| 0002836 | Sketcher | Bug | public | 2017-01-08 14:15 | 2017-08-19 19:32 |
| Reporter | garnish | Assigned To | wmayer | ||
| Platform | Mac | OS | OS X | OS Version | 10.11.4 |
| Summary | 0002836: Crash in sketcher | ||||
| Description | This is further to this post: http://forum.freecad.org/viewtopic.php?f=3&t=18652&p=145434 This morning I started a new project in FreeCAD 0.17, Libs: 0.17R9172 (Git) and it crashed while editing a sketch attached to the face of another sketch. I downloaded the latest: FreeCAD 0.17, Libs: 0.17R9564 (Git) After doing 'crash recovery', I regenerated the model to the state I was in on R1972 and then FC crashed performing the same action as the first crash but saving my file first right at the point before the crash. After creating an account on the bug tracker, I tried to reproduce the crash by creating a rectangle on a sketch and it crashed exactly the same. The output is: FreeCAD 0.17, Libs: 0.17R9564 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2016 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly. Can't find Origin for "Body" Can't find Origin for "Body" Can't find Origin for "Body" Can't find Origin for "Body" Document::recompute: The graph must be a DAG. *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 The previous crash on R9564 was slightly different: *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 168 And the first crash referenced above (in R9172) was different again: *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGBUS 'bus error' detected. | ||||
| Steps To Reproduce | Draw a rectangle in the sketcher on Sketch001 that extends from the leftmost circle to the rightmost circle and is vertically within the circles and does not extend outside of the leftmost to rightmost circle. I have a screenshot but the bug tracker appears to only want me to attach a single file so I decided it would be best to attach the model instead of the screenshot. I will attempt to attach the screenshot after I file the bug. | ||||
ok. I managed to attach the screenshot. Immediately after completing the rectangle, the crash happens. This is the output from the crash as a result of making the screenshot: FreeCAD 0.17, Libs: 0.17R9564 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2016 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly. Can't find Origin for "Body" Can't find Origin for "Body" Can't find Origin for "Body" Can't find Origin for "Body" Document::recompute: The graph must be a DAG. *** Abort *** an exception was raised, but no catch was found. ... The exception is:SIGSEGV 'segmentation violation' detected. Address 0 Since I have to complete this model I'll move over to OpenSCAD to continue working on it but will leave this model unmodified so I can test future builds.. |
First, your model has a few errors which could either be the result of the crash, but also from a poor understanding of the new PartDesign work flow. The Pad is outside the Body, which is empty apart from the BodyOrigin planes and axes. And Sketch001 is also outside of the Body. When editing then closing Sketch001 (no crash here), the Report view shows the following message: Document::recompute: The graph must be a DAG. The Dependency graph shows the "Footprint w/out bumpers" sketch has a circular dependency unto itself, not sure how it happened. You wrote "it crashed while editing a sketch attached to the face of another sketch." This is an impossibility because a sketch does not have a face. A sketch is a 2D construct that can be attached to a plane or to a face. I have repaired your file as best as I could, but had to delete and redo the Pad as I couldn't move it to the body, FreeCAD gave an error "Some of the selected features have dependencies in the source body". Please open "approximate fill_normandc1.fcstd", first activate the Body, then edit Sketch001 and see if you still get a crash. My FreeCAD info: OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9542 (Git) Build type: None Branch: master Hash: 96dc57c06861922b9dde830e3bcc07e43ed11cf7 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
