| 0000906 | PartDesign | Bug | public | 2012-12-07 09:00 | 2012-12-07 12:05 |
| Reporter | danielpoplawski | Assigned To | |||
| Summary | 0000906: Segmentation Fault when try to use linear pattern on Part | ||||
| Description | FreeCAD crash with Segmentation Fail when try to create linear pattern on Part. Part created on different version FreeCAD (0.12 from Ubuntu repo). | ||||
| Additional Information | FreeCAD: Version: 0.13 Revision number: 1737 (Git) Operating system: Ubuntu 12.04.1 LTS (it's Kubuntu) Platform: 32-bit Branch: master Own compilation with dependencies from ubuntu repos. ======================================================= uname -r 3.2.0-34-generic-pae ======================================================= I have core dump but it's 177 MB. Backtrace form gdb: Reading symbols from /usr/bin/FreeCAD...(no debugging symbols found)...done. [New LWP 31524] [New LWP 31527] [New LWP 31528] [New LWP 31531] [New LWP 31534] [New LWP 31533] [New LWP 31530] [New LWP 31532] [New LWP 31529] warning: Can't read pathname for load map: B??d wej?cia/wyj?cia. [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1". Core was generated by `FreeCAD'. Program terminated with signal 11, Segmentation fault. #0 0xaa04ea38 in TopoDS_ListIteratorOfListOfShape::Initialize(TopoDS_ListOfShape const&) () from /usr/lib/libTKBRep-6.5.0.so (gdb) bt #0 0xaa04ea38 in TopoDS_ListIteratorOfListOfShape::Initialize(TopoDS_ListOfShape const&) () from /usr/lib/libTKBRep-6.5.0.so #1 0xaa096fee in TopoDS_Iterator::Initialize(TopoDS_Shape const&, unsigned int, unsigned int) () from /usr/lib/libTKBRep-6.5.0.so 0000002 0xaa070628 in BRepTools_Modifier::Put(TopoDS_Shape const&) () from /usr/lib/libTKBRep-6.5.0.so 0000003 0xaa0707c6 in BRepTools_Modifier::Init(TopoDS_Shape const&) () from /usr/lib/libTKBRep-6.5.0.so 0000004 0xa9eeabfb in BRepBuilderAPI_ModifyShape::DoModif(TopoDS_Shape const&) () from /usr/lib/libTKTopAlgo-6.5.0.so 0000005 0xa9edb3ab in BRepBuilderAPI_Copy::BRepBuilderAPI_Copy(TopoDS_Shape const&, unsigned int) () from /usr/lib/libTKTopAlgo-6.5.0.so 0000006 0xa1f1a8bd in PartDesign::Transformed::execute() () from /opt/freecad/Mod/PartDesign/PartDesign.so 0000007 0xb6c628dd in App::DocumentObject::recompute() () from /opt/freecad/lib/libFreeCADApp.so 0000008 0xab5ea59f in Part::Feature::recompute() () from /opt/freecad/Mod/Part/Part.so 0000009 0xb6c251bf in App::Document::_recomputeFeature(App::DocumentObject*) () from /opt/freecad/lib/libFreeCADApp.so 0000010 0xb6c24edf in App::Document::recompute() () from /opt/freecad/lib/libFreeCADApp.so 0000011 0xb6c7dc6e in App::DocumentPy::recompute(_object*) () from /opt/freecad/lib/libFreeCADApp.so 0000012 0xb6c79736 in App::DocumentPy::staticCallback_recompute(_object*, _object*) () from /opt/freecad/lib/libFreeCADApp.so 0000013 0xb66f78cf in PyCFunction_Call () from /usr/lib/libpython2.7.so.1.0 0000014 0xb66568bf in PyEval_EvalFrameEx () from /usr/lib/libpython2.7.so.1.0 0000015 0xb660c4d2 in PyEval_EvalCodeEx () from /usr/lib/libpython2.7.so.1.0 0000016 0xb660c813 in PyEval_EvalCode () from /usr/lib/libpython2.7.so.1.0 0000017 0xb660c8b3 in PyRun_StringFlags () from /usr/lib/libpython2.7.so.1.0 0000018 0xb699f4a1 in Base::InterpreterSingleton::runString(char const*) () from /opt/freecad/lib/libFreeCADBase.so 0000019 0xb7118c77 in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) () from /opt/freecad/lib/libFreeCADGui.so 0000020 0xb7119022 in Gui::Command::updateActive() () from /opt/freecad/lib/libFreeCADGui.so 0000021 0xa1d1b818 in CmdPartDesignLinearPattern::activated(int) () from /opt/freecad/Mod/PartDesign/PartDesignGui.so 0000022 0xb7118560 