0004431FreeCADBugpublic2022-02-04 19:00
ReporterGregory son of Carl Assigned To
Status confirmedResolutionopen
Target Version0.20
Summary0004431: Crash after editing Part Design feature links with DAGView active
DescriptionLink to forum thread
When the DAGView panel is active, FreeCAD will crash after editing App:Link objects that reference Part Design features such as Pads, Revolves, Sweeps, and Sketches.
Steps To Reproduce
  1. Download both attached files into the same folder (Assembly3Test.FCStd, Assembly3TestCube2.FCStd)
  2. Activate DAG view. (Tools> Edit Parameters...> BaseApp> Preferences> DockWindows> DAGView> Enabled=True)
  3. Restart FreeCAD
  4. Open Assembly3Test.FCStd
  5. Double-click the Pad feature in Assembly3Test
  6. Click Cancel or OK in the task window.
The crash happens immediately after releasing the mouse button
Additional Information
FreeCAD 0.19, Libs: 0.19R22284 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Loading Assembly4 WorkBench
Sheet Metal workbench loaded
During initialization the error "'backend.qt4 is not a valid rc parameter (see rcParams.keys() for a list of valid parameters)'" occurred in /home/gregory/.FreeCAD/Mod/animation/InitGui.py
Please look into the log file for further information
During initialization the error "inconsistent use of tabs and spaces in indentation (<string>, line 48)" occurred in /home/gregory/.FreeCAD/Mod/GDT/InitGui.py
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x37840) [0x7fd13613f840]
#1  0x7fd138ba2f54 in Gui::DAG::Model::slotResetEdit(Gui::ViewProviderDocumentObject const&) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x44
0000002  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so(+0x382d1c) [0x7fd13892ad1c]
0000003  0x7fd138981c35 in Gui::Document::_resetEdit() from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x1f5
0000004  0x7fd13891022a in Gui::Application::setEditDocument(Gui::Document*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x3a
0000005  0x7fd13899177c in Gui::DocumentPy::resetEdit(_object*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x2c
0000006  0x7fd1389917c4 in Gui::DocumentPy::staticCallback_resetEdit(_object*, _object*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x24
0000007  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(PyCFunction_Call+0xf7) [0x7fd138393d87]
0000008  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(_PyObject_MakeTpCall+0x250) [0x7fd138348850]
0000009  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4e36) [0x7fd1383d77d6]
0000010  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x2e2) [0x7fd138344f92]
0000011  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCodeEx+0x44) [0x7fd138345d54]
0000012  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCode+0x1c) [0x7fd1383fb6ac]
0000013  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(+0x219ecf) [0x7fd138419ecf]
0000014  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(+0x252b84) [0x7fd138452b84]
0000015  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libpython3.8.so.1.0(PyRun_StringFlags+0x7d) [0x7fd138452c1d]
0000016  0x7fd137c4d2ba in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADBase.so+0x6a
0000017  0x7fd1389ec3b8 in Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x98
0000018  0x7fd1389ec5a2 in Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x102
0000019  0x7fd04a7a9e35 in PartDesignGui::TaskDlgFeatureParameters::reject() from /tmp/.mount_FreeCAbs6iBc/usr/lib/PartDesignGui.so+0x105
0000020  0x7fd04a7aeaa1 in PartDesignGui::TaskDlgSketchBasedParameters::reject() from /tmp/.mount_FreeCAbs6iBc/usr/lib/PartDesignGui.so+0x31
0000021  0x7fd138c85819 in Gui::TaskView::TaskView::reject() from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x59
0000022  0x7fd1366867b8 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Core.so.5+0x780
0000023  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5(+0x274bbb) [0x7fd136f9cbbb]
0000024  0x7fd1366867b8 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Core.so.5+0x780
0000025  0x7fd136f351fe in QAbstractButton::clicked(bool) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0x32