I definitely have a poor understanding of the new work-flow as I only encountered it when upgrading in hopes of resolving crashes with 0.16 ... I thought I was creating a sketch on one face of the pad so I mis-typed above. I was hoping to put the three circles on the side of the pad. 'Body's are new to me in this context so I don't know how to work with them. I can't explain the circular dependency. I'm not sure what I did to cause that. But you're correct that it does not crash when performing that action now. Thanks. Obviously there's a bug there somewhere that I antagonized by not knowing what I was doing. |
Have a look at this topic which goes over the changes introduced in 0.17's PartDesign workbench (which we commonly dub "PartDesignNext"): http://forum.freecad.org/viewtopic.php?f=3&t=15432 And don't hesitate to ask for clarifications in that topic. As for circular dependencies, we've realized recently that in PDN they are very easy to produce inadvertently. It's an issue that needs to be addressed, as well as many other bugs, which is why using 0.17's PartDesignNext for production work is not recommended at this time. But since 0.16 is unusable for you, I can only suggest that while using 0.17 you save often and raise the number of backups in Edit --> Preferences / General / Document. |
Thank you for your help. |
NormandC: First, your model has a few errors which could either be the result of the crash, but also from a poor understanding of the new PartDesign work flow. The Pad is outside the Body, which is empty apart from the BodyOrigin planes and axes. And Sketch001 is also outside of the Body. I guess the broken document is the result of recent changes in PDN. ickby said that older projects created with 0.17 will be affected but it's rather easy to fix them by drag and dropping the objects to the body. garnish: I couldn't reproduce a crash. Are you able to run FreeCAD in a debugger? Since you are on OSX you should do something like: |
[I accidentally replied to the email notification from Mantis. Here is the same text. Apologies if it appears twice] Here’s what I got. I’ll leave the debugger attached in case you want me to run additional debugging commands… chimay bin $ lldb ./FreeCAD (lldb) target create "./FreeCAD" Current executable set to './FreeCAD' (x86_64). (lldb) run Process 91315 launched: './FreeCAD' (x86_64) FreeCAD 0.17, Libs: 0.17R9564 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2016 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly. Can't find Origin for "Body" Can't find Origin for "Body" Can't find Origin for "Body" Can't find Origin for "Body" Document::recompute: The graph must be a DAG. Process 91315 stopped * thread #1: tid = 0x4a5cf1e, 0x000000011c85b664 SketcherGui.so`SketcherGui::ViewProviderSketch::drawConstraintIcons() + 596, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0) frame #0: 0x000000011c85b664 SketcherGui.so`SketcherGui::ViewProviderSketch::drawConstraintIcons() + 596 SketcherGui.so`SketcherGui::ViewProviderSketch::drawConstraintIcons: -> 0x11c85b664 <+596>: movq (%r14), %rax 0x11c85b667 <+599>: movq 0x168(%rax), %rax 0x11c85b66e <+606>: movl $0x1, %esi 0x11c85b673 <+611>: movq %r14, %rdi (lldb) bt * thread #1: tid = 0x4a5cf1e, 0x000000011c85b664 SketcherGui.so`SketcherGui::ViewProviderSketch::drawConstraintIcons() + 596, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0) * frame #0: 0x000000011c85b664 SketcherGui.so`SketcherGui::ViewProviderSketch::drawConstraintIcons() + 596 frame #1: 0x000000011c85966a SketcherGui.so`SketcherGui::ViewProviderSketch::mouseMove(SbVec2s const&, Gui::View3DInventorViewer*) + 2010 frame 0000002: 0x00000001002b02dc libFreeCADGui.dylib`Gui::ViewProvider::eventCallback(void*, SoEventCallback*) + 428 frame 0000003: 0x00000001015853fe libCoin.60.dylib`SoEventCallback::handleEvent(SoHandleEventAction*) + 164 frame 0000004: 0x0000000101406935 libCoin.60.dylib`SoAction::traverse(SoNode*) + 91 frame 0000005: 0x00000001014f007f libCoin.60.dylib`SoChildList::traverse(SoAction*, int, int) + 123 frame 0000006: 0x000000010158c749 libCoin.60.dylib`SoGroup::doAction(SoAction*) + 87 frame 0000007: 0x00000001015a2490 libCoin.60.dylib`SoSeparator::doAction(SoAction*) + 40 frame 0000008: 0x0000000101406935 libCoin.60.dylib`SoAction::traverse(SoNode*) + 91 frame 0000009: 0x00000001014f007f libCoin.60.dylib`SoChildList::traverse(SoAction*, int, int) + 123 frame 0000010: 0x000000010158c749 libCoin.60.dylib`SoGroup::doAction(SoAction*) + 87 frame 0000011: 0x00000001015a2490 libCoin.60.dylib`SoSeparator::doAction(SoAction*) + 40 frame 0000012: 0x0000000101406935 libCoin.60.dylib`SoAction::traverse(SoNode*) + 91 frame 0000013: 0x000000010140f6e4 libCoin.60.dylib`SoHandleEventAction::beginTraversal(SoNode*) + 104 frame 0000014: 0x0000000101406586 libCoin.60.dylib`SoAction::apply(SoNode*) + 360 frame 0000015: 0x00000001014f4621 libCoin.60.dylib`SoEventManager::actuallyProcessEvent(SoEvent const*) + 97 frame 0000016: 0x000000010026630c libFreeCADGui.dylib`SIM::Coin3D::Quarter::QuarterWidget::processSoEvent(SoEvent const*) + 28 frame 0000017: 0x000000010026de6c libFreeCADGui.dylib`SIM::Coin3D::Quarter::SoQTQuarterAdaptor::processSoEvent(SoEvent const*) + 92 frame 0000018: 0x00000001002923d9 libFreeCADGui.dylib`Gui::View3DInventorViewer::processSoEventBase(SoEvent const*) + 9 frame 0000019: 0x000000010027bffb libFreeCADGui.dylib`Gui::BlenderNavigationStyle::processSoEvent(SoEvent const*) + 2347 frame 0000020: 0x0000000100278100 libFreeCADGui.dylib`Gui::NavigationStyle::processEvent(SoEvent const*) + 288 frame 0000021: 0x00000001002923c0 libFreeCADGui.dylib`Gui::View3DInventorViewer::processSoEvent(SoEvent const*) + 128 frame 0000022: 0x000000010025b0c3 libFreeCADGui.dylib`SIM::Coin3D::Quarter::EventFilter::eventFilter(QObject*, QEvent*) + 307 frame 0000023: 0x00000001048146eb QtCore`QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 111 frame 0000024: 0x0000000103a4c54e QtGui`QApplicationPrivate::notify_helper(QObject*, QEvent*) + 178 frame 0000025: 0x0000000103a4ded4 QtGui`QApplication::notify(QObject*, QEvent*) + 2082 frame 0000026: 0x0000000100067b0b libFreeCADGui.dylib`Gui::GUIApplication::notify(QObject*, QEvent*) + 75 frame 0000027: 0x00000001048144f6 QtCore`QCoreApplication::notifyInternal(QObject*, QEvent*) + 118 frame 0000028: 0x0000000103a4ce0b QtGui`QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 415 frame 0000029: 0x0000000103a05143 QtGui`qt_mac_handleMouseEvent(NSEvent*, QEvent::Type, Qt::MouseButton, QWidget*, bool) + 1292 frame 0000030: 0x00007fff99e43bb5 AppKit`-[NSWindow _reallySendEvent:isDelayedEvent:] + 2108 frame 0000031: 0x00007fff9988263d AppKit`-[NSWindow sendEvent:] + 517 frame 0000032: 0x00000001039fd6c3 QtGui`-[QCocoaWindow sendEvent:] + 113 frame 0000033: 0x00007fff99802b3c AppKit`-[NSApplication sendEvent:] + 2540 frame 0000034: 0x0000000103a01b68 