| 0000105 | FreeCAD | Bug | public | 2010-06-07 06:16 | 2010-06-09 11:11 |
| Summary | 0000105: Crash when using SketchExample.py | ||||
| Description | When using the sketcher example, go to edit mode and try to drag and drop a segmentation fault happens. The stack trace is: #0 0xaecc6bb3 in Sketcher::Sketch::movePoint (this=0x8a96a20, geoIndex1=0, Pos1=Sketcher::start, toPoint=...) at ../../../../../src/Mod/Sketcher/App/Sketch.cpp:465 #1 0x07fd30d8 in SketcherGui::ViewProviderSketch::mouseMove (this=0x882ca38, point=..., normal=..., pp=0x8a95888) at ../../../../../src/Mod/Sketcher/Gui/ViewProviderSketch.cpp:268 0000002 0x02ff91cd in Gui::ViewProvider::eventCallback (ud=0x882ca38, node=0x8976ed8) at ../../../src/Gui/ViewProvider.cpp:163 0000003 0x0493b404 in SoEventCallback::handleEvent(SoHandleEventAction*) () from /usr/lib/libCoin.so.60 0000004 0x04958508 in SoNode::handleEventS(SoAction*, SoNode*) () from /usr/lib/libCoin.so.60 0000005 0x046d01f0 in SoAction::traverse(SoNode*) () from /usr/lib/libCoin.so.60 0000006 0x048609d4 in SoChildList::traverse(SoAction*, int, int) () from /usr/lib/libCoin.so.60 0000007 0x04860d0a in SoChildList::traverse(SoAction*) () from /usr/lib/libCoin.so.60 0000008 0x04948f42 in SoGroup::doAction(SoAction*) () from /usr/lib/libCoin.so.60 0000009 0x049734f9 in SoSeparator::doAction(SoAction*) () from /usr/lib/libCoin.so.60 0000010 0x049735d4 in SoSeparator::handleEvent(SoHandleEventAction*) () from /usr/lib/libCoin.so.60 0000011 0x0497212c in SoSelection::handleEvent(SoHandleEventAction*) () from /usr/lib/libCoin.so.60 0000012 0x04958508 in SoNode::handleEventS(SoAction*, SoNode*) () from /usr/lib/libCoin.so.60 0000013 0x046d01f0 in SoAction::traverse(SoNode*) () from /usr/lib/libCoin.so.60 0000014 0x048609d4 in SoChildList::traverse(SoAction*, int, int) () from /usr/lib/libCoin.so.60 0000015 0x04860d0a in SoChildList::traverse(SoAction*) () from /usr/lib/libCoin.so.60 0000016 0x04948f42 in SoGroup::doAction(SoAction*) () from /usr/lib/libCoin.so.60 0000017 0x049734f9 in SoSeparator::doAction(SoAction*) () from /usr/lib/libCoin.so.60 0000018 0x049735d4 in SoSeparator::handleEvent(SoHandleEventAction*) () from /usr/lib/libCoin.so.60 0000019 0x04958508 in SoNode::handleEventS(SoAction*, SoNode*) () from /usr/lib/libCoin.so.60 0000020 0x046d01f0 in SoAction::traverse(SoNode*) () from /usr/lib/libCoin.so.60 0000021 0x048609d4 in SoChildList::traverse(SoAction*, int, int) () from /usr/lib/libCoin.so.60 0000022 0x04860d0a in SoChildList::traverse(SoAction*) () from /usr/lib/libCoin.so.60 0000023 0x04948f42 in SoGroup::doAction(SoAction*) () from /usr/lib/libCoin.so.60 0000024 0x049734f9 in SoSeparator::doAction(SoAction*) () from /usr/lib/libCoin.so.60 0000025 0x049735d4 in SoSeparator::handleEvent(SoHandleEventAction*) () from /usr/lib/libCoin.so.60 0000026 0x04958508 in SoNode::handleEventS(SoAction*, SoNode*) () from /usr/lib/libCoin.so.60 0000027 0x046d01f0 in SoAction::traverse(SoNode*) () from /usr/lib/libCoin.so.60 0000028 0x046dd9df in