| 0002963 | FreeCAD | Bug | public | 2017-03-11 13:49 | 2017-07-15 03:43 |
| Reporter | bernhardb | Assigned To | |||
| Platform | linux | OS | Suse Leap | OS Version | 42.2 |
| Summary | 0002963: Opening the preferences-dialog leads to crash (downstream packman-suse packaging issue) | ||||
| Description | When opening the preferences-dialog, the application crashes | ||||
| Steps To Reproduce | - Start FreeCad from a xterm -> You get: bb@hex1:~> /usr/bin/FreeCAD FreeCAD 0.17, Libs: 0.17R10236 (Git) (Packman) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2017 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Mod pluginloader InitGui.py starting ... pluginmanager config file /home/bb/.FreeCAD//Mod/plugins/pluginloaderconfig.yaml During initialization the error local variable 'fn2' referenced before assignment occurred in /usr/lib64/FreeCAD/Mod/plugins/InitGui.py -> Select Edit -> Preferences Then the application hangs for may be 3 seconds and then the application crashes. Program received signal SIGSEGV, Segmentation fault. #0 /lib64/libc.so.6(+0x34950) [0x7f1e1455a950] #1 /usr/lib64/libpython2.7.so.1.0(+0x1155f0) [0x7f1e161295f0] 0000002 /usr/lib64/libpython2.7.so.1.0(PyEval_GetGlobals+0x9) [0x7f1e16100749] 0000003 /usr/lib64/libpython2.7.so.1.0(PyImport_Import+0x20) [0x7f1e16121df0] 0000004 /usr/lib64/libpython2.7.so.1.0(PyImport_ImportModule+0x1a) [0x7f1e1616553a] 0000005 0x7f1de40cc7ae in PyCustomWidgets::getModuleAttr(char const*, char const*) from /usr/lib64/qt4/plugins/designer/libpyqt4.so+0xe 0000006 0x7f1de40cd8a8 in PyCustomWidgets::PyCustomWidgets(QObject*) from /usr/lib64/qt4/plugins/designer/libpyqt4.so+0x1088 0000007 /usr/lib64/qt4/plugins/designer/libpyqt4.so(qt_plugin_instance+0x87) [0x7f1de40cdf77] 0000008 0x7f1e14fd0501 in QPluginLoader::instance() from /usr/lib64/libQtCore.so.4+0x41 0000009 0x7f1e17298990 in QFormInternal::QFormBuilder::updateCustomWidgets() from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x360 0000010 0x7f1e17274113 in QUiLoader::QUiLoader(QObject*) from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x133 0000011 0x7f1e1721ae41 in Gui::UiLoader::UiLoader(QObject*) from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x11 0000012 0x7f1e16ffe9f5 in Gui::Dialog::PreferenceUiForm::PreferenceUiForm(QString const&, QWidget*) from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x55 0000013 0x7f1e1721cd62 in Gui::PrefPageUiProducer::Produce() const from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x22 0000014 0x7f1e164b2761 in Base::Factory::Produce(char const*) const from /usr/lib64/FreeCAD/lib/libFreeCADBase.so+0x51 0000015 0x7f1e17219ba0 in Gui::WidgetFactoryInst::createPreferencePage(char const*, QWidget*) const from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x10 0000016 0x7f1e1705cb10 in Gui::Dialog::DlgPreferencesImp::setupPages() from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x5c0 0000017 0x7f1e1705c526 in Gui::Dialog::DlgPreferencesImp::DlgPreferencesImp(QWidget*, QFlags<Qt::WindowType>) from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0xd6 0000018 0x7f1e16f9bcd5 in StdCmdDlgPreferences::activated(int) from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x25 0000019 0x7f1e16f86b38 in Gui::Command::invoke(int) from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x48 0000020 0x7f1e150000ea in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib64/libQtCore.so.4+0x2da 0000021 0x7f1e1552b5b2 in QAction::triggered(bool) from /usr/lib64/libQtGui.so.4+0x32 0000022 0x7f1e1552cf63 in QAction::activate(QAction::ActionEvent) from /usr/lib64/libQtGui.so.4+0x63 0000023 /usr/lib64/libQtGui.so.4(+0x6022d9) [0x7f1e159562d9] 0000024 /usr/lib64/libQtGui.so.4(+0x606829) [0x7f1e1595a829] 0000025 0x7f1e15580bba in QWidget::event(QEvent*) from /usr/lib64/libQtGui.so.4+0xaca 0000026 0x7f1e1595e67b in QMenu::event(QEvent*) from /usr/lib64/libQtGui.so.4+0x5b 0000027 0x7f1e155316fc in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib64/libQtGui.so.4+0x8c 0000028 0x7f1e15537d7a in