0004311FreeCADBugpublic2022-01-24 19:16
ReporterBruceL Assigned To
PrioritylowSeveritycrashReproducibilityalways
Status acknowledgedResolutionopen
OS Debian GNU/Linux bullseye/sid
Target Version0.20
Summary0004311: Crash on a loft command with incorrect input (OCC bug)
DescriptionI'm experience a crash on 0.19-20406 Appimage. But with an admittedly wrong user input, but I would think that the program should complain to me instead of crashing. Lofting and adding the section that was used to start the loft will crash FreeCAD.
Thank you in advance for you time.
Forum post: https://forum.freecad.org/viewtopic.php?f=8&t=45013&p=386183#p386183
Note: this ticket is be tracked via OCC bugs in the bugtracker forum thread
Steps To Reproduce1. Create a new file
2. Go to part design workbench
3. Draw a simple sketch on XY plane, ie a rectangle
4. Draw another simple sketch either on a different plane, or on a parallel plane
5. select one sketch
6. click additive loft
7. Click add section
8. click on the first sketch (yes, this is wrong).
9. Click add section
10. click on the second sketch.
11. Crash.
Additional InformationReading failed from embedded file: PartShape.bin (0 bytes, 2 bytes compressed)
6.79e-07 <App> Document.cpp(3715): Failed to recompute crash#AdditiveLoft: Loft: At least one section is needed
Recompute failed! Please check report view.
0.0035612 <App> Document.cpp(3715): Failed to recompute crash#AdditiveLoft: Loft: At least one section is needed
3.67836 <App> Document.cpp(3715): Failed to recompute crash#AdditiveLoft: Loft could not be built
3.7744 Tree.cpp(293): [TreeView] duplicate child item crash#AdditiveLoft.Sketch
3.77562 Tree.cpp(293): [ComboView] duplicate child item crash#AdditiveLoft.Sketch
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3b7e0) [0x7f5d0350e7e0]
#1 /tmp/.mount_FreeCAhwE8MW/usr/lib/./libTKTopAlgo.so.7(+0x17a177) [0x7f5cdbfcd177]
0000002 0x7f5cdbfcdb72 in BRepLib::EncodeRegularity(TopoDS_Shape const&, double) from /tmp/.mount_FreeCAhwE8MW/usr/lib/./libTKTopAlgo.so.7+0x152
0000003 0x7f5cdd607c26 in BRepOffsetAPI_ThruSections::Build() from /tmp/.mount_FreeCAhwE8MW/usr/lib/./libTKOffset.so.7+0xd16
0000004 0x7f5c6afae337 in PartDesign::Loft::execute() from /tmp/.mount_FreeCAhwE8MW/usr/lib/_PartDesign.so+0x7f7
0000005 0x7f5d0529956e in App::DocumentObject::recompute() from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADApp.so+0x9e
0000006 0x7f5cddd6818c in Part::Feature::recompute() from /tmp/.mount_FreeCAhwE8MW/usr/lib/Part.so+0xc
0000007 0x7f5d0522fded in App::Document::_recomputeFeature(App::DocumentObject*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADApp.so+0x2fd
0000008 0x7f5d0528904c in App::Document::recomputeFeature(App::DocumentObject*, bool) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADApp.so+0xdc
0000009 0x7f5c6a4cd2b2 in PartDesignGui::TaskLoftParameters::onSelectionChanged(Gui::SelectionChanges const&) from /tmp/.mount_FreeCAhwE8MW/usr/lib/PartDesignGui.so+0x122
0000010 0x7f5d0618286e in Gui::SelectionObserver::_onSelectionChanged(Gui::SelectionChanges const&) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x4e
0000011 /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so(+0x5cc47c) [0x7f5d05ede47c]
0000012 0x7f5d06190917 in Gui::SelectionSingleton::slotSelectionChanged(Gui::SelectionChanges const&) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x2b7
0000013 /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so(+0x5cc47c) [0x7f5d05ede47c]
0000014 0x7f5d06191566 in Gui::SelectionSingleton::notify(Gui::SelectionChanges&&) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0xf6
0000015 0x7f5d0619a762 in Gui::SelectionSingleton::addSelection(char const*, char const*, char const*, float, float, float, std::vector<Gui::SelectionSingleton::SelObj, std::allocator<Gui::SelectionSingleton::SelObj> > const*, bool) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x7e2
0000016 0x7f5d05f74891 in Gui::SoFCUnifiedSelection::setSelection(std::vector<Gui::SoFCUnifiedSelection::PickedInfo, std::allocator<Gui::SoFCUnifiedSelection::PickedInfo> > const&, bool) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x8f1
0000017 0x7f5d05f75dd1 in Gui::SoFCUnifiedSelection::handleEvent(SoHandleEventAction*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x141
0000018 0x7f5d048a923a in SoAction::traverse(SoNode*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0x6a
0000019 0x7f5d04a9384b in SoChildList::traverse(SoAction*, int, int) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0xeb
0000020 0x7f5d04aeb378 in SoGroup::doAction(SoAction*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0x58
0000021 0x7f5d04b08b3a in SoSeparator::doAction(SoAction*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0x2a
0000022 0x7f5d048a923a in SoAction::traverse(SoNode*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0x6a
0000023 0x7f5d048b3960 in SoHandleEventAction::beginTraversal(SoNode*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0x70
0000024 0x7f5d048aa0a2 in SoAction::apply(SoNode*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0x442
