| 0004224 | FreeCAD | Bug | public | 2019-12-13 15:55 | 2020-03-02 20:16 |
| Reporter | Zolko | Assigned To | realthunder | ||
| Platform | AppImage | OS | Linux | OS Version | Ubuntu 18.04 |
| Summary | 0004224: crash with App::Link | ||||
| Description | Hello, when linking App::Parts from different files/documents, FreeCAD crashes when trying to edit a function of a linked part. This bug has been reported in the forum, but without answer: https://forum.freecadweb.org/viewtopic.php?f=8&t=41552 I tried to nail the problem down to the lowest level, and it's a bug in how App::Link handles documents in the background. I've made the same assembly structure but using exclusively App::Part and App::Link functions, no Assembly4 whatsoever involved. The structure is the following:
The 3 files are attached for testing. The problem arises only when opening the top-level assembly first, when opening the parts starting from the lower level to up (Part_1 → Part_2 → Assembly) then everything works as expected, it's possible to edit Part_1 directly from Assembly document.
When opening the file asm.FCStdt, the result is actually 2 things, but which come from the same problem I think : 1) Link not restored: as you can see, the link to Part_1 is correctly restored in the file/document asm, but not in Part_2. 2) Segmentation fault: if you try to edit the Part::Cone of the — unrestored — Part_1, FreeCAD crashes:
| Steps To Reproduce |
→ the link to Part_1 in Part_2 appears as "Link not restored". When trying to edit the Part::Cone of Part_1 inside Part_2 (also called edit in place) FreeCAD segfaults. | ||||
| Additional Information | hubertz @ipag-9102 ~ > FreeCAD_0.19-18846.AppImage /tmp/.mount_FreeCAZkpZLn FreeCAD 0.19, Libs: 0.19R18846 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## Sheet Metal workbench loaded Loading Assembly 4 WorkBench connect failed: No such file or directory 5.58e-07 <App> Document.cpp(2549): Part_2#Link.LinkedObject: Link not restored Linked object: Part Linked file: Part_1.FCStd Program received signal SIGSEGV, Segmentation fault. #0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7fe891df2f20] #1 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so(+0x5b3193) [0x7fe894793193] 0000002 0x7fe894796d1b in Gui::DAG::Model::selectionChanged(Gui::SelectionChanges const&) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x4b 0000003 0x7fe894790325 in Gui::DAG::View::onSelectionChanged(Gui::SelectionChanges const&) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x275 0000004 0x7fe894a1536e in Gui::SelectionObserver::_onSelectionChanged(Gui::SelectionChanges const&) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x4e 0000005 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so(+0x597d2f) [0x7fe894777d2f] 0000006 0x7fe894a238bf in Gui::SelectionSingleton::slotSelectionChanged(Gui::SelectionChanges const&) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x28f 0000007 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so(+0x597d2f) [0x7fe894777d2f] 0000008 0x7fe894a244be in Gui::SelectionSingleton::notify(Gui::SelectionChanges&&) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x10e 0000009 0x7fe894a2df1c in Gui::SelectionSingleton::addSelection(char const*, char const*, char const*, float, float, float, std::vector<Gui::SelectionSingleton::SelObj, std::allocator<Gui::SelectionSingleton::SelObj> > const*, bool) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x8cc 0000010 0x7fe89477b1d5 in Gui::DocumentItem::updateItemSelection(Gui::DocumentObjectItem*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x385 0000011 0x7fe89477b489 in Gui::DocumentItem::clearSelection(Gui::DocumentObjectItem*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x199 0000012 0x7fe8947827e5 in Gui::TreeWidget::onItemSelectionChanged() from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x3c5 0000013 0x7fe89253f7b8 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x780 0000014 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5(+0x3406a7) [0x7fe892f1e6a7] 0000015 0x7fe89253f7b8 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x780 0000016 0x7fe8925041b6 in QItemSelectionModel::selectionChanged(QItemSelection const&, QItemSelection const&) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x2a 0000017 0x7fe892508b09 in QItemSelectionModel::emitSelectionChanged(QItemSelection const&, QItemSelection const&) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0xe9 0000018 0x7fe892508fd3 in QItemSelectionModel::select(QItemSelection const&, QFlags<QItemSelectionModel::SelectionFlag>) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x1d1 0000019 0x7fe892f17fe4 in QTreeViewPrivate::select(QModelIndex const&, QModelIndex