QtGui`-[QNSApplication sendEvent:] + 97 frame 0000035: 0x00007fff99669ef6 AppKit`-[NSApplication run] + 796 frame 0000036: 0x0000000103a09ace QtGui`QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1496 frame 0000037: 0x0000000104811bc7 QtCore`QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 77 frame 0000038: 0x0000000104811d41 QtCore`QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 365 frame #39: 0x000000010481494b QtCore`QCoreApplication::exec() + 199 frame #40: 0x000000010002300b libFreeCADGui.dylib`Gui::Application::runApplication() + 7915 frame 0000041: 0x0000000100008cc6 FreeCAD`main + 4070 frame 0000042: 0x00007fff87d0c5ad libdyld.dylib`start + 1 frame 0000043: 0x00007fff87d0c5ad libdyld.dylib`start + 1 (lldb) register read General Purpose Registers: rax = 0x0000000000000000 rbx = 0x000000000000000d rcx = 0x000000000000006d rdx = 0x0000000000000000 rdi = 0x0000000118faf820 rsi = 0x000000000000000d rbp = 0x00007fff5fbfd330 rsp = 0x00007fff5fbfd050 r8 = 0x0000000000000005 r9 = 0x00000000ffffffff r10 = 0x0000000019c84b9a r11 = 0x0000000118a00000 r12 = 0x0000000117eb7920 r13 = 0x0000000100c93cb0 libFreeCADApp.dylib`typeinfo for App::DocumentObject r14 = 0x0000000000000000 r15 = 0x0000000117e530a8 rip = 0x000000011c85b664 SketcherGui.so`SketcherGui::ViewProviderSketch::drawConstraintIcons() + 596 rflags = 0x0000000000010202 cs = 0x000000000000002b fs = 0x0000000000000000 gs = 0x0000000000000000 |
Just started a new model and tried to use PDN 'correctly' and very quickly experienced another crash. I'm attaching to this bug but it is probably a different crash. I created a body, created a sketch in that body, fully constrained it and then saved it. Then I created a second body and created a sketch in that body, fully constrained it and created a pad. unfortunately, I didn't save it. I decided to create a pad for the first body but was given a bunch of options on the left pane at which point I realized that wasn't quite what I wanted so I pressed 'Cancel' and experienced this crash: (lldb) run Process 98523 launched: './FreeCAD' (x86_64) FreeCAD 0.17, Libs: 0.17R9564 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2016 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly. 2017-01-15 07:00:31.422 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:00:57.337 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:02:43.787 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:02:53.571 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:03:03.200 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 71.332017-01-15 07:06:14.631 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:08:03.102 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:08:41.477 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:08:53.667 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:09:03.081 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:09:28.313 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:09:36.662 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:09:46.761 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:10:21.641 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:10:31.261 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:10:39.966 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:10:47.560 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:10:57.944 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:11:07.481 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:11:16.999 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:11:24.936 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:11:31.884 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:11:40.633 