SoHandleEventAction::beginTraversal(SoNode*) () from /usr/lib/libCoin.so.60 0000029 0x046d0872 in SoAction::apply(SoNode*) () from /usr/lib/libCoin.so.60 0000030 0x048ee6fd in SoEventManager::actuallyProcessEvent(SoEvent const*) () from /usr/lib/libCoin.so.60 0000031 0x048ee44a in SoEventManager::processEvent(SoEvent const*) () from /usr/lib/libCoin.so.60 0000032 0x048e8dae in SoSceneManager::processEvent(SoEvent const*) () from /usr/lib/libCoin.so.60 0000033 0x0448ac31 in SoQtRenderArea::processSoEvent(SoEvent const*) () from /usr/lib/libSoQt4.so.20 0000034 0x044cd934 in SoQtViewer::processSoEvent(SoEvent const*) () from /usr/lib/libSoQt4.so.20 0000035 0x02fe06a0 in Gui::View3DInventorViewer::processSoEventBase (this=0x88af450, ev=0x88b1e18) at ../../../src/Gui/View3DInventorViewer.cpp:976 0000036 0x02efca35 in Gui::NavigationStyle::processSoEvent (this=0x8a480b8, ev=0x88b1e18) at ../../../src/Gui/NavigationStyle.cpp:883 0000037 0x02eff326 in Gui::CADNavigationStyle::processSoEvent (this=0x8a480b8, ev=0x88b1e18) at ../../../src/Gui/NavigationStyle.cpp:1594 0000038 0x02efc975 in Gui::NavigationStyle::processEvent (this=0x8a480b8, ev=0x88b1e18) at ../../../src/Gui/NavigationStyle.cpp:866 #39 0x02fe0676 in Gui::View3DInventorViewer::processSoEvent (this=0x88af450, ev=0x88b1e18) at ../../../src/Gui/View3DInventorViewer.cpp:971 #40 0x0448ebea in SoQtRenderArea::processEvent(QEvent*) () from /usr/lib/libSoQt4.so.20 0000041 0x02fe059b in Gui::View3DInventorViewer::processEvent (this=0x88af450, event=0xbfffe7f0) at ../../../src/Gui/View3DInventorViewer.cpp:952 0000042 0x04486bb9 in SoQtGLWidgetP::eventFilter(QObject*, QEvent*) () from /usr/lib/libSoQt4.so.20 0000043 0x00295cda in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) () from /usr/lib/libQtCore.so.4 0000044 0x004e14b9 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQtGui.so.4 0000045 0x004e89f7 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/libQtGui.so.4 0000046 0x02dde9f4 in Gui::GUIApplication::notify (this=0xbffff164, receiver=0x88b30a8, event=0xbfffe7f0) at ../../../src/Gui/Application.cpp:1277 0000047 0x00296a3b in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/libQtCore.so.4 0000048 0x004e7952 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () | ||||
There is a further minor issue when going to edit mode. The Coin warning is: Coin warning in SoGLLazyElement::sendDiffuseByIndex(): index 2 out of bounds [0, 1] in node 0x8eae7e8: <noname> (this warning will only be printed once, but there might be more errors) |
Sketcher is at the moment under heavy development, won't accept bug reports on sketch till the rewrite is finished.... |
| 2010-06-07 06:16 | unauthenticated | New Issue | |
| 2010-06-07 06:20 | unauthenticated | Note Added: 0000240 | |
| 2010-06-09 07:03 | wmayer | Assigned To | => Jriegel |
| 2010-06-09 07:03 | wmayer | Status | new => assigned |
| 2010-06-09 11:11 |
Note Added: 0000241 | |
| 2010-06-09 11:11 |
Status | assigned => closed |
| 2010-06-09 11:11 |
Resolution | open => won't fix |
