My bad. I was testing the Draft WB.
I was not aware of this PartDesign.Draft tool.
It crashes also for me :
Log: Loading PartDesign module... done
Log: Loading GUI of PartDesign module... done
Log: X Error: BadWindow (invalid Window parameter) 3
Major opcode: 31 (X_GrabKeyboard)
Resource id: 0x0
Err: Program received signal SIGSEGV, Segmentation fault.
Err: #0 /lib/x86_64-linux-gnu/libc.so.6(+0x37140) [0x7fbc69c7d140]
Err: #1 0x7fbc1dde6730 in Geom_Circle::Circ() const from /usr/local/lib/libTKG3d.so.7+0
Err: 0000002 0x7fbc1de0bf46 in GeomAdaptor_Curve::Circle() const from /usr/local/lib/libTKG3d.so.7+0x56
Err: 0000003 0x7fbc1bb155de in BRepAdaptor_Curve::Circle() const from /usr/local/lib/libTKBRep.so.7+0x25e
Err: 0000004 0x7fbc09fa0c75 in PartDesign::Draft::execute() from /home/tomate/Software/FreeCAD/build/Mod/PartDesign/_PartDesign.so+0x81b
Err: 0000005 0x7fbc6c64440f in App::DocumentObject::recompute() from /home/tomate/Software/FreeCAD/build/lib/libFreeCADApp.so+0xbd
Err: 0000006 0x7fbc1f00f8cb in Part::Feature::recompute() from /home/tomate/Software/FreeCAD/build/Mod/Part/Part.so+0x1b
Err: 0000007 0x7fbc6c5da5eb in App::Document::_recomputeFeature(App::DocumentObject*) from /home/tomate/Software/FreeCAD/build/lib/libFreeCADApp.so+0xa5
Err: 0000008 0x7fbc6c5d8fcc in App::Document::recompute() from /home/tomate/Software/FreeCAD/build/lib/libFreeCADApp.so+0x324
Err: 0000009 0x7fbc6c6857e4 in App::DocumentPy::recompute(_object*) from /home/tomate/Software/FreeCAD/build/lib/libFreeCADApp.so+0x5e
Err: 0000010 0x7fbc6c67f563 in App::DocumentPy::staticCallback_recompute(_object*, _object*) from /home/tomate/Software/FreeCAD/build/lib/libFreeCADApp.so+0x119
Err: 0000011 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalFrameEx+0x9179) [0x7fbc6b860b09]
Err: 0000012 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCodeEx+0x7d8) [0x7fbc6b988b88]
Err: 0000013 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyEval_EvalCode+0x19) [0x7fbc6b8577f9]
Err: 0000014 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(PyRun_StringFlags+0x76) [0x7fbc6b900e76]
Err: 0000015 0x7fbc6be91991 in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /home/tomate/Software/FreeCAD/build/lib/libFreeCADBase.so+0xe7
Err: 0000016 0x7fbc6d2a81e5 in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) from /home/tomate/Software/FreeCAD/build/lib/libFreeCADGui.so+0x197
Err: 0000017 0x7fbc6d2a8aaa in Gui::Command::updateActive() from /home/tomate/Software/FreeCAD/build/lib/libFreeCADGui.so+0x3a
Err: 0000018 0x7fbc09a239ec in finishFeature(Gui::Command const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, App::DocumentObject*, bool, bool) from /home/tomate/Software/FreeCAD/build/Mod/PartDesign/PartDesignGui.so+0xa6
Err: 0000019 0x7fbc09a27b0b in finishDressupFeature(Gui::Command const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, Part::Feature*, std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&) from /home/tomate/Software/FreeCAD/build/Mod/PartDesign/PartDesignGui.so+0x46c
Err: 0000020 0x7fbc09a284e0 in CmdPartDesignDraft::activated(int) from /home/tomate/Software/FreeCAD/build/Mod/PartDesign/PartDesignGui.so+0x40c
Err: 0000021 0x7fbc6d2a785e in Gui::Command::invoke(int) from /home/tomate/Software/FreeCAD/build/lib/libFreeCADGui.so+0x9a
Err: 0000022 0x7fbc6d29b001 in Gui::Action::onActivated() from /home/tomate/Software/FreeCAD/build/lib/libFreeCADGui.so+0x21
Err: 0000023 /home/tomate/Software/FreeCAD/build/lib/libFreeCADGui.so(+0x7c03b6) [0x7fbc6d2a03b6]
Err: 0000024 0x7fbc6a761f70 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x4d0
Err: 0000025 0x7fbc6ac73dc2 in QAction::triggered(bool) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x42
Err: 0000026 0x7fbc6ac75113 in QAction::activate(QAction::ActionEvent) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x83
Err: 0000027 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x5a0fa3) [0x7fbc6b055fa3]
Err: 0000028 0x7fbc6b0560f4 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x74
Err: 0000029 0x7fbc6b11c0aa in QToolButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0xa
Err: 0000030 0x7fbc6acd0930 in QWidget::event(QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x2a0
Err: 0000031 0x7fbc6ac7a03c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x8c
Err: 0000032 0x7fbc6ac81136 in QApplication::notify(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x476
Err: 0000033 0x7fbc6d273ca2 in Gui::GUIApplication::notify(QObject*, QEvent*) from /home/tomate/Software/FreeCAD/build/lib/libFreeCADGui.so+0x10e
Err: 0000034 0x7fbc6a74d8ad in QCoreApplication::notifyInternal(QObject*, QEvent*) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x8d
Err: 0000035 0x7fbc6ac8073d in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x14d
Err: 0000036 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x249452) [0x7fbc6acfe452]
Err: 0000037 0x7fbc6acfdce3 in QApplication::x11ProcessEvent(_XEvent*) from /usr/lib/x86_64-linux-gnu/libQtGui.so.4+0x16b3
Err: 0000038 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272592) [0x7fbc6ad27592]
Err: #39 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_dispatch+0x2e7) [0x7fbc63ab6fb7]
Err: #40 /lib/x86_64-linux-gnu/libglib-2.0.so.0(+0x4b1f0) [0x7fbc63ab71f0]
Err: 0000041 /lib/x86_64-linux-gnu/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7fbc63ab727c]
Err: 0000042 0x7fbc6a77e20e in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x7e
Err: 0000043 /usr/lib/x86_64-linux-gnu/libQtGui.so.4(+0x272666) [0x7fbc6ad27666]
Err: 0000044 0x7fbc6a74c12f in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x3f
Err: 0000045 0x7fbc6a74c495 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x1b5
Err: 0000046 0x7fbc6a752459 in QCoreApplication::exec() from /usr/lib/x86_64-linux-gnu/libQtCore.so.4+0x99
Err: 0000047 0x7fbc6d201b93 in Gui::Application::runApplication() from /home/tomate/Software/FreeCAD/build/lib/libFreeCADGui.so+0x1ec3
Err: 0000048 /home/tomate/Software/FreeCAD/build/bin/FreeCAD(main+0xa89) [0x56450f6f20e3]
Err: 0000049 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf1) [0x7fbc69c671c1]
Err: 0000050 /home/tomate/Software/FreeCAD/build/bin/FreeCAD(_start+0x2a) [0x56450f6f14ba]