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:11:52.490 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:12:09.163 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:12:19.226 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:12:21.551 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:13:21.056 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:29:46.634 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:32:29.557 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:33:34.492 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:34:03.748 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: 2017-01-15 07:34:14.659 FreeCAD[98523:82996877] modalSession has been exited prematurely - check for a reentrant call to endModalSession: Process 98523 stopped * thread #1: tid = 0x4f26e8d, 0x0000000100b0d37d libFreeCADApp.dylib`App::Document::getObjectsOfType(Base::Type const&) const + 61, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0) frame #0: 0x0000000100b0d37d libFreeCADApp.dylib`App::Document::getObjectsOfType(Base::Type const&) const + 61 libFreeCADApp.dylib`App::Document::getObjectsOfType: -> 0x100b0d37d <+61>: movq (%rax), %rbx 0x100b0d380 <+64>: cmpq 0x8(%rax), %rbx 0x100b0d384 <+68>: je 0x100b0d439 ; <+249> 0x100b0d38a <+74>: leaq -0x38(%rbp), %r13 (lldb) tb No breakpoints currently set. (lldb) bt * thread #1: tid = 0x4f26e8d, 0x0000000100b0d37d libFreeCADApp.dylib`App::Document::getObjectsOfType(Base::Type const&) const + 61, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0) * frame #0: 0x0000000100b0d37d libFreeCADApp.dylib`App::Document::getObjectsOfType(Base::Type const&) const + 61 frame #1: 0x00000001194ca013 Part.so`Part::BodyBase::findBodyOf(App::DocumentObject const*) + 67 frame 0000002: 0x000000011c51a780 _PartDesign.so`PartDesign::Body::findBodyOf(App::DocumentObject const*) + 16 frame 0000003: 0x000000011c3b81f6 PartDesignGui.so`PartDesignGui::TaskBoxPrimitives::~TaskBoxPrimitives() + 54 frame 0000004: 0x000000011c3b82ce PartDesignGui.so`PartDesignGui::TaskBoxPrimitives::~TaskBoxPrimitives() + 14 frame 0000005: 0x000000010024497f libFreeCADGui.dylib`Gui::TaskView::TaskDialog::~TaskDialog() + 63 frame 0000006: 0x000000011c3bb48e PartDesignGui.so`PartDesignGui::TaskPrimitiveParameters::~TaskPrimitiveParameters() + 14 frame 0000007: 0x000000010024352a libFreeCADGui.dylib`Gui::TaskView::TaskView::removeDialog() + 266 frame 0000008: 0x0000000100243953 libFreeCADGui.dylib`Gui::TaskView::TaskView::reject() + 179 frame 0000009: 0x0000000104828d93 QtCore`QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 2207 frame 0000010: 0x0000000103d84f53 QtGui`QDialogButtonBoxPrivate::_q_handleButtonClicked() + 187 frame 0000011: 0x0000000104828d93 QtCore`QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 2207 frame 0000012: 0x0000000103fa84ca QtGui`QAbstractButton::clicked(bool) + 64 frame 0000013: 0x0000000103d5be84 QtGui`QAbstractButtonPrivate::emitClicked() + 52 frame 0000014: 0x0000000103d5bd85 QtGui`QAbstractButtonPrivate::click() + 207 frame 0000015: 0x0000000103d5c72e QtGui`QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 88 frame 0000016: 0x0000000103a8eca9 QtGui`QWidget::event(QEvent*) + 709 frame 0000017: 0x0000000103d5c63b QtGui`QAbstractButton::event(QEvent*) + 175 frame 0000018: 0x0000000103a4c55e QtGui`QApplicationPrivate::notify_helper(QObject*, QEvent*) + 194 frame 0000019: 0x0000000103a4ded4 QtGui`QApplication::notify(QObject*, QEvent*) + 2082 frame 0000020: 0x0000000100067b0b libFreeCADGui.dylib`Gui::GUIApplication::notify(QObject*, QEvent*) + 75 frame 0000021: 0x00000001048144f6 