0000025 0x7f5d04ab379b in SoEventManager::processEvent(SoEvent const*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libCoin.so.80+0x15b
0000026 0x7f5d05ff8fee in SIM::Coin3D::Quarter::QuarterWidget::processSoEvent(SoEvent const*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x1e
0000027 0x7f5d06001d6a in SIM::Coin3D::Quarter::SoQTQuarterAdaptor::processSoEvent(SoEvent const*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x5a
0000028 0x7f5d0603bf3a in Gui::View3DInventorViewer::processSoEventBase(SoEvent const*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0xa
0000029 0x7f5d060118ca in Gui::BlenderNavigationStyle::processSoEvent(SoEvent const*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x22a
0000030 0x7f5d0600cea8 in Gui::NavigationStyle::processEvent(SoEvent const*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0xf8
0000031 0x7f5d0603bea5 in Gui::View3DInventorViewer::processSoEvent(SoEvent const*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x65
0000032 0x7f5d05fefe05 in SIM::Coin3D::Quarter::EventFilter::eventFilter(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x185
0000033 0x7f5d039ebb6d in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Core.so.5+0xd1
0000034 0x7f5d0421781a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Widgets.so.5+0xce
0000035 0x7f5d0421c095 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Widgets.so.5+0x79d
0000036 0x7f5d05d1bae9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x89
0000037 0x7f5d039ee186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Core.so.5+0x88
0000038 0x7f5d0421b53f in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Widgets.so.5+0x283
#39 /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Widgets.so.5(+0x1af554) [0x7f5d04252554]
#40 /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Widgets.so.5(+0x1b03a6) [0x7f5d042533a6]
0000041 0x7f5d0421782a in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Widgets.so.5+0xde
0000042 0x7f5d0421d3f1 in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Widgets.so.5+0x1af9
0000043 0x7f5d05d1bae9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x89
0000044 0x7f5d039ee186 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Core.so.5+0x88
0000045 0x7f5d03d9440b in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Gui.so.5+0x6d3
0000046 0x7f5d03d94ff7 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Gui.so.5+0x175
0000047 0x7f5d03d81dd4 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Gui.so.5+0x64
0000048 /tmp/.mount_FreeCAhwE8MW/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5af0e) [0x7f5cff8cbf0e]
0000049 /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x2e8) [0x7f5d00ac39d8]
0000050 /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/./libglib-2.0.so.0(+0x51c21) [0x7f5d00ac3c21]
0000051 /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x2e) [0x7f5d00ac3cae]
0000052 0x7f5d03a1d42b in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Core.so.5+0x63
0000053 0x7f5d039eabc1 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Core.so.5+0x187
0000054 0x7f5d039eea39 in QCoreApplication::exec() from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libQt5Core.so.5+0x105
0000055 0x7f5d05c944ea in Gui::Application::runApplication() from /tmp/.mount_FreeCAhwE8MW/usr/bin/../lib/libFreeCADGui.so+0x155a
0000056 /tmp/.mount_FreeCAhwE8MW/usr/bin/freecad(main+0x74d) [0x561431e1e7cd]
0000057 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [0x7f5d034f9e0b]
0000058 /tmp/.mount_FreeCAhwE8MW/usr/bin/freecad(+0x451f) [0x561431e1f51f]
Tags#ready-for-migration, OCC 7.5, OCC Bug, OCC NotOnRoadmap, upstream
FreeCAD InformationOS: Debian GNU/Linux bullseye/sid (GNOME/gnome)
Version: 0.19.20406 (Git) AppImage
Hash: bb45a2b01f9aafeae00cdf60c87b43fc36ad28ad
Python version: 3.8.2
Locale: English/Canada (en_CA)
chennes
2020-11-12 04:16
administrator   ~0014978
The bug is really in OCC (https://forum.freecad.org/viewtopic.php?f=8&t=45013&p=447258#p447258) -- do we want to try to work around it, at least this exact incarnation, by preventing the original profile from being selected as a section?
2020-12-31 12:25
administrator   ~0015185
Tracking this via OCC bugs in the bugtracker forum thread
2022-01-15 13:51
administrator   ~0016213
This needs an upstream ticket
yorik
2022-03-03 13:55
administrator   ~0016878
This ticket has been migrated to GitHub as issue 6044.
2020-04-11 23:47 BruceL New Issue
2020-04-13 09:25 openBrain Status new => acknowledged
2020-11-12 04:16 chennes Note Added: 0014978
2020-11-12 04:16 chennes Note Edited: 0014978
2020-11-12 12:25 Kunda1 Tag Attached: OCC 7.5
2020-11-12 12:25 Kunda1 Tag Attached: upstream
2020-11-12 12:25 Kunda1 Tag Attached: OCC Bug
2020-11-21 16:32 Kunda1 Summary Crash on a loft command with incorrect input => Crash on a loft command with incorrect input (OCC bug)
2020-12-31 12:25 Kunda1 Note Added: 0015185
2020-12-31 12:25 Kunda1 Description Updated
2022-01-15 13:51 Kunda1 Tag Attached: OCC NotOnRoadmap
2022-01-15 13:51 Kunda1 Note Added: 0016213
2022-01-24 19:16 Kunda1 Tag Attached: #ready-for-migration