QApplication::notify(QObject*, QEvent*) from /usr/lib64/libQtGui.so.4+0x36a 0000029 0x7f1e16f68cb8 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x48 0000030 0x7f1e14fec17d in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib64/libQtCore.so.4+0x6d 0000031 0x7f1e15537573 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /usr/lib64/libQtGui.so.4+0x153 0000032 /usr/lib64/libQtGui.so.4(+0x254f7c) [0x7f1e155a8f7c] 0000033 0x7f1e155a76bc in QApplication::x11ProcessEvent(_XEvent*) from /usr/lib64/libQtGui.so.4+0x5fc 0000034 /usr/lib64/libQtGui.so.4(+0x27a552) [0x7f1e155ce552] 0000035 /usr/lib64/libglib-2.0.so.0(g_main_context_dispatch+0x254) [0x7f1e0e12c134] 0000036 /usr/lib64/libglib-2.0.so.0(+0x4c388) [0x7f1e0e12c388] 0000037 /usr/lib64/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7f1e0e12c42c] 0000038 0x7f1e15018fae in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib64/libQtCore.so.4+0x7e #39 /usr/lib64/libQtGui.so.4(+0x27a606) [0x7f1e155ce606] #40 0x7f1e14fead3f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib64/libQtCore.so.4+0x2f 0000041 0x7f1e14feb035 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib64/libQtCore.so.4+0x175 0000042 0x7f1e14ff0489 in QCoreApplication::exec() from /usr/lib64/libQtCore.so.4+0x89 0000043 0x7f1e16f235b0 in Gui::Application::runApplication() from /usr/lib64/FreeCAD/lib/libFreeCADGui.so+0x1bf0 0000044 /usr/bin/FreeCAD(main+0x692) [0x4033b2] 0000045 /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f1e145466e5] 0000046 /usr/bin/FreeCAD(_start+0x29) [0x402bf9] | ||||
| Additional Information | OS: "openSUSE Leap 42.2" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10236 (Git) (Packman) Build type: Release Branch: master Hash: dd20ba3d068c4a0903417d93144f8ac7fed068e9 Python version: 2.7.12 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev | ||||
| Tags | distribution specific, downstream | ||||
I can't reproduce this. My version info:
I see you have some addons installed:Mod pluginloader InitGui.py starting ...To troubleshoot, can you try temporarily moving the contents of `/usr/lib64/FreeCAD/Mod` and `/home/bb/.FreeCAD/Mod` to different folders, e.g. `/home/bb/system-mods` and `/home/bb/user-mods`? That way we can see if this is occurring because of, e.g., an old version of an addon. |
Tried this: - Moved `/home/bb/.FreeCAD/Mod` away -> still crash opening the pref-dialog - Moved the central `/usr/lib64/FreeCAD/Mod` away -> Crash vanishes, the dialog can be called - Deinstalled complete FreeCad via rpm-mechanism -> the whole /usr/lib64/FreeCad - dir is deleted. Reinstalled FreeCad from packman -> /usr/lib64/FreeCad including the Mod-dir is of the packman-installation - Crash is there again. So, I would conclude, there is something offending in the Mod-directory of the packman package... |
OK, I narrowed it down a little bit: The crash vanishes if the directories /usr/lib64/FreeCAD/Mod/Arch and /usr/lib64/FreeCAD/Mod/Draft are moved away. If one of these two dirs are avaylable, the crash occures... |
I set up an OpenSUSE VM to test this further and can't reproduce still: |
Here is the output of ldd /usr/lib64/FreeCAD/bin/FreeCAD Might be that one of the referenced libraries is not compartible? |
What workbench do you have active when the crash happens? Is it possible to change to any other workbench and not have the crash? Can you try temporarily moving the folders needed to not get a crash and change your startup workbench and see if that has any effect? |
I have played arround a little bit with the workbenches: No change of workbench leads ever to a crash. I start with the "start" - workbench But gunny behavour:
I also run a "strace" of the crash in case 1) which I added here |
@bernhardb do you mind re-upping the zip file? |
@Kunda1 I have updated my system in between, but the same error is still reproducable.Please find the strace attached. Here the new version of freecad: OS: "openSUSE Leap 42.2" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10236 (Git) (Packman) Build type: Release Branch: master Hash: dd20ba3d068c4a0903417d93144f8ac7fed068e9 Python version: 2.7.12 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.9.1.oce-0.18-dev |