QtCore`QCoreApplication::notifyInternal(QObject*, QEvent*) + 118 frame 0000022: 0x0000000103a4ce0b QtGui`QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 415 frame 0000023: 0x0000000103a05143 QtGui`qt_mac_handleMouseEvent(NSEvent*, QEvent::Type, Qt::MouseButton, QWidget*, bool) + 1292 frame 0000024: 0x00007fff99e427b3 AppKit`-[NSWindow _handleMouseUpEvent:isDelayedEvent:] + 119 frame 0000025: 0x00007fff99e4344d AppKit`-[NSWindow _reallySendEvent:isDelayedEvent:] + 212 frame 0000026: 0x00007fff9988263d AppKit`-[NSWindow sendEvent:] + 517 frame 0000027: 0x00000001039fd6c3 QtGui`-[QCocoaWindow sendEvent:] + 113 frame 0000028: 0x00007fff99802b3c AppKit`-[NSApplication sendEvent:] + 2540 frame 0000029: 0x0000000103a01b68 QtGui`-[QNSApplication sendEvent:] + 97 frame 0000030: 0x00007fff99669ef6 AppKit`-[NSApplication run] + 796 frame 0000031: 0x0000000103a09ace QtGui`QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1496 frame 0000032: 0x0000000104811bc7 QtCore`QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 77 frame 0000033: 0x0000000104811d41 QtCore`QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 365 frame 0000034: 0x000000010481494b QtCore`QCoreApplication::exec() + 199 frame 0000035: 0x000000010002300b libFreeCADGui.dylib`Gui::Application::runApplication() + 7915 frame 0000036: 0x0000000100008cc6 FreeCAD`main + 4070 frame 0000037: 0x00007fff87d0c5ad libdyld.dylib`start + 1 frame 0000038: 0x00007fff87d0c5ad libdyld.dylib`start + 1 (lldb) register read General Purpose Registers: rax = 0x0000000000000000 rbx = 0x000000011d096440 rcx = 0x0000000106136620 rdx = 0x00007fff5fbfd4d0 rdi = 0x00007fff5fbfd4e0 rsi = 0x000000011d096440 rbp = 0x00007fff5fbfd4c0 rsp = 0x00007fff5fbfd460 r8 = 0x00000000000003ff r9 = 0xffffffffffffffff r10 = 0x0000000105eb6bf0 r11 = 0x00000001042c19d0 (void *)0x00000001042c19f8: QCocoaView r12 = 0x00007fff5fbfd4e0 r13 = 0x0000000100243df0 libFreeCADGui.dylib`Gui::TaskView::TaskView::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) r14 = 0x00007fff5fbfd4d0 r15 = 0x0000000106848c00 rip = 0x0000000100b0d37d libFreeCADApp.dylib`App::Document::getObjectsOfType(Base::Type const&) const + 61 rflags = 0x0000000000010206 cs = 0x000000000000002b fs = 0x0000000000000000 gs = 0x0000000000000000 Recovery produced only the first body/sketch but nothing regarding the second body so I can not reproduce the crash. |
Stupid question: In the debugger output there appears the number "596" after SketcherGui::ViewProviderSketch::drawConstraintIcons(). What does this mean? Is it an offset value? The crash you observed in your last post is indeed a different issue. I experienced it too and committed a fix. |
yes, that would be the offset from the beginning of the function to where the bug is. If I had source and this was gdb, I would say "list SketcherGui::ViewProviderSketch::drawConstraintIcons+596" or something like that... There's probably a similar way to do that in lldb but I'm not familiar with it. |
I have no idea how to use the "list" command. What I did so far: + make a debug build with cmake (-DCMAKE_BUILD_TYPE=Debug) + gdb ./FreeCAD + break SketcherGui::ViewProviderSketch::drawConstraintIcons + run FreeCAD then hits the breakpoint Now when entering list SketcherGui::ViewProviderSketch::drawConstraintIcons there is no output. When I enter list "SketcherGui::ViewProviderSketch::drawConstraintIcons+596" I get an error message. Any ideas how to continue? |
@garnish ping |
Got the ping. It looks like someone needs help using a debugger. I don't know how to use lldb. Here's a helpful page on lldb. https://lldb.llvm.org/lldb-gdb.html I haven't built FC from source, I don't know how FC works inside, nor how it's supposed to work. I'm a kernel guy. I no longer experience crashes with FC since I've stopped using FC completely. Maybe you should close this bug? |
