr/include/QtCore/qsharedpointer_impl.h:473 0000012 0x4228e491 in StdCmdAbout::activated (this=0x82f80f8, iMsg=0) at CommandStd.cpp:229 0000013 0x4227ead4 in Gui::Command::invoke (this=0x82f80f8, i=0) at Command.cpp:282 0000014 0x42244fd4 in Gui::Action::onActivated (this=0x8444b90) at Action.cpp:82 0000015 0x42249c2c in Gui::Action::qt_static_metacall (_o=0x8444b90, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0xbfffd718) at moc_Action.cpp:50 0000016 0x44d3eea1 in QMetaObject::activate (sender=0x846ad30, m=0x463918d8, local_signal_index=1, argv=0xbfffd718) at kernel/qobject.cpp:3547 0000017 0x45a1b15e in QAction::triggered (this=0x846ad30, _t1=false) at .moc/release-shared/moc_qaction.cpp:277 0000018 0x45a1b3fb in QAction::activate (this=0x846ad30, event=QAction::Trigger) at kernel/qaction.cpp:1257 0000019 0x45edac9c in QMenuPrivate::activateCausedStack (this=0x8464258, causedStack=..., action=0x846ad30, action_e= QAction::Trigger, self=true) at widgets/qmenu.cpp:1028 0000020 0x45ee1b6f in QMenuPrivate::activateAction (this=0x8464258, action=0x846ad30, action_e=QAction::Trigger, self=true) at widgets/qmenu.cpp:1120 0000021 0x45ee4886 in QMenu::mouseReleaseEvent (this=0x844f198, e=0xbfffdf54) at widgets/qmenu.cpp:2351 0000022 0x45a7cf5d in QWidget::event (this=0x844f198, event=0xbfffdf54) at kernel/qwidget.cpp:8361 0000023 0x45ee32ec in QMenu::event (this=0x844f198, e=0xbfffdf54) at widgets/qmenu.cpp:2460 0000024 0x45a22134 in notify_helper (e=0xbfffdf54, receiver=0x844f198, this=0x80d0f30) at kernel/qapplication.cpp:4550 0000025 QApplicationPrivate::notify_helper (this=0x80d0f30, receiver=0x844f198, e=0xbfffdf54) at kernel/qapplication.cpp:4522 0000026 0x45a282ca in QApplication::notify (this=0x80d0f30, receiver=0x844f198, e=0xbfffdf54) at kernel/qapplication.cpp:4093 0000027 0x4225a73a in Gui::GUIApplication::notify (this=0xbfffe900, receiver=0x844f198, event=0xbfffdf54) at Application.cpp:1443 0000028 0x44d295fe in QCoreApplication::notifyInternal (this=0xbfffe900, receiver=0x844f198, event=0xbfffdf54) at kernel/qcoreapplication.cpp:876 0000029 0x45a23106 in sendEvent (event=<optimized out>, receiver=<optimized out>) at ../../src/corelib/kernel/qcoreapplication.h:231 0000030 QApplicationPrivate::sendMouseEvent (receiver=0x844f198, event=0xbfffdf54, alienWidget=0x0, nativeWidget=0x844f198, buttonDown=0x463aeed4, lastMouseReceiver=..., spontaneous=true) at kernel/qapplication.cpp:3161 0000031 0x45aad5cc in QETWidget::translateMouseEvent (this=0x844f198, event=0xbfffe40c) at kernel/qapplication_x11.cpp:4454 0000032 0x45aabe4d in QApplication::x11ProcessEvent (this=0xbfffe900, event=0xbfffe40c) at kernel/qapplication_x11.cpp:3641 0000033 0x45ad6e05 in x11EventSourceDispatch (s=0x817f548, callback=0, user_data=0x0) at kernel/qguieventdispatcher_glib.cpp:148 0000034 0x43d6c62f in g_main_dispatch (context=0x8191e20) at gmain.c:2441 0000035 g_main_context_dispatch (context=0x8191e20) at gmain.c:3011 0000036 0x43d6cd70 in g_main_context_iterate (context=0x8191e20, block=1138210832, dispatch=1, self=0x80d0e80) at gmain.c:3089 0000037 0x43d6d01f in g_main_context_iteration (context=0x8191e20, may_block=1) at gmain.c:3152 0000038 0x44d5c2b8 in QEventDispatcherGlib::processEvents (this=0x816a8a8, flags=...) at kernel/qeventdispatcher_glib.cpp:424 #39 0x45ad6a9b in QGuiEventDispatcherGlib::processEvents (this=0x816a8a8, flags=...) at kernel/qguieventdispatcher_glib.cpp:207 #40 0x44d284ee in QEventLoop::processEvents (this=0xbfffe714, flags=...) at kernel/qeventloop.cpp:149 0000041 0x44d28799 in QEventLoop::exec (this=0xbfffe714, flags=...) at kernel/qeventloop.cpp:204 0000042 0x44d2d93b in QCoreApplication::exec () at kernel/qcoreapplication.cpp:1148 0000043 0x45a1ff35 in QApplication::exec () at kernel/qapplication.cpp:3811 0000044 0x42257b66 in Gui::Application::runApplication () at Application.cpp:1659 0000045 0x0804d40a in main (argc=1, argv=0xbfffecf4) at MainGui.cpp:349 (gdb) |
So, again what is your exact Qt version (of course version 4)? It seems the implementation of QSharedPointer has changed or a bug was inserted there. In StdCmdAbout::activated() you can try this code snippet: const Gui::Dialog::AboutDialogFactory* f = Gui::Dialog::AboutDialogFactory::defaultFactory(); QSharedPointer <QDialog> dlg = QSharedPointer<QDialog>(f->create(getMainWindow())); dlg->exec(); |
According to http://blog.codef00.com/2011/12/15/not-so-much-fun-with-qsharedpointer/ the use of QSharedPointer is a bit weird. If the above suggestion fails too then simply write: const Gui::Dialog::AboutDialogFactory* f = Gui::Dialog::AboutDialogFactory::defaultFactory(); QDialog* dlg = f->create(getMainWindow()); dlg->exec(); delete dlg; |
>>So, again what is your exact Qt version (of course version 4)? It seems the >>implementation of QSharedPointer has changed or a bug was inserted there. >>In StdCmdAbout::activated() you can try this code snippet: >>const Gui::Dialog::AboutDialogFactory* f = Gui::Dialog::AboutDialogFactory::defaultFactory(); >>QSharedPointer <QDialog> dlg = QSharedPointer<QDialog (f->create(getMainWindow())); >>dlg->exec(); Fedora 16 is using Qt 4.5, but also includes certain Qt3 components for backwards compatibility. Here's the backtrace using the above snippet: 0000006 0x44c08df9 in qFatal (msg=0x44dd3368 "QSharedPointer: pointer %p already has reference counting") at global/qglobal.cpp:2481 0000007 0x44c5ba2f in QtSharedPointer::ExternalRefCountData::setQObjectShared (this=0x8378e78, obj=0x8a42d80) at tools/qsharedpointer.cpp:1242 0000008 0x4848a34b in QtSharedPointer::ExternalRefCount<QDialog>::internalFinishConstruction (this=0xbfffd544, ptr=0x8a42d80) at /usr/include/QtCore/qsharedpointer_impl.h:381 0000009 0x4848a269 in QtSharedPointer::ExternalRefCount<QDialog>::internalConstruct (this=0xbfffd544, ptr=0x8a42d80) at /usr/include/QtCore/qsharedpointer_impl.h:357 0000010 0x4848a1c5 in QtSharedPointer::ExternalRefCount<QDialog>::ExternalRefCount (this=0xbfffd544, ptr=0x8a42d80) at /usr/include/QtCore/qsharedpointer_impl.h:391 0000011 