@bernhardb Can you update to the latest 0.17 revision and retest? |
@Kunda1 That is the newest version of the packman package. The system updated it a week before or so. bb@hex1:~> rpm -q FreeCAD FreeCAD-0.16.99+git20170222.0922-2.19.x86_64 |
@bernhardb can you still reproduce on the latest 0.17 ? |
@Kunda1 I really think, the problem is not in the source code of FreeCad, but in the build process of the packman-suse-packages: If You look at http://packman.links2linux.org/package/FreeCAD they were newly uploaded today. But they are - like the version number shows - still based on the source code of the date 2017-02-22. So, the distro recognizes the new package but installs a build of the old git status again and again... |
@bernhardb can you let downstream packman-suse package team know this is a problem ? |
I just opened a ticket downstream: https://bugs.links2linux.org/browse/PM-140 and have asked on their freenode #packman channel for help. |
They closed the downstream ticket with the comment that the maintainer left the project and they will withdraw the (non-functional) package. So, I think, this ticket can be closed too: This was quite shure only in this package a bug, and since the freecad-packman-package seems to be dead there is nothing more to test on SUSE linux. Thanks for the whole work! |
@bernhardb We have appimage builds https://github.com/FreeCAD/FreeCAD/releases/tag/0.17_pre that work cross distro. just downlaod the .AppImage and make it executable. Take the larger file from the link. The other is an old build that has netgen support. If you get a crash please report back. |
closing per 0002963:0009755 |
| 2017-03-11 13:49 | bernhardb | New Issue | |
| 2017-03-12 13:29 | kkremitzki | Note Added: 0008612 | |
| 2017-03-12 15:44 | bernhardb | Note Added: 0008615 | |
| 2017-03-12 22:30 | bernhardb | Note Added: 0008618 | |
| 2017-03-13 11:40 | Kunda1 | Priority | normal => high |
| 2017-03-13 11:40 | Kunda1 | Status | new => confirmed |
| 2017-03-13 11:40 | Kunda1 | Target Version | => 0.17 |
| 2017-03-14 21:13 | kkremitzki | Note Added: 0008629 | |
| 2017-03-15 21:17 | bernhardb | File Added: ldd_FreeCad | |
| 2017-03-15 21:17 | bernhardb | Note Added: 0008634 | |
| 2017-03-15 22:44 | kkremitzki | Note Added: 0008635 | |
| 2017-03-16 07:27 | bernhardb | File Added: FC.debug.zip | |
| 2017-03-16 07:27 | bernhardb | Note Added: 0008638 | |
| 2017-05-08 04:59 | Kunda1 | Note Added: 0008911 | |
| 2017-05-08 05:00 | Kunda1 | Status | confirmed => feedback |
| 2017-05-08 07:31 | bernhardb | File Added: freecad.crash.zip | |
| 2017-05-08 07:31 | bernhardb | Note Added: 0008915 | |
| 2017-05-08 07:31 | bernhardb | Status | feedback => new |
| 2017-05-08 12:08 | Kunda1 | Note Added: 0008916 | |
| 2017-05-09 04:54 | bernhardb | Note Added: 0008922 | |
| 2017-07-12 02:46 | Kunda1 | Note Added: 0009726 | |
| 2017-07-12 20:24 | bernhardb | Note Added: 0009748 | |
| 2017-07-12 21:35 | Kunda1 | Tag Attached: distribution specific | |
| 2017-07-12 21:35 | Kunda1 | Tag Attached: upstream | |
| 2017-07-12 21:36 | Kunda1 | Note Added: 0009750 | |
| 2017-07-12 21:36 | Kunda1 | Tag Detached: upstream | |
| 2017-07-12 21:36 | Kunda1 | Tag Attached: downstream | |
| 2017-07-12 21:37 | Kunda1 | Summary | Opening the preferences-dialog leads to crash => Opening the preferences-dialog leads to crash (downstream packman-suse packaging issue) |
| 2017-07-12 21:37 | Kunda1 | Tag Attached: #pending | |
| 2017-07-13 11:51 | Kunda1 | Note Added: 0009753 | |
| 2017-07-14 19:54 | bernhardb | Note Added: 0009755 | |
| 2017-07-14 22:09 |
Note Added: 0009756 | |
| 2017-07-15 03:42 | Kunda1 | Status | new => closed |
| 2017-07-15 03:42 | Kunda1 | Resolution | open => not fixable |
| 2017-07-15 03:42 | Kunda1 | Note Added: 0009757 | |
| 2017-07-15 03:43 | Kunda1 | Target Version | 0.17 => |
| 2017-07-15 03:43 | Kunda1 | Tag Detached: #pending |