in Gui::Command::invoke(int) () from /opt/freecad/lib/libFreeCADGui.so 0000023 0xb710fc80 in Gui::Action::onActivated() () from /opt/freecad/lib/libFreeCADGui.so 0000024 0xb71148f7 in Gui::Action::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) () from /opt/freecad/lib/libFreeCADGui.so 0000025 0xb59836b1 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/i386-linux-gnu/libQtCore.so.4 0000026 0xb5c409bd in QAction::triggered(bool) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000027 0xb5c40c5b in QAction::activate(QAction::ActionEvent) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000028 0xb614d410 in QToolButton::nextCheckState() () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000029 0xb6074c57 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000030 0xb6074f56 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000031 0xb614d4ad in QToolButton::mouseReleaseEvent(QMouseEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000032 0xb5ca21ac in QWidget::event(QEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000033 0xb60741f9 in QAbstractButton::event(QEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000034 0xb614ebdc in QToolButton::event(QEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000035 0xb5c47ed4 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000036 0xb5c4e024 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000037 0xb70b5604 in Gui::GUIApplication::notify(QObject*, QEvent*) () from /opt/freecad/lib/libFreeCADGui.so 0000038 0xb596c97e in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/i386-linux-gnu/libQtCore.so.4 #39 0xb5c48e95 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 #40 0xb5cd5074 in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000041 0xb5cd3c0d in QApplication::x11ProcessEvent(_XEvent*) () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000042 0xb5d00eac in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000043 0xb404bd86 in g_main_context_dispatch () from /lib/i386-linux-gnu/libglib-2.0.so.0 0000044 0xb404c125 in ?? () from /lib/i386-linux-gnu/libglib-2.0.so.0 0000045 0xb404c201 in g_main_context_iteration () from /lib/i386-linux-gnu/libglib-2.0.so.0 0000046 0xb599f887 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/i386-linux-gnu/libQtCore.so.4 0000047 0xb5d00aaa in ?? () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000048 0xb596b50d in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/i386-linux-gnu/libQtCore.so.4 0000049 0xb596b7a9 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/i386-linux-gnu/libQtCore.so.4 0000050 0xb5970eba in QCoreApplication::exec() () from /usr/lib/i386-linux-gnu/libQtCore.so.4 0000051 0xb5c45a74 in QApplication::exec() () from /usr/lib/i386-linux-gnu/libQtGui.so.4 0000052 0xb70b1bd8 in Gui::Application::runApplication() () from /opt/freecad/lib/libFreeCADGui.so 0000053 0x0804f1b9 in main () =================================================== Attached file is my simple project that crash. I tried Linear pattern on "Revlotion" Part. | ||||
2012-12-07 09:00
Your Revolution object is broken because it hasn't defined an axis. But there are also some checks required when doing the pattern feature to avoid the crash. |
git show 3c3abd4 |
| 2012-12-07 09:00 | danielpoplawski | New Issue | |
| 2012-12-07 09:00 | danielpoplawski | File Added: prototype-test.FCStd | |
| 2012-12-07 11:48 | wmayer | Note Added: 0002623 | |
| 2012-12-07 12:04 | wmayer | Note Added: 0002624 | |
| 2012-12-07 12:04 | wmayer | Status | new => closed |
| 2012-12-07 12:05 | wmayer | Resolution | open => fixed |
| 2012-12-07 12:05 | wmayer | Fixed in Version | => 0.13 |
