0004661 | FreeCAD | Bug | public | 2021-05-19 01:18 | 2022-01-24 19:16 |
Reporter | BruceL | Assigned To | chennes | ||
Priority | low | Severity | crash | Reproducibility | always |
Status | assigned | Resolution | open | ||
Product Version | 0.19 | ||||
Summary | 0004661: FreeCAD crashes on spreadsheet update Due to Fillet | ||||
Description | Forum Post FreeCAD crashes on spreadsheet update Due to Fillet | ||||
Steps To Reproduce | On the attached file, open the spreadsheet. Change the formula in cell B6 from
to
FreeCAD will crash with the output attached below. I'm attempting to change the depth of the "case" pad by changing the formula as listed above. | ||||
Additional Information | Program received signal SIGSEGV, Segmentation fault. #0 /lib/x86_64-linux-gnu/libc.so.6(+0x3bd60) [0x7f6b54484d60] #1 0x7f6b2b362b98 in Geom2d_Curve::Value(double) const from /tmp/.mount_FreeCA0weYfg/usr/lib/./libTKG2d.so.7+0x18 0000002 0x7f6b2d505b46 in ChFi3d_Builder::PerformMoreThreeCorner(int, int) from /tmp/.mount_FreeCA0weYfg/usr/lib/./libTKFillet.so.7+0xa936 0000003 0x7f6b2d4e701e in ChFi3d_Builder::PerformIntersectionAtEnd(int) from /tmp/.mount_FreeCA0weYfg/usr/lib/./libTKFillet.so.7+0x7cfe 0000004 0x7f6b2d4eae1a in ChFi3d_Builder::PerformOneCorner(int, bool) from /tmp/.mount_FreeCA0weYfg/usr/lib/./libTKFillet.so.7+0x10ba 0000005 0x7f6b2d4874fe in ChFi3d_Builder::PerformFilletOnVertex(int) from /tmp/.mount_FreeCA0weYfg/usr/lib/./libTKFillet.so.7+0x51e 0000006 0x7f6b2d4884fc in ChFi3d_Builder::Compute() from /tmp/.mount_FreeCA0weYfg/usr/lib/./libTKFillet.so.7+0xe5c 0000007 0x7f6b2d64d504 in BRepFilletAPI_MakeFillet::Build() from /tmp/.mount_FreeCA0weYfg/usr/lib/./libTKFillet.so.7+0x34 0000008 0x7f6af984bbb1 in PartDesign::Fillet::execute() from /tmp/.mount_FreeCA0weYfg/usr/lib/_PartDesign.so+0x4b1 0000009 0x7f6b56269ec2 in App::DocumentObject::recompute() from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADApp.so+0x122 0000010 0x7f6b2e48962a in Part::Feature::recompute() from /tmp/.mount_FreeCA0weYfg/usr/lib/Part.so+0xa 0000011 0x7f6b561fa81d in App::Document::_recomputeFeature(App::DocumentObject*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADApp.so+0x2fd 0000012 0x7f6b56255dd6 in App::Document::recompute(std::vector<App::DocumentObject*, std::allocator<App::DocumentObject*> > const&, bool, bool*, int) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADApp.so+0x5c6 0000013 0x7f6b562b557f in App::DocumentPy::recompute(_object*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADApp.so+0x2df 0000014 0x7f6b562b5749 in App::DocumentPy::staticCallback_recompute(_object*, _object*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADApp.so+0x29 0000015 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(PyCFunction_Call+0xf5) [0x7f6b566b7725] 0000016 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(_PyObject_MakeTpCall+0x230) [0x7f6b5665f550] 0000017 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4ddd) [0x7f6b566c928d] 0000018 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x2ea) [0x7f6b56660d9a] 0000019 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCodeEx+0x3a) [0x7f6b566ee40a] 0000020 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(PyEval_EvalCode+0x1c) [0x7f6b566ee42c] 0000021 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(+0x1e05aa) [0x7f6b567135aa] 0000022 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(+0x224225) [0x7f6b56757225] 0000023 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libpython3.8.so.1.0(PyRun_StringFlags+0x80) [0x7f6b567572c0] 0000024 0x7f6b55f542cc in Base::InterpreterSingleton::runString[abi:cxx11](char const*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADBase.so+0x6c 0000025 0x7f6b56d6e091 in Gui::Command::_runCommand(char const*, int, Gui::Command::DoCmd_Type, char const*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADGui.so+0x91 0000026 0x7f6b56d6e231 in Gui::Command::_doCommand(char const*, int, Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADGui.so+0x101 0000027 0x7f6af8961365 in SpreadsheetGui::SheetModel::setData(QModelIndex const&, QVariant const&, int) from /tmp/.mount_FreeCA0weYfg/usr/lib/SpreadsheetGui.so+0x105 0000028 0x7f6af8955e30 in SpreadsheetGui::SheetView::editingFinished() from /tmp/.mount_FreeCA0weYfg/usr/lib/SpreadsheetGui.so+0x140 0000029 0x7f6b5497ca18 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Core.so.5+0x6c0 0000030 0x7f6af89478f7 in SpreadsheetGui::LineEdit::event(QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/lib/SpreadsheetGui.so+0x127 0000031 0x7f6b5518c7f2 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Widgets.so.5+0xdc 0000032 0x7f6b55190cbb in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Widgets.so.5+0x467 0000033 0x7f6b56d3cdf9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADGui.so+0x89 0000034 0x7f6b54966606 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Core.so.5+0x86 0000035 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Widgets.so.5(+0x1aff6c) [0x7f6b551c7f6c] 0000036 0x7f6b5518c7f2 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Widgets.so.5+0xdc 0000037 0x7f6b5519231d in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Widgets.so.5+0x1ac9 0000038 0x7f6b56d3cdf9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADGui.so+0x89 #39 0x7f6b54966606 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Core.so.5+0x86 #40 0x7f6b54d08eaa in QGuiApplicationPrivate::processKeyEvent(QWindowSystemInterfacePrivate::KeyEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Gui.so.5+0xca 0000041 0x7f6b54d0b939 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Gui.so.5+0x79 0000042 0x7f6b54cf8c65 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Gui.so.5+0x63 0000043 /tmp/.mount_FreeCA0weYfg/usr/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5b010) [0x7f6b501b2010] 0000044 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x27d) [0x7f6b518e123d] 0000045 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/./libglib-2.0.so.0(+0x554d1) [0x7f6b518e14d1] 0000046 /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x31) [0x7f6b518e1571] 0000047 0x7f6b549950e8 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Core.so.5+0x5e 0000048 0x7f6b54963019 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Core.so.5+0x187 0000049 0x7f6b54966e8f in QCoreApplication::exec() from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libQt5Core.so.5+0xfd 0000050 0x7f6b56cc6926 in Gui::Application::runApplication() from /tmp/.mount_FreeCA0weYfg/usr/bin/../lib/libFreeCADGui.so+0x15f6 0000051 /tmp/.mount_FreeCA0weYfg/usr/bin/freecad(+0x44bf) [0x55a8337464bf] 0000052 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea) [0x7f6b5446fd0a] 0000053 /tmp/.mount_FreeCA0weYfg/usr/bin/freecad(+0x47d9) [0x55a8337467d9] | ||||
Tags | #ready-for-migration, fillet, OCC 7.6, OCC Bug, upstream | ||||
FreeCAD Information | |||||
Trying again to upload the file, I'm informed that there's no space on the webserver. |
I'm not able to upload the file to the bug tracker. It's available on the forum here |
Can you still reproduce this on the latest HEAD? I am not getting a crash right now. |
I can report that the crash still occurs on the latest weekly Appimage (25429). I'll see what's involved in running the latest HEAD version. |
If the AppImage is compiled against the official OpenCASCADE libraries, rather than the "blobfish" patched version, then we'll just have to wait for OCCT 7.6 to be released to fix this. |
I suspect that's the case, the current Appimage shows it using the OCC 7.5.2 libraries. |
This ticket has been migrated to GitHub as issue 6219. |
2021-05-19 01:18 | BruceL | New Issue | |
2021-05-19 01:22 | BruceL | Note Added: 0015664 | |
2021-05-19 01:23 | BruceL | Note Added: 0015665 | |
2021-05-19 01:28 | chennes | Assigned To | => chennes |
2021-05-19 01:28 | chennes | Status | new => assigned |
2021-08-17 16:57 | chennes | Status | assigned => feedback |
2021-08-17 16:57 | chennes | Note Added: 0015825 | |
2021-08-19 21:22 | BruceL | Note Added: 0015829 | |
2021-08-19 21:22 | BruceL | Status | feedback => assigned |
2021-08-20 15:13 | chennes | Note Added: 0015842 | |
2021-08-20 21:03 | BruceL | Note Added: 0015844 | |
2021-08-25 14:18 | Kunda1 | Tag Attached: fillet | |
2021-08-25 14:19 | Kunda1 | Tag Attached: OCC 7.6 | |
2021-08-25 14:19 | Kunda1 | Tag Attached: upstream | |
2021-08-25 14:19 | Kunda1 | Tag Attached: OCC Bug | |
2022-01-24 19:16 | Kunda1 | Tag Attached: #ready-for-migration |
