| Description | Freecad crash when I try to apply a fillet on a arc. You just have to select the fillet tool and select the edge (the fillet menu is not even opened). This arc has been generated by an other fillet.
Stacktrace:
Delete: Selection not restricted to one sketch and its subelementsProgram received signal SIGSEGV, Segmentation fault.
#0 /usr/lib/libc.so.6(+0x3a7e0) [0x7f89ba6dd7e0]
#1 0x7f8932daae88 in Geom2d_Curve::Value(double) const from /tmp/.mount_FreeCAMZHBBs/usr/lib/./libTKG2d.so.7+0x8
0000002 0x7f8937406478 in ChFi3d_Builder::PerformOneCorner(int, bool) from /tmp/.mount_FreeCAMZHBBs/usr/lib/./libTKFillet.so.7+0x2988
0000003 0x7f89373a5b27 in ChFi3d_Builder::PerformFilletOnVertex(int) from /tmp/.mount_FreeCAMZHBBs/usr/lib/./libTKFillet.so.7+0x477
0000004 0x7f89373a6229 in ChFi3d_Builder::Compute() from /tmp/.mount_FreeCAMZHBBs/usr/lib/./libTKFillet.so.7+0x619
0000005 0x7f89375249c0 in BRepFilletAPI_MakeFillet::Build() from /tmp/.mount_FreeCAMZHBBs/usr/lib/./libTKFillet.so.7+0x20
0000006 0x7f895190d988 in PartDesign::Fillet::execute() from /tmp/.mount_FreeCAMZHBBs/usr/lib/_PartDesign.so+0x3d8
0000007 0x7f89bf85f6ad in App::DocumentObject::recompute() from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADApp.so+0x8d
0000008 0x7f895137452b in Part::Feature::recompute() from /tmp/.mount_FreeCAMZHBBs/usr/lib/./Part.so+0xb
0000009 0x7f89bf820b9c in App::Document::_recomputeFeature(App::DocumentObject*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADApp.so+0x9c
0000010 0x7f89bf8250e1 in App::Document::recompute() from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADApp.so+0x1e1
0000011 0x7f89bf891324 in App::DocumentPy::recompute(_object*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADApp.so+0x34
0000012 0x7f89bf891457 in App::DocumentPy::staticCallback_recompute(_object*, _object*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADApp.so+0x27
0000013 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libpython3.6m.so.1.0(_PyCFunction_FastCallDict+0x18e) [0x7f89beeb3c1e]
0000014 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libpython3.6m.so.1.0(+0x1650da) [0x7f89bef4d0da]
0000015 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libpython3.6m.so.1.0(_PyEval_EvalFrameDefault+0x3002) [0x7f89bef50902]
0000016 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libpython3.6m.so.1.0(+0x164cde) [0x7f89bef4ccde]
0000017 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libpython3.6m.so.1.0(PyEval_EvalCodeEx+0x6d) [0x7f89bef4d30d]
0000018 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libpython3.6m.so.1.0(PyEval_EvalCode+0x3b) [0x7f89bef4d35b]
0000019 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libpython3.6m.so.1.0(PyRun_StringFlags+0x92) [0x7f89bef88772]
0000020 0x7f89bf3e6274 in Base::InterpreterSingleton::runString(char const*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADBase.so+0x54
0000021 0x7f89c0028f4a in Gui::Command::doCommand(Gui::Command::DoCmd_Type, char const*, ...) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADGui.so+0x12a
0000022 0x7f89c00293e4 in Gui::Command::updateActive() from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADGui.so+0x24
0000023 0x7f89319cbbe5 in finishFeature(Gui::Command const*, std::string const&, App::DocumentObject*, bool, bool) from /tmp/.mount_FreeCAMZHBBs/usr/lib/PartDesignGui.so+0x125
0000024 0x7f89319cc360 in finishDressupFeature(Gui::Command const*, std::string const&, Part::Feature*, std::vector<std::string, std::allocator<std::string> > const&) from /tmp/.mount_FreeCAMZHBBs/usr/lib/PartDesignGui.so+0x300
0000025 0x7f89319ce223 in makeChamferOrFillet(Gui::Command*, std::string const&) from /tmp/.mount_FreeCAMZHBBs/usr/lib/PartDesignGui.so+0xe3
0000026 0x7f89319ce3cd in CmdPartDesignFillet::activated(int) from /tmp/.mount_FreeCAMZHBBs/usr/lib/PartDesignGui.so+0x2d
0000027 0x7f89c002d14c in Gui::Command::invoke(int) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADGui.so+0x4c
0000028 0x7f89bb5fe8d1 in QMetaObject::activate(QObject*, int, int, void**) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Core.so.5+0x2c1
0000029 0x7f89bbf79372 in QAction::triggered(bool) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x32
0000030 0x7f89bbf7c09d in QAction::activate(QAction::ActionEvent) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x5d
0000031 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5(+0x25952d) [0x7f89bc07e52d]
0000032 0x7f89bc07e664 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0xd4
0000033 0x7f89bc14564a in QToolButton::mouseReleaseEvent(QMouseEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0xa
0000034 0x7f89bbfc573a in QWidget::event(QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x96a
0000035 0x7f89bc145729 in QToolButton::event(QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x69
0000036 0x7f89bbf82c6c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x9c
0000037 0x7f89bbf87b5d in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0xc6d
0000038 0x7f89c0004371 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADGui.so+0x41
#39 0x7f89bb5d4425 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Core.so.5+0x75
#40 0x7f89bbf86860 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x1a0
0000041 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5(+0x1b9cd1) [0x7f89bbfdecd1]
0000042 /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5(+0x1bc2c3) [0x7f89bbfe12c3]
0000043 0x7f89bbf82c6c in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x9c
0000044 0x7f89bbf872ea in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Widgets.so.5+0x3fa
0000045 0x7f89c0004371 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADGui.so+0x41
0000046 0x7f89bb5d4425 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Core.so.5+0x75
0000047 0x7f89bb9787db in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Gui.so.5+0x40b
0000048 0x7f89bb979f75 in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Gui.so.5+0x115
0000049 0x7f89bb95b74b in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Gui.so.5+0x7b
0000050 /tmp/.mount_FreeCAMZHBBs/usr/lib/libQt5XcbQpa.so.5(+0xa05d0) [0x7f89b53805d0]
0000051 /tmp/.mount_FreeCAMZHBBs/usr/lib/libglib-2.0.so.0(+0x569be) [0x7f89b74589be]
0000052 /tmp/.mount_FreeCAMZHBBs/usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x33) [0x7f89b7459826]
0000053 /tmp/.mount_FreeCAMZHBBs/usr/lib/libglib-2.0.so.0(+0x57a0b) [0x7f89b7459a0b]
0000054 /tmp/.mount_FreeCAMZHBBs/usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x4a) [0x7f89b7459acf]
0000055 0x7f89bb62598c in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Core.so.5+0x5c
0000056 0x7f89bb5d253b in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Core.so.5+0xfb
0000057 0x7f89bb5da466 in QCoreApplication::exec() from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libQt5Core.so.5+0x86
0000058 0x7f89bffa125c in Gui::Application::runApplication() from /tmp/.mount_FreeCAMZHBBs/usr/bin/../lib/libFreeCADGui.so+0x16bc
0000059 /tmp/.mount_FreeCAMZHBBs/usr/bin/FreeCAD(main+0x6c9) [0x403829]
0000060 /usr/lib/libc.so.6(__libc_start_main+0xf3) [0x7f89ba6c9ee3]
0000061 /tmp/.mount_FreeCAMZHBBs/usr/bin/FreeCAD() [0x404699]