0x4848a076 in QSharedPointer<QDialog>::QSharedPointer (this=0xbfffd544, ptr=0x8a42d80) at /usr/include/QtCore/qsharedpointer_impl.h:473 0000012 0x48488301 in StdCmdAbout::activated (this=0x82ebb90, iMsg=0) at CommandStd.cpp:229 0000013 0x484785e4 in Gui::Command::invoke (this=0x82ebb90, i=0) at Command.cpp:282 0000014 0x4843dd54 in Gui::Action::onActivated (this=0x866c1a8) at Action.cpp:82 0000015 0x484429ac in Gui::Action::qt_static_metacall (_o=0x866c1a8, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0xbfffd6f8) at moc_Action.cpp:50 0000016 0x44d3eea1 in QMetaObject::activate (sender=0x859fc28, m=0x463918d8, local_signal_index=1, argv=0xbfffd6f8) at kernel/qobject.cpp:3547 0000017 0x45a1b15e in QAction::triggered (this=0x859fc28, _t1=false) at .moc/release-shared/moc_qaction.cpp:277 0000018 0x45a1b3fb in QAction::activate (this=0x859fc28, event=QAction::Trigger) at kernel/qaction.cpp:1257 0000019 0x45edac9c in QMenuPrivate::activateCausedStack (this=0x8614f48, causedStack=..., action=0x859fc28, action_e= QAction::Trigger, self=true) at widgets/qmenu.cpp:1028 0000020 0x45ee1b6f in QMenuPrivate::activateAction (this=0x8614f48, action=0x859fc28, action_e=QAction::Trigger, self=true) at widgets/qmenu.cpp:1120 0000021 0x45ee4886 in QMenu::mouseReleaseEvent (this=0x8675eb8, e=0xbfffdf34) at widgets/qmenu.cpp:2351 |
const Gui::Dialog::AboutDialogFactory* f = Gui::Dialog::AboutDialogFactory::defaultFactory(); QDialog* dlg = f->create(getMainWindow()); dlg->exec(); delete dlg; The snippet (above) without QSharedPointer works fine. |
The use of QSharedPointer is really weird. An alternative might be QScopedPointer but that is not part of Qt 4.5. Thus, I decided to use boost::scoped_ptr. I could also the raw pointer as in my last example but in case the dialog throws an exception I get a memory leak. |
Fixed in git 04cdad1db4227bc52cda1b71eefd1ed85e8e9e75 |
| 2012-03-04 00:06 | djreichel | New Issue | |
| 2012-03-04 08:33 | wmayer | Note Added: 0001706 | |
| 2012-03-04 08:43 | wmayer | Note Added: 0001707 | |
| 2012-03-04 14:45 | djreichel | Note Added: 0001710 | |
| 2012-03-04 15:25 | wmayer | Note Added: 0001711 | |
| 2012-03-05 02:06 | djreichel | Note Added: 0001712 | |
| 2012-03-06 06:19 | wmayer | Note Added: 0001715 | |
| 2012-03-06 11:32 | djreichel | Note Added: 0001716 | |
| 2012-03-08 11:42 | djreichel | Note Added: 0001725 | |
| 2012-03-08 15:54 | wmayer | Note Added: 0001726 | |
| 2012-03-08 16:18 | wmayer | Note Added: 0001727 | |
| 2012-03-08 16:22 | wmayer | Relationship added | related to 0000594 |
| 2012-03-10 00:41 | djreichel | Note Added: 0001734 | |
| 2012-03-10 01:17 | djreichel | Note Added: 0001735 | |
| 2012-03-11 08:39 | wmayer | Note Added: 0001738 | |
| 2012-03-11 08:53 | wmayer | Note Added: 0001739 | |
| 2012-03-11 08:53 | wmayer | Status | new => closed |
| 2012-03-11 08:53 | wmayer | Resolution | open => fixed |
| 2012-03-11 08:53 | wmayer | Fixed in Version | => 0.13 |
| 2012-09-19 10:44 | wmayer | Relationship added | has duplicate 0000838 |