const&, QFlags<QItemSelectionModel::SelectionFlag>) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x554 0000020 0x7fe892f1822d in QTreeView::setSelection(QRect const&, QFlags<QItemSelectionModel::SelectionFlag>) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x1fd 0000021 0x7fe892ed491d in QAbstractItemView::mousePressEvent(QMouseEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x2fd 0000022 0x7fe892f1a936 in QTreeView::mousePressEvent(QMouseEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x74 0000023 0x7fe892d7dc2a in QWidget::event(QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0xba 0000024 0x7fe892de7875 in QFrame::event(QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x27 0000025 0x7fe892ed828e in QAbstractItemView::viewportEvent(QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x2f6 0000026 0x7fe892f1a79d in QTreeView::viewportEvent(QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x111 0000027 0x7fe892526b6d in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0xd1 0000028 0x7fe892d5281a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0xce 0000029 0x7fe892d57095 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x79d 0000030 0x7fe8945cf9e9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x89 0000031 0x7fe892529186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x88 0000032 0x7fe892d5653f in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x283 0000033 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5(+0x1af554) [0x7fe892d8d554] 0000034 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5(+0x1b03a6) [0x7fe892d8e3a6] 0000035 0x7fe892d5282a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0xde 0000036 0x7fe892d583f1 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Widgets.so.5+0x1af9 0000037 0x7fe8945cf9e9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x89 0000038 0x7fe892529186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x88 #39 0x7fe8928cf40b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Gui.so.5+0x6d3 #40 0x7fe8928cfff7 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Gui.so.5+0x175 0000041 0x7fe8928bcdd4 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Gui.so.5+0x64 0000042 /tmp/.mount_FreeCAZkpZLn/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5af0e) [0x7fe88c854f0e] 0000043 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x2e8) [0x7fe88e7589d8] 0000044 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/./libglib-2.0.so.0(+0x51c21) [0x7fe88e758c21] 0000045 /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x2e) [0x7fe88e758cae] 0000046 0x7fe89255842b in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x63 0000047 0x7fe892525bc1 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x187 0000048 0x7fe892529a39 in QCoreApplication::exec() from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libQt5Core.so.5+0x105 0000049 0x7fe8945506c0 in Gui::Application::runApplication() from /tmp/.mount_FreeCAZkpZLn/usr/bin/../lib/libFreeCADGui.so+0x15b0 0000050 /tmp/.mount_FreeCAZkpZLn/usr/bin/freecad(main+0x74d) [0x5636934937cd] 0000051 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fe891dd5b97] 0000052 /tmp/.mount_FreeCAZkpZLn/usr/bin/freecad(+0x451f) [0x56369349451f] | ||||
| FreeCAD Information | OS: Ubuntu 18.04.3 LTS (KDE/plasma) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.18846 (Git) AppImage Build type: Release Branch: master Hash: ceeb776fff25c679752571d5d8e6c4c8b1fd9008 Python version: 3.7.3 Qt version: 5.12.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/United Kingdom (en_GB) | ||||
Has been reported by another user, I think it's the same problem: https://forum.freecadweb.org/viewtopic.php?f=20&t=34806&p=353631#p353612 |
Assigning to realthunder |
https://github.com/FreeCAD/FreeCAD/commit/0a608e94139ef94cbd58b578b7de24a911730adc https://github.com/FreeCAD/FreeCAD/commit/5eb15e4219d3d4e5c2650f6c876dbefe17c14aa5 https://github.com/FreeCAD/FreeCAD/commit/27771fc6ee93170b6ecb978ff4da438a5b9cfe97 |
| 2019-12-13 15:55 | Zolko | New Issue | |
| 2019-12-13 15:55 | Zolko | File Added: bug_linknotrestored.png | |
| 2019-12-13 15:55 | Zolko | File Added: asm.FCStd1 | |
| 2019-12-13 15:55 | Zolko | File Added: Part_1.FCStd | |
| 2019-12-13 15:55 | Zolko | File Added: Part_2.FCStd | |
| 2019-12-13 16:12 | Zolko | Note Added: 0013909 | |
| 2019-12-13 23:58 | Kunda1 | Assigned To | => realthunder |
| 2019-12-13 23:58 | Kunda1 | Status | new => assigned |
| 2019-12-13 23:58 | Kunda1 | Note Added: 0013910 | |
| 2020-02-14 19:41 | wmayer | Status | assigned => closed |
| 2020-02-14 19:41 | wmayer | Resolution | open => fixed |
| 2020-02-14 19:41 | wmayer | Fixed in Version | => 0.19 |
| 2020-02-14 19:41 | wmayer | Note Added: 0014158 | |
| 2020-03-02 20:16 | wmayer | Changeset attached | => FreeCAD master 0a608e94 |