0000026  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5(+0x20d8b7) [0x7fd136f358b7]
0000027  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5(+0x20e14c) [0x7fd136f3614c]
0000028  0x7fd136f361e8 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0x88
0000029  0x7fd136ec7c3e in QWidget::event(QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0xce
0000030  0x7fd136e9c82a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0xde
0000031  0x7fd136ea1095 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0x79d
0000032  0x7fd1389baab9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x89
0000033  0x7fd136670186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Core.so.5+0x88
0000034  0x7fd136ea053f in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0x283
0000035  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5(+0x1af554) [0x7fd136ed7554]
0000036  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5(+0x1b03a6) [0x7fd136ed83a6]
0000037  0x7fd136e9c82a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0xde
0000038  0x7fd136ea23f1 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Widgets.so.5+0x1af9
#39  0x7fd1389baab9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x89
#40  0x7fd136670186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Core.so.5+0x88
0000041  0x7fd136a1640b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Gui.so.5+0x6d3
0000042  0x7fd136a16ff7 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Gui.so.5+0x175
0000043  0x7fd136a03dd4 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Gui.so.5+0x64
0000044  /tmp/.mount_FreeCAbs6iBc/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5af0e) [0x7fd132402f0e]
0000045  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x2cb) [0x7fd13364cb3b]
0000046  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/./libglib-2.0.so.0(+0x54d81) [0x7fd13364cd81]
0000047  /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x2e) [0x7fd13364ce0e]
0000048  0x7fd13669f42b in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Core.so.5+0x63
0000049  0x7fd13666cbc1 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Core.so.5+0x187
0000050  0x7fd136670a39 in QCoreApplication::exec() from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libQt5Core.so.5+0x105
0000051  0x7fd138932ca2 in Gui::Application::runApplication() from /tmp/.mount_FreeCAbs6iBc/usr/bin/../lib/libFreeCADGui.so+0x15a2
0000052  /tmp/.mount_FreeCAbs6iBc/usr/bin/freecad(+0x37cd) [0x560a04df97cd]
0000053  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [0x7fd13612c09b]
0000054  /tmp/.mount_FreeCAbs6iBc/usr/bin/freecad(+0x4521) [0x560a04dfa521]
Tags#pending-forum, crash, DAG, Part Design
FreeCAD InformationOS: Debian GNU/Linux 10 (buster) (KDE/default)
Version: 0.19.22284 (Git) AppImage
Hash: bf1e8e48389f5e9e25bd77b67fe98da4213e797c
Python version: 3.8.5
Gregory son of Carl
2020-09-09 19:05
reporter
Assembly3TestCube2.FCStd (10,796 bytes)
Assembly3Test.FCStd (2,771 bytes)
2020-09-10 14:49
administrator   ~0014731
Confirmed by chrisb on the thread
2020-12-04 02:51
administrator   ~0015074
@chennes responded in https://forum.freecadweb.org/viewtopic.php?f=20&t=49982#p454170
2022-02-04 19:00
administrator   ~0016353
bumped forum thread
yorik
2022-03-03 13:55
administrator   ~0016936
This ticket has been migrated to GitHub as issue 6103.
2020-09-09 19:05 Gregory son of Carl New Issue
2020-09-09 19:05 Gregory son of Carl Tag Attached: 0.19
2020-09-09 19:05 Gregory son of Carl Tag Attached: crash
2020-09-09 19:05 Gregory son of Carl Tag Attached: DAG
2020-09-09 19:05 Gregory son of Carl Tag Attached: Part Design
2020-09-09 19:05 Gregory son of Carl File Added: Assembly3TestCube2.FCStd
2020-09-09 19:05 Gregory son of Carl File Added: Assembly3Test.FCStd
2020-09-10 14:49 Kunda1 Status new => confirmed
2020-09-10 14:49 Kunda1 Note Added: 0014731
2020-09-10 14:49 Kunda1 Target Version => 0.19
2020-12-04 02:51 Kunda1 Note Added: 0015074
2022-02-04 18:59 Kunda1 Tag Attached: #pending-forum
2022-02-04 18:59 Kunda1 Tag Detached: 0.19
2022-02-04 19:00 Kunda1 Note Added: 0016353