@wmayer should we keep this open? |
@Abdullah if you have a moment can you weigh in on this? |
It crashes with auto-update, it does not crash without it. Related to 0002710, in that early return from the execute function leaves sketch solver and viewer geometry/constraints out of sync. Then it crashes in the SoNode indexing. When reaching a solution to the other ticket this may be automatically resolved as well. |
It is in fact a generalisation of the 0002710, so it is better to handle this first, which will solve the problem for that one too. The solution is not the one proposed there in view of this ticket. Summary: execute() of SketchObject is not even executed, because Document::Recompute fails, because the dependency graph is not a DAG. Relevant code:
I think we need a general mechanism to tidy up objects when recompute is interrupted.To be discussed in: https://forum.freecad.org/viewtopic.php?f=10&t=19923&p=175762#p175762 |
https://github.com/FreeCAD/FreeCAD/commit/2004544e574cb45f7fdb5fb4f7ef02dfcad56aab |
c:FreeCAD:2004544e574cb45f7fdb5fb4f7ef02dfcad56aab: |
| 2017-01-08 14:15 | garnish | New Issue | |
| 2017-01-08 14:15 | garnish | File Added: approximate fill.FCStd | |
| 2017-01-08 14:15 | garnish | File Added: Screen Shot 2017-01-08 at 7.11.22 AM.png | |
| 2017-01-08 14:18 | garnish | Note Added: 0007569 | |
| 2017-01-08 21:46 | normandc | Note Added: 0007570 | |
| 2017-01-08 21:47 | normandc | File Added: approximate fill_normandc1.FCStd | |
| 2017-01-08 21:47 | normandc | Note Edited: 0007570 | |
| 2017-01-08 21:57 | garnish | Note Added: 0007571 | |
| 2017-01-08 22:14 | normandc | Note Added: 0007572 | |
| 2017-01-08 22:16 | garnish | Note Added: 0007573 | |
| 2017-01-09 21:35 | wmayer | Note Added: 0007586 | |
| 2017-01-10 15:13 | garnish | Note Added: 0007601 | |
| 2017-01-15 14:46 | garnish | Note Added: 0007794 | |
| 2017-01-23 21:48 | wmayer | Changeset attached | => FreeCAD Master master 8a100bf6 |
| 2017-01-23 21:48 | wmayer | Note Added: 0007931 | |
| 2017-01-23 22:24 | Kunda1 | Status | new => feedback |
| 2017-01-24 03:44 | garnish | Note Added: 0007942 | |
| 2017-01-24 03:44 | garnish | Status | feedback => new |
| 2017-01-25 21:55 | wmayer | Note Added: 0007988 | |
| 2017-02-17 10:51 | Kunda1 | Status | new => feedback |
| 2017-02-17 10:51 | Kunda1 | Note Added: 0008330 | |
| 2017-02-17 11:55 | garnish | Note Added: 0008333 | |
| 2017-02-17 11:55 | garnish | Status | feedback => new |
| 2017-03-15 20:11 | Kunda1 | Target Version | => 0.17 |
| 2017-05-01 22:57 | Kunda1 | Note Added: 0008840 | |
| 2017-05-26 22:48 | Kunda1 | Note Added: 0009162 | |
| 2017-05-27 07:26 | abdullah | Relationship added | related to 0002710 |
| 2017-05-27 07:28 | abdullah | Note Added: 0009165 | |
| 2017-05-27 10:30 | abdullah | Note Added: 0009168 | |
| 2017-05-27 12:03 | Kunda1 | Note View State: 0009165: private | |
| 2017-05-27 12:04 | Kunda1 | Note Edited: 0009165 | |
| 2017-05-27 12:04 | Kunda1 | Note View State: 0009165: public | |
| 2017-05-27 12:04 | Kunda1 | Note Edited: 0009168 | |
| 2017-06-02 15:14 | Kunda1 | Status | new => confirmed |
| 2017-06-02 15:15 | Kunda1 | Note Edited: 0009168 | |
| 2017-08-19 15:51 | wmayer | Assigned To | => wmayer |
| 2017-08-19 15:51 | wmayer | Status | confirmed => closed |
| 2017-08-19 15:51 | wmayer | Resolution | open => fixed |
| 2017-08-19 15:51 | wmayer | Fixed in Version | => 0.17 |
| 2017-08-19 15:51 | wmayer | Note Added: 0009959 | |
| 2017-08-19 19:32 | Kunda1 | Note Added: 0009965 |
